After the latest update of xorg and the tkg kernel to 5.10.1 my second monitor isn't being able to turn on. It's detected in the system settings, but if it never turns on even when activated. Trying to set it up through xrandr only gives me this error message:
xrandr: Configure crtc 4 failed
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 21 (RRSetCrtcConfig)
Value in failed request: 0x0
Serial number of failed request: 62
Current serial number in output stream: 62
Before anyone asks here's my inxi -Fxxxza as well, if it helps:
Kernel: 5.10.1-103-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq-skylake
root=UUID=5a5a9fdd-3013-4a23-8eae-41aa9903e2c0 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
Mobo: Dell model: 0P84C9 v: A01 serial: <filter> UEFI: Dell v: 1.11.0
date: 12/04/2019
ID-1: BAT0 charge: 55.7 Wh condition: 55.7/74.0 Wh (75%) volts: 12.4/11.1
model: Samsung SDI DELL 0GFJ681 type: Li-ion serial: <filter> status: Full
Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44840
Speed: 2800 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 2800 2: 1648
3: 2800 4: 2800 5: 2801 6: 2800 7: 2803 8: 2801
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: Sunplus Innovation Integrated Webcam type: USB driver: uvcvideo
bus ID: 1-12:5 chip ID: 1bcf:2c01
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel,nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.10.1-103-tkg-bmq
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus ID: 02:00.0 chip ID: 10ec:8168
vendor: Dell driver: ath10k_pci v: kernel port: d000 bus ID: 03:00.0
chip ID: 168c:003e
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:4
chip ID: 0cf3:e007
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
port: f060 bus ID: 00:17.0 chip ID: 8086.282a rev: 31
Local Storage: total: 1.13 TiB used: 153.25 GiB (13.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS240G2G0B-00EPW0
size: 223.58 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0000
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ02ABD100H
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1D
ID-1: / raw size: 223.28 GiB size: 1.13 TiB (517.19%) used: 153.25 GiB (13.3%)
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 223.28 GiB size: 1.13 TiB (517.19%)
used: 153.25 GiB (13.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw size: 223.28 GiB size: 1.13 TiB (517.19%)
ID-5: /var/tmp raw size: 223.28 GiB size: 1.13 TiB (517.19%)
ID-1: swap-1 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
ID-2: swap-2 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
System Temperatures: cpu: 58.0 C mobo: 45.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 259 Uptime: 25m wakeups: 1 Memory: 15.38 GiB used: 3.73 GiB (24.2%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1462 pacman: 1451
lib: 397 flatpak: 11 Shell: Zsh v: 5.8 running in: alacritty inxi: 3.2.00
I don't know which one is the cause, but I'm betting on xorg. Maybe a partial update? Or is there some issue with NVIDIA and 5.10.1 that I didn't hear of?
