I now have a noisy boot splash even though quiet appears to be enabled.
How to set quiet splash?
# GRUB boot loader configuration
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Garuda'
GRUB_CMDLINE_LINUX_DEFAULT='quiet resume=UUID=f5be392d-7846-41f0-ab1e-51a5ac5fb447 loglevel=3'
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda-dr460nized/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
# This config file imports drop-in files from /etc/default/grub.d/.
for garuda_grub_d in ${sysconfdir}/default/grub.d/*.cfg ; do if [ -e "${garuda_grub_d}" ]; then source "${garuda_grub_d}"; fi; done
GRUB_EARLY_INITRD_LINUX_STOCK=''
Garuda Boot Options application
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=50d71b1c-9d62-4b5d-858b-a9016b65b502 rw rootflags=subvol=@
quiet resume=UUID=f5be392d-7846-41f0-ab1e-51a5ac5fb447 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop System: Dell product: Precision 5720 AIO v: N/A
serial: <superuser required> Chassis: type: 13 serial: <superuser required>
Mobo: Dell model: 0WNP26 v: A00 serial: <superuser required> part-nu: 075D
uuid: <superuser required> UEFI: Dell v: 2.23.0 date: 12/07/2023
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 926 high: 1215 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 1215 3: 900 4: 900
5: 800 6: 900 7: 900 8: 900 bogomips: 54398
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: DP-1
empty: DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0300
Device-2: AMD Ellesmere [Radeon Pro WX 7100 Mobile] vendor: Dell
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 1002:67c0 class-ID: 0380 temp: 25.0 C
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:5 chip-ID: 0bda:58c3
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 1165mm (45.88")
Monitor-1: DP-1 model: LG (GoldStar) HDR 4K serial: <filter> built: 2024
res: 3840x2160 hz: 60 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: iris x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.0-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:1912 memory: 15.17 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 530 (SKL GT2) driver: mesa intel v: 24.1.0-arch1.1
device-ID: 8086:1912 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: AMD Radeon Pro WX 7100 Graphics (RADV POLARIS10) driver: mesa radv
v: 24.1.0-arch1.1 device-ID: 1002:67c0 surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.0-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:6 chip-ID: 8087:0a2b
Local Storage: total: 3.68 TiB used: 2.7 TiB (73.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM951 NVMe 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: BXV77D0Q temp: 29.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT960BX500SSD1
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R022 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST2000LM003 HN-M201RAD
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0002 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Lexar model: USB Flash Drive
size: 57.62 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 919.39 GiB size: 919.39 GiB (100.00%)
used: 697.29 GiB (75.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 919.39 GiB size: 919.39 GiB (100.00%)
ID-4: /var/log raw-size: 919.39 GiB size: 919.39 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.39 GiB size: 919.39 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 34.0 C mobo: N/A gpu: amdgpu temp: 25.0 C
Fan Speeds (rpm): cpu: 941
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 7.65 GiB (24.6%)
Processes: 338 Power: uptime: 10m states: freeze,mem,disk suspend: deep
Packages: 1654 pm: pacman pkgs: 1645 libs: 453 tools: octopi,paru
pm: flatpak pkgs: 9 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-05-24
Last full system update: 2024-06-06
