Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=4757eb94-0065-4f96-8914-c77c06fa1e7d rw rootflags=subvol=@
resume=UUID=d3701c73-f146-42e6-9957-47e42ad885dd loglevel=3 ibt=off
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
serial: <superuser required> UEFI: American Megatrends v: H.20
date: 07/03/2019
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3703 high: 4074 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3822
3: 3600 4: 3600 5: 4060 6: 3600 7: 3600 8: 3688 9: 3600 10: 3600 11: 4074
12: 3600 bogomips: 86401
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 2d:00.0
chip-ID: 10de:2489 class-ID: 0300
Device-2: Realtek NexiGo N660P FHD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4:4
chip-ID: 0bda:0567 class-ID: 0102 serial: <filter>
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 4880x2560 s-dpi: 96 s-size: 1291x677mm (50.83x26.65")
s-diag: 1458mm (57.39")
Monitor-1: DP-0 pos: top-left res: 1440x2560 hz: 60 dpi: 118
size: 311x553mm (12.24x21.77") diag: 634mm (24.98") modes: N/A
Monitor-2: DP-2 pos: primary,bottom-r res: 3440x1440 hz: 60 dpi: 109
size: 798x335mm (31.42x13.19") diag: 865mm (34.07") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX 3060
Ti/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 2d:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: RODE Microphones Deity VO-7U driver: snd-usb-audio type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 19f7:003c
Device-4: Realtek NexiGo N660P FHD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
Local Storage: total: 1.36 TiB used: 378.64 GiB (27.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 42.9 C
model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
used: 378.64 GiB (87.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-4: /var/log raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.29 GiB used: 1.89 GiB (6.1%)
System Temperatures: cpu: 47.2 C mobo: N/A gpu: nvidia temp: 39 C
Processes: 352 Uptime: 3h 23m wakeups: 0 Memory: available: 31.29 GiB
used: 8.37 GiB (26.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1568 libs: 486 tools: octopi,pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
System install date: 2022-11-05
Last full system update: 2023-07-09
After my PC resumes from suspend, I get no output from the motherboard or video card. My keyboard will wake the PC up, but the monitors do not turn on, the keyboard and mouse do not light up, speakers don't work, and as far as I can tell the PC is not accepting any input either.
However, a restart will have it all operating normally. It also operates normally after shutting down completely and standard startup.
I've google'd around and even asked chatgpt... couldn't find anyone reporting anything similiar. I'm open to ideas before I just completely re-install...
