No Option to Connect to Wifi
Hello all! After a fresh installation of Garuda dr460nized I have no option to connect to wifi. This seems to be a similar issue to one I encountered with Ubuntu 22.04 that actually prompted my switch to Garuda.
From the outputs below you'll find that my wifi card is detected, but appears to have no driver, resulting in the network unclaimed state (output of lshw -c Network).
λ garuda-inxi
Kernel: 6.1.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=5ae91ff7-bba3-45dd-a087-4869ba37774d rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ZenBook UX433FA_UX433FA v: 1.0
Mobo: ASUSTeK model: UX433FA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: UX433FA.309 date: 07/15/2019
ID-1: BAT0 charge: 36.1 Wh (100.0%) condition: 36.1/50.1 Wh (72.1%)
volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 152
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Whiskey Lake
model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1837 high: 2000 min/max: 400/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 2000 2: 2000 3: 2000
4: 2000 5: 2000 6: 2000 7: 2000 8: 700 bogomips: 31999
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: ASUSTeK
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
Device-2: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 13d3:56cb class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: AU Optronics 0x323d built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 620 (WHL
GT2) direct-render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound API: ALSA v: k6.1.11-zen1-1-zen running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: N/A
modules: iwlwifi bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
type: USB driver: r8152 bus-ID: 2-1:2 chip-ID: 2357:0601 class-ID: 0000
IF: enp0s20f0u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-10:6 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 476.94 GiB used: 18.42 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 24.9 C scheme: GPT
used: 18.42 GiB (3.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C pch: 36.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 238 Uptime: 1h 2m wakeups: 83 Memory: 15.44 GiB
used: 3.17 GiB (20.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1439
libs: 362 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
System install date:     2023-02-15
Last full system update: 2023-02-15
Below are the outputs of the diagnostic commands I've run so far:
sudo dmesg | grep wifi
[    5.136266] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    5.139456] iwlwifi 0000:00:14.3: Can find a correct rfid for crf id 0x5a2
[    5.139484] iwlwifi: probe of 0000:00:14.3 failed with error -22
lspci -v
00:00.0 Host bridge: Intel Corporation Coffee Lake HOST and DRAM Controller (rev 0b)
Subsystem: ASUSTeK Computer Inc. Device 1461
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation WhiskeyLake-U GT2 [UHD Graphics 620] (prog-if 00 [VGA controller])
DeviceName: VGA
Flags: bus master, fast devsel, latency 0, IRQ 124
Memory at b0000000 (64-bit, non-prefetchable) [size=16M]
Memory at a0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 3000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0b)
Flags: fast devsel, IRQ 16
Memory at b1210000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device_pci_legacy
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Flags: fast devsel, IRQ 255
Memory at b122b000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:12.0 Signal processing controller: Intel Corporation Cannon Point-LP Thermal Controller (rev 30)
Memory at b122a000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Point-LP USB 3.1 xHCI Controller (rev 30) (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Device 201f
Flags: bus master, medium devsel, latency 0, IRQ 125
Memory at b1200000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Point-LP Shared SRAM (rev 30)
Subsystem: Intel Corporation Device 7270
Flags: fast devsel
Memory at b1220000 (64-bit, non-prefetchable) [disabled] [size=8K]
Memory at b1229000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.3 Network controller: Intel Corporation Cannon Point-LP CNVi [Wireless-AC] (rev 30)
DeviceName: WLAN
Subsystem: Intel Corporation Device 0000
Memory at b121c000 (64-bit, non-prefetchable) [size=16K]
Kernel modules: iwlwifi
00:15.0 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Controller #0 (rev 30)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at b1223000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO I2C Controller #1 (rev 30)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at b1227000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller: Intel Corporation Cannon Point-LP MEI Controller #1 (rev 30)
Memory at b1226000 (64-bit, non-prefetchable) [disabled] [size=4K]
Kernel modules: mei_me
00:1d.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 4000-4fff [size=4K] [16-bit]
Memory behind bridge: b1300000-b14fffff [size=2M] [32-bit]
Prefetchable memory behind bridge: b1500000-b16fffff [size=2M] [32-bit]
Kernel driver in use: pcieport
00:1d.4 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #13 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: b1100000-b11fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
00:1e.0 Communication controller: Intel Corporation Cannon Point-LP Serial IO UART Controller #2 (rev 30)
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at b1225000 (64-bit, non-prefetchable) [size=4K]
Memory at b1224000 (64-bit, non-prefetchable) [size=4K]
00:1e.2 Serial bus controller: Intel Corporation Cannon Point-LP Serial IO SPI Controller (rev 30)
Flags: bus master, fast devsel, latency 0, IRQ 22
Memory at b1228000 (64-bit, non-prefetchable) [size=4K]
00:1f.0 ISA bridge: Intel Corporation Cannon Point-LP LPC Controller (rev 30)
00:1f.3 Audio device: Intel Corporation Cannon Point-LP High Definition Audio Controller (rev 30) (prog-if 80)
Subsystem: ASUSTeK Computer Inc. Device 16ce
Flags: bus master, fast devsel, latency 32, IRQ 135
Memory at b1218000 (64-bit, non-prefetchable) [size=16K]
Memory at b1000000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
00:1f.4 SMBus: Intel Corporation Cannon Point-LP SMBus Controller (rev 30)
Flags: medium devsel, IRQ 16
Memory at b1222000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Cannon Point-LP SPI Controller (rev 30)
Flags: fast devsel
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
02:00.0 Non-Volatile memory controller: Intel Corporation SSD 660P Series (rev 03) (prog-if 02 [NVM Express])
Subsystem: Intel Corporation Device 390d
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Memory at b1100000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
Kernel modules: nvme
sudo lshw -c Network
*-network UNCLAIMED
description: Network controller
product: Cannon Point-LP CNVi [Wireless-AC]
vendor: Intel Corporation
physical id: 14.3
bus info: [email protected]:00:14.3
version: 30
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:b121c000-b121ffff
*-network
description: Ethernet interface
physical id: 1
bus info: [email protected]:1
logical name: enp0s20f0u1
serial: 9c:a2:f4:c6:2b:a2
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.12.13 duplex=full firmware=rtl8153a-4 v2 02/07/20 ip=10.0.1.139 link=yes multicast=yes port=MII speed=1Gbit/s
Any suggestions on how to fix this problem would be wonderful! Previously I tried installing the iwlwifi backports when I ran Ubuntu 22.04 (sudo apt install backport-iwlwifi-dkms). However this only served to eliminate the unclaimed network issue, but did not restore full function to the wifi card.
Hi there, welcome to the forum!
Just a shot in the dark:
Looks like a kernel regression, like this:
So, I'd try some different kernels, back and forth, eg LTS kernel, linux, linux-mainline (and headers).
sudo pacman -S linux linux-headers
sudo pacman -S linux-mainline linux-mainline-headers
But honestly I've seen many issues like yours, on several distros, at a quick internet search. So chances are low... :crossed_fingers:
Hello and thank you for the suggestions! I'll let you know if the kernel swapping works; what I may do in addition is install the backport dkms for iwlwifi and reboot to see if this changes the behavior of iwlwifi.
One alternative I've also thought about is using an intermediary compatibility utility like NDISWrapper to try using the windows driver for my particular network controller.
This is usually not a good solution for modern wifi hardware. I would not recommend this route. I would suggest searching for and testing older, and newer versions of iwlwifi firmware on the Intel website, (and possibly Google Android developmental versions).
Thank you for the suggestion! I'll try that next; I booted with the three suggested kernels but had no difference in WiFi capability.
However, when I booted with linux-mainline I was able to successfully download and install the drivers for an external WiFi adapter I'd bought to address the near identical problem that occurred when I ran Ubuntu 22.04. I should add that the external WiFi adapter was incompatible with my Ubuntu but installed in seconds with my current Garuda setup.
The current kernel 6.1.12 should have fixed the issue. If that was the issue you were facing, of course. But it's worth trying...
Hello! I tried booting with the most recent Arch kernel, but to no avail. After some additional digging and troubleshooting I noticed something I hadn't before:
ls /lib/firmware | grep 'iwlwifi'
ls /lib/firmware/ | grep 'iwlwifi'
.rw-r--r-- 116k root 16 Feb 10:55  iwlwifi-100-5.ucode.xz
.rw-r--r-- 197k root 16 Feb 10:55  iwlwifi-105-6.ucode.xz
.rw-r--r-- 206k root 16 Feb 10:55  iwlwifi-135-6.ucode.xz
.rw-r--r-- 116k root 16 Feb 10:55  iwlwifi-1000-5.ucode.xz
.rw-r--r-- 199k root 16 Feb 10:55  iwlwifi-2000-6.ucode.xz
.rw-r--r-- 208k root 16 Feb 10:55  iwlwifi-2030-6.ucode.xz
.rw-r--r-- 218k root 16 Feb 10:55  iwlwifi-3160-17.ucode.xz
.rw-r--r-- 263k root 16 Feb 10:55  iwlwifi-3168-29.ucode.xz
.rw-r--r--  55k root 16 Feb 10:55  iwlwifi-3945-2.ucode.xz
.rw-r--r--  69k root 16 Feb 10:55  iwlwifi-4965-2.ucode.xz
.rw-r--r-- 113k root 16 Feb 10:55  iwlwifi-5000-5.ucode.xz
.rw-r--r-- 113k root 16 Feb 10:55  iwlwifi-5150-2.ucode.xz
.rw-r--r-- 132k root 16 Feb 10:55  iwlwifi-6000-4.ucode.xz
.rw-r--r-- 183k root 16 Feb 10:55  iwlwifi-6000g2a-6.ucode.xz
.rw-r--r-- 184k root 16 Feb 10:55  iwlwifi-6000g2b-6.ucode.xz
.rw-r--r-- 139k root 16 Feb 10:55  iwlwifi-6050-5.ucode.xz
.rw-r--r-- 243k root 16 Feb 10:55  iwlwifi-7260-17.ucode.xz
.rw-r--r-- 259k root 16 Feb 10:55  iwlwifi-7265-17.ucode.xz
.rw-r--r-- 270k root 16 Feb 10:55  iwlwifi-7265D-29.ucode.xz
.rw-r--r-- 379k root 16 Feb 10:55  iwlwifi-8000C-34.ucode.xz
.rw-r--r-- 381k root 16 Feb 10:55  iwlwifi-8000C-36.ucode.xz
.rw-r--r-- 379k root 16 Feb 10:55  iwlwifi-8265-34.ucode.xz
.rw-r--r-- 383k root 16 Feb 10:55  iwlwifi-8265-36.ucode.xz
.rw-r--r-- 416k root 16 Feb 10:55  iwlwifi-9000-pu-b0-jf-b0-34.ucode.xz
.rw-r--r-- 412k root 16 Feb 10:55  iwlwifi-9000-pu-b0-jf-b0-38.ucode.xz
.rw-r--r-- 435k root 16 Feb 10:55  iwlwifi-9000-pu-b0-jf-b0-46.ucode.xz
.rw-r--r-- 416k root 16 Feb 10:55  iwlwifi-9260-th-b0-jf-b0-34.ucode.xz
.rw-r--r-- 412k root 16 Feb 10:55  iwlwifi-9260-th-b0-jf-b0-38.ucode.xz
.rw-r--r-- 430k root 16 Feb 10:55  iwlwifi-9260-th-b0-jf-b0-46.ucode.xz
.rw-r--r-- 392k root 16 Feb 10:55  iwlwifi-cc-a0-50.ucode.xz
.rw-r--r-- 442k root 16 Feb 10:55  iwlwifi-cc-a0-59.ucode.xz
.rw-r--r-- 453k root 16 Feb 10:55  iwlwifi-cc-a0-66.ucode.xz
.rw-r--r-- 462k root 16 Feb 10:55  iwlwifi-cc-a0-72.ucode.xz
.rw-r--r-- 463k root 16 Feb 10:55  iwlwifi-cc-a0-73.ucode.xz
.rw-r--r-- 468k root 16 Feb 10:55  iwlwifi-cc-a0-74.ucode.xz
.rw-r--r-- 475k root 16 Feb 10:55  iwlwifi-cc-a0-77.ucode.xz
.rw-r--r-- 393k root 16 Feb 10:55  iwlwifi-Qu-b0-hr-b0-50.ucode.xz
.rw-r--r-- 446k root 16 Feb 10:55  iwlwifi-Qu-b0-hr-b0-59.ucode.xz
.rw-r--r-- 459k root 16 Feb 10:55  iwlwifi-Qu-b0-hr-b0-66.ucode.xz
.rw-r--r-- 468k root 16 Feb 10:55  iwlwifi-Qu-b0-hr-b0-72.ucode.xz
.rw-r--r-- 470k root 16 Feb 10:55  iwlwifi-Qu-b0-hr-b0-73.ucode.xz
.rw-r--r-- 475k root 16 Feb 10:55  iwlwifi-Qu-b0-hr-b0-74.ucode.xz
.rw-r--r-- 482k root 16 Feb 10:55  iwlwifi-Qu-b0-hr-b0-77.ucode.xz
.rw-r--r-- 377k root 16 Feb 10:55  iwlwifi-Qu-b0-jf-b0-50.ucode.xz
.rw-r--r-- 423k root 16 Feb 10:55  iwlwifi-Qu-b0-jf-b0-59.ucode.xz
.rw-r--r-- 430k root 16 Feb 10:55  iwlwifi-Qu-b0-jf-b0-66.ucode.xz
.rw-r--r-- 437k root 16 Feb 10:55  iwlwifi-Qu-b0-jf-b0-72.ucode.xz
.rw-r--r-- 438k root 16 Feb 10:55  iwlwifi-Qu-b0-jf-b0-73.ucode.xz
.rw-r--r-- 443k root 16 Feb 10:55  iwlwifi-Qu-b0-jf-b0-74.ucode.xz
.rw-r--r-- 449k root 16 Feb 10:55  iwlwifi-Qu-b0-jf-b0-77.ucode.xz
.rw-r--r-- 393k root 16 Feb 10:55  iwlwifi-Qu-c0-hr-b0-50.ucode.xz
.rw-r--r-- 446k root 16 Feb 10:55  iwlwifi-Qu-c0-hr-b0-59.ucode.xz
.rw-r--r-- 459k root 16 Feb 10:55  iwlwifi-Qu-c0-hr-b0-66.ucode.xz
.rw-r--r-- 468k root 16 Feb 10:55  iwlwifi-Qu-c0-hr-b0-72.ucode.xz
.rw-r--r-- 470k root 16 Feb 10:55  iwlwifi-Qu-c0-hr-b0-73.ucode.xz
.rw-r--r-- 475k root 16 Feb 10:55  iwlwifi-Qu-c0-hr-b0-74.ucode.xz
.rw-r--r-- 482k root 16 Feb 10:55  iwlwifi-Qu-c0-hr-b0-77.ucode.xz
.rw-r--r-- 377k root 16 Feb 10:55  iwlwifi-Qu-c0-jf-b0-50.ucode.xz
.rw-r--r-- 423k root 16 Feb 10:55  iwlwifi-Qu-c0-jf-b0-59.ucode.xz
.rw-r--r-- 430k root 16 Feb 10:55  iwlwifi-Qu-c0-jf-b0-66.ucode.xz
.rw-r--r-- 437k root 16 Feb 10:55  iwlwifi-Qu-c0-jf-b0-72.ucode.xz
.rw-r--r-- 438k root 16 Feb 10:55  iwlwifi-Qu-c0-jf-b0-73.ucode.xz
.rw-r--r-- 443k root 16 Feb 10:55  iwlwifi-Qu-c0-jf-b0-74.ucode.xz
.rw-r--r-- 449k root 16 Feb 10:55  iwlwifi-Qu-c0-jf-b0-77.ucode.xz
.rw-r--r-- 393k root 16 Feb 10:55  iwlwifi-QuZ-a0-hr-b0-50.ucode.xz
.rw-r--r-- 446k root 16 Feb 10:55  iwlwifi-QuZ-a0-hr-b0-59.ucode.xz
.rw-r--r-- 459k root 16 Feb 10:55  iwlwifi-QuZ-a0-hr-b0-66.ucode.xz
.rw-r--r-- 468k root 16 Feb 10:55  iwlwifi-QuZ-a0-hr-b0-72.ucode.xz
.rw-r--r-- 470k root 16 Feb 10:55  iwlwifi-QuZ-a0-hr-b0-73.ucode.xz
.rw-r--r-- 475k root 16 Feb 10:55  iwlwifi-QuZ-a0-hr-b0-74.ucode.xz
.rw-r--r-- 482k root 16 Feb 10:55  iwlwifi-QuZ-a0-hr-b0-77.ucode.xz
.rw-r--r-- 376k root 16 Feb 10:55  iwlwifi-QuZ-a0-jf-b0-50.ucode.xz
.rw-r--r-- 423k root 16 Feb 10:55  iwlwifi-QuZ-a0-jf-b0-59.ucode.xz
.rw-r--r-- 430k root 16 Feb 10:55  iwlwifi-QuZ-a0-jf-b0-66.ucode.xz
.rw-r--r-- 437k root 16 Feb 10:55  iwlwifi-QuZ-a0-jf-b0-72.ucode.xz
.rw-r--r-- 438k root 16 Feb 10:55  iwlwifi-QuZ-a0-jf-b0-73.ucode.xz
.rw-r--r-- 443k root 16 Feb 10:55  iwlwifi-QuZ-a0-jf-b0-74.ucode.xz
.rw-r--r-- 449k root 16 Feb 10:55  iwlwifi-QuZ-a0-jf-b0-77.ucode.xz
.rw-r--r-- 514k root 16 Feb 10:55  iwlwifi-so-a0-gf-a0-72.ucode.xz
.rw-r--r-- 514k root 16 Feb 10:55  iwlwifi-so-a0-gf-a0-73.ucode.xz
.rw-r--r-- 524k root 16 Feb 10:55  iwlwifi-so-a0-gf-a0-74.ucode.xz
.rw-r--r-- 534k root 16 Feb 10:55  iwlwifi-so-a0-gf-a0-77.ucode.xz
.rw-r--r-- 538k root 16 Feb 10:55  iwlwifi-so-a0-gf-a0-78.ucode.xz
.rw-r--r-- 538k root 16 Feb 10:55  iwlwifi-so-a0-gf-a0-79.ucode.xz
.rw-r--r-- 5.5k root 16 Feb 10:55  iwlwifi-so-a0-gf-a0.pnvm.xz
.rw-r--r-- 520k root 16 Feb 10:55  iwlwifi-so-a0-gf4-a0-72.ucode.xz
.rw-r--r-- 522k root 16 Feb 10:55  iwlwifi-so-a0-gf4-a0-73.ucode.xz
.rw-r--r-- 531k root 16 Feb 10:55  iwlwifi-so-a0-gf4-a0-74.ucode.xz
.rw-r--r-- 542k root 16 Feb 10:55  iwlwifi-so-a0-gf4-a0-77.ucode.xz
.rw-r--r-- 545k root 16 Feb 10:55  iwlwifi-so-a0-gf4-a0-78.ucode.xz
.rw-r--r-- 545k root 16 Feb 10:55  iwlwifi-so-a0-gf4-a0-79.ucode.xz
.rw-r--r-- 4.1k root 16 Feb 10:55  iwlwifi-so-a0-gf4-a0.pnvm.xz
.rw-r--r-- 483k root 16 Feb 10:55  iwlwifi-so-a0-hr-b0-72.ucode.xz
.rw-r--r-- 485k root 16 Feb 10:55  iwlwifi-so-a0-hr-b0-73.ucode.xz
.rw-r--r-- 494k root 16 Feb 10:55  iwlwifi-so-a0-hr-b0-74.ucode.xz
.rw-r--r-- 495k root 16 Feb 10:55  iwlwifi-so-a0-hr-b0-77.ucode.xz
.rw-r--r-- 497k root 16 Feb 10:55  iwlwifi-so-a0-hr-b0-79.ucode.xz
.rw-r--r-- 452k root 16 Feb 10:55  iwlwifi-so-a0-jf-b0-72.ucode.xz
.rw-r--r-- 453k root 16 Feb 10:55  iwlwifi-so-a0-jf-b0-73.ucode.xz
.rw-r--r-- 461k root 16 Feb 10:55  iwlwifi-so-a0-jf-b0-74.ucode.xz
.rw-r--r-- 461k root 16 Feb 10:55  iwlwifi-so-a0-jf-b0-77.ucode.xz
.rw-r--r-- 469k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-59.ucode.xz
.rw-r--r-- 496k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-66.ucode.xz
.rw-r--r-- 505k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-72.ucode.xz
.rw-r--r-- 507k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-73.ucode.xz
.rw-r--r-- 522k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-74.ucode.xz
.rw-r--r-- 529k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-77.ucode.xz
.rw-r--r-- 533k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-78.ucode.xz
.rw-r--r-- 533k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0-79.ucode.xz
.rw-r--r-- 5.8k root 16 Feb 10:55  iwlwifi-ty-a0-gf-a0.pnvm.xz
All of the relevant versions of iwlwifi available exist in my firmware library, however they're all compressed files. Similarly, if I search my relevant kernel directory I find that the relevant driver file is also a compressed archive file:
ls /usr/lib/modules/6.2.0-1-mainline/kernel/drivers/net/wireless/intel/iwlwifi/
drwxr-xr-x    - root 22 Feb 11:30  dvm
drwxr-xr-x    - root 22 Feb 11:30  mvm
.rw-r--r-- 329k root 20 Feb 05:18  iwlwifi.ko.zst
Is this related to my original network unclaimed error, or is this some naivety on my part? I can't reconcile the presence of the relevant drivers in both places, yet the output of lspci -vkn indicates that there is no driver in use for the wireless card:
00:14.3 0280: 8086:9df0 (rev 30)
DeviceName: WLAN
Subsystem: 8086:0000
Any suggestions for new paths toward a solution? Since I have managed to achieve wifi access though a third party external adapter, the issue is less pressing than originally, but I do want to find a solution since this seems to be a fairly common problem.
