No Man's Sky via Steam Freeze then Crash
Hello All,
I am new to Garuda and am loving it. I switched from Windows months ago all is well except my Game No Man’s Sky occasionally freezes (Once or Twice a day or rarely not at all) with sound and then closes after a minute. It happens willy-nilly as far as I can tell.
So far I have tried switching Proton’s via Steam, and kernels in terminal (it did things and completed) as one post I found said not using zen worked for someone that had kinda the same issue alas today it froze again. the Journal errors report is a bit different today but I do see QML, sleep, hda and hub issues and seem to be the constant.
```text
Aug 10 18:17:19 VF-1 kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 10 18:17:24 VF-1 systemd-udevd[565]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Aug 10 18:17:24 VF-1 kernel: snd_hda_intel 0000:12:00.6: no codecs found!
Aug 10 18:17:26 VF-1 (udev-worker)[609]: card0: /usr/lib/udev/rules.d/30-amdgpu-pm.rules:3 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.0/simple-framebuffer.0/drm/card0/device/power_dpm_state}="performance", ignoring: No such file or directory
Aug 10 18:17:38 VF-1 plasmashell[4856]: aurorae: Couldn't find QML Decoration  ""
Aug 10 18:17:39 VF-1 org_kde_powerdevil[4913]: busno=7, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 10 18:17:39 VF-1 org_kde_powerdevil[4913]: Turning off dynamic sleep and retrying
Aug 10 18:17:39 VF-1 org_kde_powerdevil[4913]: busno=8, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 10 18:17:40 VF-1 org_kde_powerdevil[4913]: busno=8, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
Aug 10 18:17:40 VF-1 org_kde_powerdevil[4913]: busno=7, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
Any idea’s or direction to go where I can track this bug down would be great if not the solution. I’m not sure if its actually the Kernel or hda (a drive?) or what :slight_smile: but just looking for ppl with same problem or browsing for lines I see in the Journal error log hasn’t yield great results for me as of yet. Thanks
```text
  Kernel: 6.10.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    root=UUID=fac7d830-11b1-4713-a692-77e449b6d8d7 rw rootflags=subvol=@ quiet
    resume=UUID=2b2f9cd7-273f-48e3-849a-4ff339b45f2f loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0 wm: kwin_wayland vt: 1
  Type: Desktop System: Micro-Star product: MS-7D75 v: 1.0 serial: <superuser required>
  Mobo: Micro-Star model: MAG B650 TOMAHAWK WIFI (MS-7D75) v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.50 date: 03/24/2023
  Device-1: ps-controller-battery-ac:36:1b:04:a2:0b model: N/A serial: N/A charge: N/A status: full
  Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check
    built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x61 (97) stepping: 2
    microcode: 0xA601203
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3054 high: 5500 min/max: 400/5573 scaling: driver: amd-pstate-epp
    governor: performance cores: 1: 4397 2: 5500 3: 4386 4: 4491 5: 400 6: 4393 7: 4390 8: 4391
    9: 400 10: 5452 11: 400 12: 4670 13: 400 14: 400 15: 400 16: 4400 bogomips: 143997
  Device-1: AMD Navi 33 [Radeon RX 7600/7600 XT/7600M XT/7600S/7700S / PRO W7600]
    vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3 code: Navi-33 built: 2023+ pcie:
    gen: 4 speed: 16 GT/s lanes: 8 ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3,Writeback-1
    bus-ID: 03:00.0 chip-ID: 1002:7480 class-ID: 0300
  Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2
    code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: none empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-2 bus-ID: 12:00.0 chip-ID: 1002:164e
    class-ID: 0300 temp: 43.0 C
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2 compositor: kwin_wayland
    gpu: amdgpu,amdgpu d-rect: 5760x1080 display-ID: 0
  Monitor-1: DP-1 pos: center res: 1920x1080 size: N/A modes: N/A
  Monitor-2: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
  Monitor-3: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1
    drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.5-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 7600 (radeonsi navi33 LLVM 18.1.8 DRM 3.57
    6.10.3-zen1-2-zen) device-ID: 1002:7480 memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD Radeon RX 7600 (RADV
    NAVI33) driver: mesa radv v: 24.1.5-arch1.1 device-ID: 1002:7480 surfaces: xcb,xlib,wayland
    device: 1 type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 24.1.5-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib,wayland device: 2
    type: cpu name: llvmpipe (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.5-arch1.1 (LLVM
    18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
  Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1
    chip-ID: 1002:1640 class-ID
: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Sony DualSense wireless controller (PS5) driver: playstation,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.4:4 chip-ID: 054c:0ce6
  Device-5: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0db0:422d class-ID: 0300
  API: ALSA v: k6.10.3-zen1-2-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
  Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0e:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp14s0 state: down mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter driver: mt7921e
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp15s0 state: up mac: <filter>
  Device-3: Sony DualSense wireless controller (PS5) driver: playstation,snd-usb-audio,usbhid
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status:
  Local Storage: total: 1.82 TiB used: 870.93 GiB (46.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
    fw-rev: 5B2QGXA7 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 870.93 GiB (47.2%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 870.93 GiB (47.2%) fs: btrfs
  ID-4: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 870.93 GiB (47.2%) fs: btrfs
  ID-5: /var/tmp raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 870.93 GiB (47.2%) fs: btrfs
  ID-1: swap-1 type: zram size: 14.78 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 16.26 GiB used: 0 KiB (0.0%) priority: -2
  System Temperatures: cpu: 59.1 C mobo: 36.0 C
  GPU: device: amdgpu temp: 50.0 C mem: 67.0 C fan: 57 watts: 18.00 device: amdgpu temp: 44.0 C
  Memory: total: 16 GiB note: est. available: 14.78 GiB used: 3.07 GiB (20.8%)
  Processes: 398 Power: uptime: 0m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 5.9 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 2005 libs: 582 tools: octopi,pamac,paru Compilers: clang: 18.1.8
    gcc: 14.2.1 Client: shell wrapper v: 5.2.32-release inxi: 3.3.35
  System install date:     2023
-12-19
  Last full system update: 2024-08-09
You say you have tried switching protons have you tried downloading Proton Tkg, instead of Proton GE? You can use protonup-qt for that, just select Proton Tkg and begin downloading what version of that you want.
i found that many of my games which had problems with proton or proton GE’s, worked completely perfect running Proton-Tkg, tho at times it took a little searching for the right version.
(Don’t forget you will have to reload Steam after you download a new proton)
First thank you for ur reply post.
I have not tried Proton Tkg. Its not in steam so i am unfamiliar with it. That will be tomorrows excursion event i suppose. To research what where and how. I may be back :slight_smile:
Also if you haven’t yet - check on protondb to see if there’s any hints from other people.
As @fbodymechanic mentioned, you can find details on running games on Protondb. No Mans Sky has a Gold rating, so it should run pretty well.
I have checked protondb :+1: and did try a few things but still the crashes persist. I was hoping someone could decipher my crash report to give further clues.
Thank you for the reply, yes I have and yes it does run well until it doesn’t. I’m hoping someone could look at the crash report and give further direction if the report even has good info. Like should I do more with my kernel or stick with proton route. I just looked a bit into Proton tkg and that looks like a sort of experimental thing. I have to learn how to deploy it tho, I have no idea atm
Your wrote;
“I have to learn how to deploy it tho, I have no idea atm”
sudo pacman -S protonup-qt
then open your file manager
make sure hidden directories are visible (ctrl h)
select the ‘.steam’ directory.
and then again;
steam (folder)
and then right click and make a new folder called “compatibilitytoolsd”, if it does not exists yet. (without the quotations marks)
close file manager
Now open your panel’s main menu
type proton
select protonup-qt
(right at left top)
under 'Install for:
change the path to
$HOME"/.steam/steam/compatibilitytoolsd/"
then press Add version more towards the left bottom of the app.
It will display proton GE as default
press it and select proton Tkg
(it will give you the latest version as default.)
Download some, restart Steam, if you have it running, and select the game you want to run in proton, right click, select properties, and then compatibility mode, and the protons-tkg you downloaded, will be available to your games now. Experiment at will.
Cheers.
Okay first that was top notch dummy proof instructions and I thank you for that :slight_smile: 2nd it seemed to work really well I was able to actually scan planets easier and everything seemed to run smoother. Bit i noticed almost right away there were no other ppl about. Somehow even tho multiplayer was on it didn’t seem active.
So since it was doing well and didn’t crash i took it for a test that always crashed eventually which was taking an exocraft out around the planet to farm some things. jumping in and out of the exocraft usually crashes the game after a while and just as I was about to call it a win the game crashed :weary: I will try and attach my Journal error.
```text
Aug 13 19:31:10 VF-1 kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 13 19:31:15 VF-1 systemd-udevd[576]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Aug 13 19:31:15 VF-1 kernel: snd_hda_intel 0000:12:00.6: no codecs found!
Aug 13 19:31:17 VF-1 (udev-worker)[620]: card0: /usr/lib/udev/rules.d/30-amdgpu-pm.rules:3 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.0/simple-framebuffer.0/drm/card0/device/power_dpm_state}="performance", ignoring: No such file or directory
Aug 13 19:31:35 VF-1 plasmashell[4865]: aurorae: Couldn't find QML Decoration  ""
Aug 13 19:31:37 VF-1 org_kde_powerdevil[4926]: busno=8, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 13 19:31:37 VF-1 org_kde_powerdevil[4926]: Turning off dynamic sleep and retrying
Aug 13 19:31:37 VF-1 org_kde_powerdevil[4926]: busno=7, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 13 19:31:37 VF-1 org_kde_powerdevil[4926]: busno=7, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
Aug 13 19:31:37 VF-1 org_kde_powerdevil[4926]: busno=8, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
Okay, so i’ve saw there was some Argyll fail which has to do with graphics if i remember right. So i was going to use amdgpu_top to watch the card but not sure yet if i can with Garuda. Some other post also said his card he found was no entirely supported in linux it froze when hitting 500Mz but his was a amd 5XXX mine is 7600. So in the mean time i decided to check crash report after boot and after crash. maybe someone that’s keen in reading these can see the a problem that can be fixed.
```text
**Errors after boot**
Aug 14 18:53:43 VF-1 kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 14 18:53:48 VF-1 systemd-udevd[573]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Aug 14 18:53:48 VF-1 kernel: snd_hda_intel 0000:12:00.6: no codecs found!
Aug 14 18:53:50 VF-1 (udev-worker)[614]: card0: /usr/lib/udev/rules.d/30-amdgpu-pm.rules:3 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.0/simple-framebuffer.0/drm/card0/device/power_dpm_state}="performance", ignoring: No such file or directory
Aug 14 18:54:17 VF-1 plasmashell[7259]: aurorae: Couldn't find QML Decoration ""
Aug 14 18:54:19 VF-1 org_kde_powerdevil[7323]: busno=8, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 14 18:54:19 VF-1 org_kde_powerdevil[7323]: Turning off dynamic sleep and retrying
Aug 14 18:54:19 VF-1 org_kde_powerdevil[7323]: busno=7, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 14 18:54:19 VF-1 org_kde_powerdevil[7323]: busno=8, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
Aug 14 18:54:19 VF-1 org_kde_powerdevil[7323]: busno=7, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
and then
```text
**Errors after crash**
Aug 14 22:27:48 VF-1 kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 14 22:27:53 VF-1 systemd-udevd[569]: /usr/lib/udev/rules.d/55-Argyll.rules:158 Unknown group 'colord', ignoring.
Aug 14 22:27:53 VF-1 kernel: snd_hda_intel 0000:12:00.6: no codecs found!
Aug 14 22:27:55 VF-1 kernel: amdgpu 0000:03:00.0: [drm] *ERROR* No EDID read.
Aug 14 22:27:55 VF-1 (udev-worker)[613]: card0: /usr/lib/udev/rules.d/30-amdgpu-pm.rules:3 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.0/simple-framebuffer.0/drm/card0/device/power_dpm_state}="performance", ignoring: No such file or directory
Aug 14 22:28:24 VF-1 plasmashell[7234]: aurorae: Couldn't find QML Decoration ""
Aug 14 22:28:25 VF-1 org_kde_powerdevil[7293]: busno=7, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 14 22:28:25 VF-1 org_kde_powerdevil[7293]: Turning off dynamic sleep and retrying
Aug 14 22:28:25 VF-1 org_kde_powerdevil[7293]: busno=8, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Aug 14 22:28:25 VF-1 org_kde_powerdevil[7293]: busno=8, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
Aug 14 22:28:26 VF-1 org_kde_powerdevil[7293]: busno=7, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_REPORTED_UNSUPPORTED in ddc_get_nontable_vcp_value]
Aug 14 22:28:32 VF-1 (sd-pam)[3692]: pam_systemd(systemd-user:session): Failed to release session: Caller does not belong to any known session.
idk if nothing is found then maybe its just the game but I refuse to think there is nothing I can do lol
I know may be a random idea but some games I have trouble with and found they run fine on flat pack steam. You can run it alongside normal steam. Try installing that and installing another copy of no man’s sky and see how it goes.
I’ll try this thank you I appreciate the information. I did not even know what a flat pack was till you mentioned it. I also found that garuda has a pretty good overlay called Goverlay which i needed so i could make sure my GPU was on the up and up during a crash or at least what the stats were. Learning a lot in a few days via everyone’s input. :+1:
Okay so I haven’t installed flat pack yet but as I said I got goverlay up and running which shoes that my Junction Metric gets up to 110 c while my gpu and vram nvr gets over 7* c also I run three monitors and had the game running on my second which is the exact same type as monitor one. So i unplugged all but main and it made things worse so I plugged them back in and ran the game on monitor one and using proton 8 again I haven’t crashed yet… Using Goverlay I watch my temp and the GPU MHz and if either get to crazy i just slow down what i’m doing in game for a few seconds. IDK what the exact issue is but since i’m only having problems with No Man’s Sky at the moment I’m going to assume its the game and its taxation on my system and maybe Wayland and the three monitors but i have doubts on that one. Idk, I’ll continue to work on it and work the flat pack in later on just cause that seems like a neat thing.
