Hi everyone, since yesterday I noticed that Garuda does not connect to the network (usually via cable but it does not connect via wifi either).
I turn it off and on again and it works.
After another reboot it does not work and I have to reboot again.
What additional information should I give you?
Thanks guys
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=671de9f9-8ee6-4c92-a404-549bf7935a22 rw rootflags=subvol=@
quiet loglevel=3 nvidia_drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5013 date: 03/22/2024
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102B
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2213 high: 2414 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2414 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 121608
Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: ZOTAC driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 0a:00.0
chip-ID: 10de:2782 class-ID: 0300
Device-2: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
chip-ID: 0c45:8006 class-ID: 0301
Device-3: Sunplus Innovation Aukey-PC-LM1E Camera
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-1:2 chip-ID: 1bcf:0215 class-ID: 0102
d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-1 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: nvidia v: 555.58.02 device-ID: 10de:2782
18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8)
Device-1: NVIDIA AD104 High Definition Audio vendor: ZOTAC
bus-ID: 0a:00.1 chip-ID: 10de:22bc class-ID: 0403
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 10.01 TiB used: 385.28 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Smart Modular Tech.
model: SHPP41-1000GM size: 931.51 GiB block-size: physical: 512 B
fw-rev: 51060A20 temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.2 temp: 27.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EFRX-68WT0N0 size: 3.64 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
used: 385.28 GiB (41.4%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
System Temperatures: cpu: 48.9 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 4.66 GiB (14.9%)
Processes: 392 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: 1792 pm: dpkg pkgs: 0 pm: pacman pkgs: 1786 libs: 455
tools: octopi,paru,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 6 Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-01-21
Last full system update: 2024-07-27
Failed units: samba.service
