Kernel: 5.19.2-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=c5c8b0e5-c2c7-47a3-9951-9e91c4bc9404 rw rootflags=subvol=@
resume=UUID=c299ee24-e17d-46a1-9481-abf64483268e loglevel=3
Type: Desktop System: Gigabyte product: X470 AORUS ULTRA GAMING v: N/A
Mobo: Gigabyte model: X470 AORUS ULTRA GAMING-CF v: x.x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F51g
date: 07/02/2020
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 built: 2019 process: GF 12nm
family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 bogomips: 28800
Type: retbleed mitigation: untrained return thunk; SMT disabled
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: none bus-ID: 0a:00.0 chip-ID: 1002:15d8
s-diag: 414mm (16.31")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung built: 2014
res: 1366x768 hz: 60 dpi: 57 gamma: 1.2 size: 609x347mm (23.98x13.66")
diag: 701mm (27.6") ratio: 16:9 modes: max: 1366x768 min: 720x400
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.47
5.19.2-zen1-2-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: N/A
alternate: snd_hda_intel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0a:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte driver: N/A
bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.19.2-zen1-2-zen running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
chip-ID: 10ec:8179 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
Local Storage: total: 2.25 TiB used: 13.63 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-GSM2NE3256GNTD size: 238.47 GiB block-size: physical: 512 B
rev: EDFM00.7 temp: 34.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
model: WD800JD-55JRA0 size: 74.53 GiB block-size: physical: 512 B
logical: 512 B speed: 1.5 Gb/s type: N/A serial: <filter> rev: 1C05
ID-4: /dev/sdc maj-min: 8:32 vendor: Patriot model: Burst
type: SSD serial: <filter> rev: 61.3 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 14.44 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 13.63 GiB
(5.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 13.63
GiB (5.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /var/log raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 13.63
ID-4: /var/tmp raw-size: 229.67 GiB size: 229.67 GiB (100.00%) used: 13.63
ID-1: swap-1 type: zram size: 5.73 GiB used: 3 MiB (0.1%) priority: 100
System Temperatures: cpu: 43.2 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 236 Uptime: 2h 10m wakeups: 0 Memory: 5.73 GiB used: 2.85 GiB
(49.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1342 lib: 351 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-08-31
Last full system update: 2022-08-31 â»
I have a problem with audio i get red speaker icon with a minus in front of it I've searched the forum and found similar problems but i couldn't resolve it am not an advanced linux user just getting started . I don't have any speakers i have a tv screen with speakers connected on the motherboards hdmi port since i don't have a gpu and until resently i had audio after an update and an error about conflicted dependences pipewire and pulseaudio i started having this problem today i reinstalled garuda but i still get the same error
