Hi have gabs whit rounded corners .
I can't get gabs when 1 window is open ?
What can i do to have also gabs when i single window is open ?
Please follow the template and try searching...
It's likely the smart_gaps on in the config.
i3-gaps doesn’t apply to one window - Unix & Linux Stack Exchange
i3: i3 User’s Guide
edit: ah, no template because in "garuda community", this should have been in "issues and assistance".
Moved!
And, yes, garuda-inxi is required!
I see gaps come from i3-gaps, now embedded into i3wm, so this might be still applicable
Smart borders will draw borders on windows only if there is more than one window in a workspace.
Also in the official i3 guide:
https://i3wm.org/docs/userguide.html#_smart_borders
Thanks for the information , i solved it ![]()
