Hi Everyone , i have been trying to switch to linux for the past few days and so far garuda seems to be the best out there but , with almost all the distros i tested only a few had HDMI audio , in fact any arch based distro i install doesnt have any HDMI audio for some reason , the ones that had audio are ubuntu and zorin os which was based on debian. i also tested out KDE Neon at first i had audio then ,after GPU driver install the audio option no longer exists , so i cant seem to find anything in common between thse distros . so i figured you guys know best.
Some basics .
1- i used pulse audio control and HDMI shows as unplugged or unavailable as if it doesnt exist
2- HDMI video works perfectly
3- on some distros uninstalling Nvidia Drivers did not fix it (OpenSUSE)
4-on KDE Neo i had to upgrade kernel to 5.8 to get audio back but lost it again after Nvidia Drivers
hope any of that information helps
My System
Razer Blade 15 2018
with GTX 1060
16GB Memory
Intel I7-8750H
Running Garuda Dragonized KDE gaming Edition
the rest can be found here
System: Kernel: 5.12.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d02cf9f0-de45-4f4f-a77e-8bfcb0ef5408
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Razer product: Blade v: 1.05 serial: <filter> Chassis: type: 10
Mobo: Razer model: C1_MB serial: <filter> UEFI: Razer v: 1.06 date: 09/05/2018
Battery: ID-1: BAT0 charge: 69.6 Wh (99.3%) condition: 70.1/80.2 Wh (87.4%) volts: 17.3 min: 15.4
model: Razer Blade type: Unknown serial: <filter> status: Unknown
CPU: Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: DE cache: L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 52799
Speed: 4001 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4001 2: 3983 3: 4000 4: 4000
5: 4000 6: 3999 7: 4000 8: 4000 9: 4000 10: 4002 11: 3578 12: 4000
Graphics: Device-1: Intel UHD Graphics 630 vendor: Razer USA driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Razer USA driver: nvidia v: 465.31
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0300
Device-3: Sunplus Innovation USB Camera type: USB driver: uvcvideo bus-ID: 1-7:5
chip-ID: 1bcf:2c9a class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 30 size: 1600x900mm (63.0x35.4")
diag: 1836mm (72.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.1 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: Licensed by Sony Entertainment America Wireless Stereo Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:7 chip-ID: 12ba:0050 class-ID: 0300
Sound Server-1: ALSA v: k5.12.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000 bus-ID: 02:00.0
Bluetooth: Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-5:4
Drives: Local Storage: total: 476.94 GiB used: 25.24 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: EXA7301Q scheme: GPT
Partition: ID-1: / raw-size: 97.17 GiB size: 97.17 GiB (100.00%) used: 25.24 GiB (26.0%) fs: btrfs
ID-2: /boot/efi raw-size: 501.3 MiB size: 500.3 MiB (99.80%) used: 560 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 97.17 GiB size: 97.17 GiB (100.00%) used: 25.24 GiB (26.0%) fs: btrfs
ID-4: /var/log raw-size: 97.17 GiB size: 97.17 GiB (100.00%) used: 25.24 GiB (26.0%) fs: btrfs
ID-5: /var/tmp raw-size: 97.17 GiB size: 97.17 GiB (100.00%) used: 25.24 GiB (26.0%) fs: btrfs
ID-1: swap-1 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 48.0 C mobo: N/A
Info: Processes: 301 Uptime: 5m wakeups: 1 Memory: 15.53 GiB used: 3.16 GiB (20.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1658 lib: 509
Shell: fish v: 3.2.2 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
