Hello
I'm currently trying to follow this tutorial with little luck. My aim is to get the touchbar on the macbook pro from 1027 to be at least functional. I've gotten to the part with telling me to put
cat <<EOF | sudo tee -a /etc/initramfs-tools/modules
# drivers for keyboard+touchpad
applespi
apple-ib-tb
intel_lpss_pci
spi_pxa2xx_platform
EOF
in my terminal. at first I got the "Expected a string, but instead found a redirection" response from fish, I fixed it by changing the shell to bash. After this, I learned there wasn't even a /etc/initramfs-tools/modules directory, at least, not where I was looking. is the initramfs-tools/modules directory somewhere else, or is there another place I should put the names of these drivers?
My inxi from bash terminal in garuda:
Kernel: 5.16.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c3207fed-eb6b-4d0d-8114-915493c66c41 rw rootflags=subvol=@
Type: Laptop System: Apple product: MacBookPro14,3 v: 1.0 serial: <filter>
Chassis: type: 9 v: Mac-551B86E5744E2388 serial: <filter>
Mobo: Apple model: Mac-551B86E5744E2388 v: MacBookPro14,3
serial: <filter> UEFI: Apple v: 447.80.3.0.0 date: 12/12/2021
ID-1: BAT0 charge: 61.7 Wh (97.3%) condition: 63.4/76.7 Wh (82.7%)
volts: 12.9 min: 11.5 model: SMP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 234
Info: model: Intel Core i7-7700HQ socket: U3E1 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3621 high: 3801 min/max: 800/3800 base/boost: 2700/2800
scaling: driver: intel_pstate governor: powersave volts: 0.9 V
ext-clock: 25 MHz cores: 1: 3591 2: 3704 3: 3552 4: 3540 5: 3586 6: 3600
7: 3601 8: 3801 bogomips: 44798
Type: l1tf
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X]
vendor: Apple driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 01:00.0
chip-ID: 1002:67ef class-ID: 0300
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.0x18.7")
s-diag: 898mm (35.4")
Monitor-1: eDP res: 2880x1800 hz: 60 dpi: 221 size: 331x207mm (13.0x8.1")
diag: 390mm (15.4")
OpenGL: renderer: AMD Radeon RX Graphics (POLARIS11 DRM 3.44.0
5.16.16-zen1-1-zen LLVM 13.0.1)
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-2: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
type: USB driver: rtl88XXau bus-ID: 1-7:3 chip-ID: 0bda:8812 class-ID: 0000
IF: wlp0s20f0u7 state: up mac: <filter>
Local Storage: total: 233.76 GiB used: 30.19 GiB (12.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD SM0256L
size: 233.76 GiB block-size: physical: 4096 B logical: 4096 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: CXS5EA0Q
temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 19d 19h cycles: 60,441
read-units: 45,704,539 [23.4 TB] written-units: 45,553,120 [23.3 TB]
ID-1: / raw-size: 37.6 GiB size: 37.6 GiB (100.00%) used: 30.19 GiB (80.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 300.4 MiB size: 299.5 MiB (99.72%)
used: 1.5 MiB (0.5%) fs: vfat block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-3: /home raw-size: 37.6 GiB size: 37.6 GiB (100.00%)
used: 30.19 GiB (80.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 37.6 GiB size: 37.6 GiB (100.00%)
maj-min: 259:4
ID-5: /var/tmp raw-size: 37.6 GiB size: 37.6 GiB (100.00%)
maj-min: 259:4
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 66.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
Processes: 308 Uptime: 2m wakeups: 2 Memory: 15.52 GiB
used: 2.11 GiB (13.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: note: see --pkg pacman: 2136 lib: 408
inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-11
Last full system update: 2022-03-22
edit: fixed garuda-inxi
