guys, I have an issue with my laptop whenever I plug earphones into the laptop no entry icon starts flashing I found that this is conflicting with my play/pause button it will automatically play/pause the video song it is irritating this thing happening in every Linux distro please please do help me whenever i tried to code it lags because of this no entry icon
Please provide the output of garuda-inxi
as requested in the forum template.
It would also be helpful to have more information in general. Do you know what brand/model the earphones are? How do they connect to the laptop (3.5mm jack, USB-C, USB-A, etc)? Is audio working with other devices, for example the native laptop speakers?
Kernel: 5.19.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1ebf5c6d-bfe3-4a75-b912-4f293c2f7dc3 rw rootflags=subvol=@
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: LENOVO product: 80XH v: Lenovo ideapad 320-15ISK
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 320-15ISK
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 4WCN47WW date: 06/30/2020
ID-1: BAT0 charge: 10.4 Wh (97.2%) condition: 10.7/35.0 Wh (30.5%)
volts: 8.3 min: 7.6 model: LGC L16L2PB3 type: Li-poly serial: <filter>
status: not charging
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x4E (78)
stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 500 min/max: 400/2000 scaling: driver: intel_pstate
governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 15999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 520 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1921 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 920MX] vendor: Lenovo driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-07) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134f class-ID: 0302
Device-3: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:4
chip-ID: 5986:210f class-ID: 0e02
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :1
Monitor-1: eDP-1 model: BOE Display 0x0729 built: 2017 res: 1920x1080
ratio: 16:9 modes: 1920x1080
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.19.4-zen1-1-zen running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
chip-ID: 0cf3:e500 class-ID: e001
address: <filter>
Local Storage: total: 931.51 GiB used: 14.6 GiB (1.6%)
model: WD10SPZX-26Z10T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A04 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 14.6 GiB
(1.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 14.6
GiB (1.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 14.6
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 14.6
ID-1: swap-1 type: zram size: 7.55 GiB used: 36.2 MiB (0.5%)
System Temperatures: cpu: 47.0 C pch: 46.0 C mobo: N/A
Processes: 248 Uptime: 2h 2m wakeups: 1079 Memory: 7.55 GiB used: 2.29 GiB
(30.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1163 lib: 323 Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-28
Last full system update: 2022-08-28 ↻
earphones are from local company and It has 3.5 mm jack audio working fine with speakers this things happens when i connect earphones to laptop (wired earphones/headphones)
gnome - not allowed sign flashing on screen - Ask Ubuntu this is happening with m
I cannot reproduce this on my laptop's Gnome installation. Playing audio works as expected; when plug in headphones with 3.5mm jack the audio comes through the headphones--no "no entry" sign. I tried messing around with the integrated media keys on my laptop's keyboard, but they all work in exactly the way they are intended (play/pause, rewind/ff, etc) and nothing gives me the "no entry" symbol you are getting.
My suspicion would be something about either your headphones or your laptop is causing issues. A quick search for your laptop model and Gnome didn't turn up anything obvious, and so far we don't know anything about the headphones except they are a "local company".
Is there a controller built into your headphones (play, pause, volume, or any kind of buttons)? If so, what is on it?
Do you have another set of headphones you can try, to see if the problem can be reproduced with a different device?
no tried with sony Orignal headphones as well but the same thing happening this is not a gnome issue this is my laptops keyboard issue when I'm using manjaro I also asked the same question on the manjaro forum and developers said it is your keyboard issue and I also tried to repair my laptop in Lenovo store they also said I guess this is a keyboard issue I guess as I have to go with this
BTW can you please tell me visualizer software name in garuda dragnised edition I cant remember I just shifted dragnised to Gnome
