No Display When Using ASUS Geforce GTX 750Ti
Hi,
So I have successfully installed Garuda Dragonized Linux on an old PC.
Onboard Graphics is working fine and I wanted to switch to using my ASUS Geforce 750Ti PCIe card.
When the DVI to HDMI cable is plugged into the Graphics Card and I switch on the PC, I can view the BIOS by pressing DEL. I can select PCIe as the initial display and then boot the PC. I see the initial Garuda Linux Splash screen (in low res).
Then the screen just goes black and I have no display.
Do I need to install any drivers before using this card? And could that be why it is not displaying?
PC Specs:
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZEDGAMING_BIRDOFPR quiet
systemd.show_status=1 checksum=y driver=nonfree nouveau.modeset=0
Type: Desktop Mobo: ASRock model: FM2A75M-DGS serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: P1.60
date: 10/03/2012
Info: model: AMD A6-5400K APU with Radeon HD Graphics bits: 64 type: MT MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 0x12 (18) stepping: 1 microcode: N/A
Topology: cpus: 1x cores: 2 smt: enabled cache: L1: 96 KiB
desc: d-2x16 KiB; i-1x64 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 3600 min/max: 1400/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
bogomips: 14373
Device-1: AMD Trinity 2 [Radeon HD 7540D] vendor: ASRock driver: radeon
v: kernel alternate: amdgpu arch: TeraScale-3 code: Northern Islands
process: TSMC 32nm built: 2010-13 ports: active: DVI-D-1
empty: HDMI-A-1,VGA-1 bus-ID: 00:01.0 chip-ID: 1002:9991 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :0 screens: 1
Monitor-1: DVI-D-1 mapped: DVI-0 model: Samsung S23B550 serial: <filter>
built: 2012 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 x11: drv: r600
inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.0.5-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD ARUBA (DRM 2.50.0 / 6.8.7-zen1-2-zen LLVM
17.0.6) device-ID: 1002:9991 memory: 250 MiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: cpu name: llvmpipe (LLVM
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM 17.0.6)
Device-1: AMD Trinity HDMI Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: SoundGraph iMON PAD Remote Controller driver: imon type: USB
rev: 1.1 speed: 1.5 Mb/s lanes: 1 mode: 1.0 bus-ID: 4-4:3 chip-ID: 15c2:ffdc
class-ID: 0000
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 282.16 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
tech: SSD serial: <filter> fw-rev: 0613 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 speed: <unknown> tech: SSD
serial: <filter> fw-rev: 8.07 scheme: MBR
ID-1: swap-1 type: zram size: 7.47 GiB used: 227.5 MiB (3.0%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2
System Temperatures: cpu: 0.0 C mobo: N/A
Memory: total: 8 GiB note: est. available: 7.47 GiB used: 1.69 GiB (22.7%)
Processes: 157 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.95 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1846 libs: 539 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-11-02
Last full system update: 2024-11-02 ↻
Many thanks
Please, follow the template and post garuda-inxi for the PC specs.
Edited post as requested.
Might wanna try installing the Linux or lts kernel :
Run sudo pacman -S --needed linux linux-headers nvidia-dkms
And reboot. If no shot.
Run sudo pacman -S --needed linux-lts linux-lts-headers nvidia-dkms
And reboot.
If still nothing, then I am afraid I can’t help you at the moment.
Considering that the user already has the zen kernel install. What would be the benefit or I should say how would they fix this when installing the lts kernel? Does this mean that in their case the zen kernel is obsolete and causing the issue directly or that the lts kernel can be used to fallback into when error arise with the zen kernel? Pardon my curiosity, I am learning and wish to understand better in case of the event that I run into such an issue myself.
Probably, but not really certain. Maybe there is an issue with SDDM (Login-in Screen).
Also, your description is not such detailed to clearly understand the real problem.
Do you mean plymouth, or sddm? :man_shrugging:
This is not how such graphic cards changes should be done.
Your report is from the ISO installer, having started in non-free graphics mode, but without nvidia card enabled. I suggest you try this first (enable nvidia only, and boot the installer, selecting non-free). If graphics are successful, it will mean that you can do the same on the installed system, as well. If it fails (black screen), try with the free graphics mode.
If non-free is OK, reboot and go to BIOS, select onboard graphics and boot to your installed system. There, start Garuda Hardware Manager and install the proprietary nvidia drivers (nvidia-dkms IIRC). On success, reboot to BIOS, set nvidia only, boot to the installation.
Sorry for the very short instruction set, but if you have questions, ask and someone will help you.
Well certain kernels behave in different manners and to know which works is simply a matter of trial and error, for me personally, zen up to version 6.2 was great but after that up till 6.6 it became unusable. Rendering issues , system freezes and what not, if it works now for you , great ! If not, then you may try other ones . Since I have removed very Arch based distro on my machine(I only have cellular internet for now and can barely afford updates above 500mb so no rolling release distros), I can’t test newer zen kernels and humbly do not feel the need to do so.
Chances are that if it performs well on your machine then you should be getting some small quality of life benefits from those tweaks present in zen.
Yes, LTS or Linux kernels , regarding that they work in the first place, can be used as a fallback. For now zen may be obsolete for them if this indeed is a kernel related issue, but in the future, they may install a newer zen kernel and give that a try. IMHO, zen is better supported on newer hardware (anything after 2013-2015)
I see, so my assumption was correct. I like zen, it works great for me and I am on Nvidia. I think that petsam is on to something. I would agree that it must possibly have something to do with the driver in use. I am not sure how well the Nvidia drivers are working with his OS since the user an AMD A5-5400K. Might they consider a different driver through the AUR repositories. Like these? I mean, this is what’s most confusing about the topic. User says No Display When Using A Geforce GTX 750TI but inxi reads AMD hardware there is no sight of nvidia in their inxi. In fact, mine is nvidia and it does not have and never has read that it was an AMD hardware when I passed inxi. AMD drivers are at AMDGPU PRO - ArchWiki
Sorry, not sure I follow.
I now have a 6 pin power supply adaptor so that I can power up my PCIe ASUS GTX 750Ti Gfx Adaptor.
I previously ran garuda-inxi with the card not powered up.
With it powered up and PCIe set as primary Gfx Adaptor, I get no display from the onboard Gfx or the PCIe Gfx (I have a monitor that has three Gfx inputs).
Not sure I follow what you mean by selecting Free Graphics.
When booting from the installer, the only options I get are Open Source or Proprietry Nvidia?
Not sure how I managed it, but, with the Gfx card powered on, I have booted using the onboard graphics and here isth readout of garuda-inxi
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cf3875ae-cdb1-4e64-8bf3-54210a4e14d2 rw single
rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
date: 10/03/2012
Info: model: AMD A6-5400K APU with Radeon HD Graphics bits: 64 type: MCP
Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: <unsupported> cache:
L1: 96 KiB desc: d-2x16 KiB; i-1x64 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 1400 min/max: 1400/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
bogomips: 14373
Device-1: Advanced Micro Devices [AMD/ATI] Trinity 2 [Radeon HD 7540D]
vendor: ASRock driver: radeon v: kernel alternate: amdgpu arch: TeraScale-3
code: Northern Islands process: TSMC 32nm built: 2010-13 ports:
active: HDMI-A-3 empty: HDMI-A-2,VGA-2 bus-ID: 00:01.0 chip-ID: 1002:9991
Device-2: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 550.xx+ status: current (as of 2024-09;
EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: DVI-D-1, DVI-D-2, HDMI-A-1, VGA-1
bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300 temp: 23.0 C
compositor: kwin_wayland driver: X: loaded: nouveau,radeon
unloaded: modesetting alternate: fbdev,nv,vesa dri: r600,nouveau
gpu: radeon,nouveau display-ID: 0
Monitor-1: HDMI-A-3 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: amd r600 platforms: device: 0
drv: r600 device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: r600 wayland: drv: r600 x11: drv: r600
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.6-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD ARUBA (DRM 2.50.0 / 6.11.6-zen1-1-zen LLVM
18.1.8) device-ID: 1002:9991 memory: 250 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 13 device: 0 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.6-arch1.1 (LLVM
18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902
Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:0fbc class-ID: 0403
Device-4: SoundGraph iMON PAD Remote Controller driver: imon type: USB
rev: 1.1 speed: 1.5 Mb/s lanes: 1 mode: 1.0 bus-ID: 3-4:2 chip-ID: 15c2:ffdc
class-ID: 0000
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 282.16 GiB used: 23.75 GiB (8.4%)
tech: SSD serial: <filter> fw-rev: 0613 scheme: MBR
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 23.75 GiB (10.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.47 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2 dev: /dev/zram0
System Temperatures: cpu: 2.4 C mobo: N/A
GPU: device: radeon temp: N/A device: nouveau temp: 23.0 C fan: 0 V: 1.01
Memory: total: 8 GiB note: est. available: 7.47 GiB used: 1.23 GiB (16.4%)
Processes: 196 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.96 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1884 libs: 569 tools: octopi,pamac,paru
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.36
Last full system update: 2024-11-03
means
found in
and free driver is
the nouveau driver.
Problem solved?
Unfortunately I can’t explain it better :slight_smile:
I am very new to this, but picking things up as we go.
I have been folling this tutorial on Nvidia Graphics and Linux.
helped me understand what you have just explained.
The GTX Ti750 was using noveau drivers.
I have now installed nvidia-dkms (recommended for zen kernal.
Once I rebooted the fans on the Gfx Card suddeny fired up (which they had not done before). Now from with the onboard graphics unplugged, I get a black screen from the PCIe Gfx Card but with a cursor and mouse pointer that I can move.
I have just tried booting to UEFI using all each of the Gfx Card display outputs and got nothing better.
Just rebooted and when the GFX card drivers kick in the screen flashed white twice and back to a black screen and cursor.
However after rebooting and reselecting PCIe as primary graphics card I now have a display (confirmed by removing the DVI to HDMI cable from the onboard Gfx output on the motherboard.
Issue solved then ? If yes, mark you reply as the solution.
Well regarding getting the Gfx card to work - yes the issue is solved.
Graphics are a little odd though.
When dragging windows left to right its as if they are made of jelly :slight_smile:
I then tried to play a game in Steam and it was too laggy to play.
Don’t think it was a Network issue (but i’ll check).
Nvidia Settings gives virtually no options.
I’ll open another thread on improving performance.
The jelly effect is due to a setting turned on in System settings, it is not a graphical artifact, you can turn it off from the settings.
