I think this is why gpg --recv-key
fails by default:
$ gpg --recv-key 0x04C367C218ADD4FF
gpg: keyserver receive failed: Server indicated a failure
But then I can:
$ gpg --keyserver keyserver.ubuntu.com --recv-key 0x04C367C218ADD4FF
gpg: key 04C367C218ADD4FF: "Benjamin Peterson <[email protected]>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
$ cat ~/.gnupg/gpg.conf
cat: /home/tech/.gnupg/gpg.conf: No such file or directory
Kernel: 5.19.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=1748cca7-e422-4ed9-bd5c-3d12856f8671 rw [email protected]
resume=UUID=dbb7a323-f52a-40d2-8ad1-ca512a750c83 loglevel=3
sysrq_always_enabled=1
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.30 date: 04/14/2021
Info: model: AMD Ryzen 9 3900XT bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4085 high: 4177 min/max: 2200/4776 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4129 2: 3335
3: 4154 4: 4155 5: 4158 6: 4151 7: 4173 8: 4177 9: 4158 10: 4144 11: 4152
12: 4136 13: 4175 14: 4173 15: 4128 16: 4146 17: 4153 18: 4175 19: 4150
20: 3370 21: 4154 22: 4175 23: 4090 24: 4150 bogomips: 182400
protection
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1, DP-2, DP-3, HDMI-A-1 empty: none
bus-ID: 0f:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 046d:085c
alternate: fbdev,vesa gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 7680x2036 s-dpi: 96 s-size: 2026x537mm (79.76x21.14")
s-diag: 2096mm (82.52")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: 2-1 model: Acer G246HL
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-2: DP-2 mapped: DisplayPort-1 pos: primary,1-2 model: LG
(GoldStar) QHD serial: <filter> built: 2021 res: 2560x1440 hz: 144
dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
Monitor-3: DP-3 mapped: DisplayPort-2 pos: 4-4 model: Samsung SyncMaster
serial: <filter> built: 2006 res: 1280x1024 dpi: 86 gamma: 1.2
size: 376x301mm (14.8x11.85") diag: 482mm (19") ratio: 5:4 modes:
max: 1280x1024 min: 720x400
Monitor-4: HDMI-A-1 mapped: HDMI-A-0 pos: 3-3 model: LCD TV built: 2011
res: 1920x1080 hz: 60 dpi: 3048 gamma: 1.2 size: 16x9mm (0.63x0.35")
diag: 6mm (0.2") ratio: 15:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.6 DRM
3.47 5.19.10-zen1-1-zen) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: bus-ID: 3-5:4 gen: 4 chip-ID: 0d8c:013a class-ID: 0300 speed: 16 GT/s
lanes: 16 bus-ID: 0f:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 11:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media USB PnP Sound Device type: USB
Device-4: Logitech C922 Pro Stream Webcam type: USB
Sound Server-1: ALSA v: k5.19.10-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF-ID-1: br-782cbcb8d015 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-4: veth4c02ea6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth73fe64c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: vethe6d881c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: virbr0 state: down mac: <filter>
bus-ID: 3-2:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 2.38 TiB used: 1.79 TiB (75.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 53.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 500GB
type: SSD serial: <filter> rev: DB6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB model: SATA SSD size: 111.79 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.7 TiB (97.3%)
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 570 KiB
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.7 TiB
(97.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.7 TiB
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.7 TiB
ID-1: swap-1 type: zram size: 62.73 GiB used: 10.94 GiB (17.4%)
ID-2: swap-2 type: partition size: 69.07 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 43.0 C mobo: 40.0 C gpu: amdgpu temp: 59.0 C
mem: 58.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1182 fan-3: 0 fan-4: 1640 fan-5: 1248
fan-6: 2191 fan-7: 0 gpu: amdgpu fan: 853
Processes: 743 Uptime: 4d 12h 54m wakeups: 0 Memory: 62.73 GiB used: 24.12
GiB (38.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2883
libs: 620 tools: octopi,pamac,paru pm: flatpak pkgs: 0 Shell: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2021-06-18
Last full system update: 2022-09-27 ↻
Failed units: [email protected]
Maybe this belongs in development? Please move if needed
