Hi I’ve tried Arch with arch install, archcraft, endeavour os and then garuda, all have the same audio problem. After 5 or more reboots I have audio but if I turn of the laptop and boot garuda I have no audio.
Here’s garuda-inxi
Kernel: 6.10.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=dc046905-517d-4890-8e78-438f3081ad6e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: Dell product: Inspiron 15 7000 Gaming v: N/A
Mobo: Dell model: 065C71 v: A00 serial: <superuser required> part-nu: 0798
uuid: <superuser required> UEFI: Dell v: 1.15.0 date: 08/30/2021
ID-1: BAT0 charge: 2.4 Wh (100.0%) condition: 2.4/74.0 Wh (3.3%) volts: 12.6
min: 11.1 model: Samsung SDI DELL 0GFJ67C type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1540 high: 3769 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 3769
5: 3752 6: 800 7: 800 8: 800 bogomips: 44798
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0300
Device-3: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5 chip-ID: 0bda:568a
Monitor-1: eDP-1 res: 1745x982 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 7.56 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 10 device: 0 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 24.2.2-arch1.1
device-ID: 8086:591b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1050 Ti driver: nvidia
v: 560.35.03 device-ID: 10de:1c8c surfaces: xcb,xlib,wayland device: 2
v: 24.2.2-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_soc_avs v: kernel
alternate: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell
API: ALSA v: k6.10.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:3165 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 8087:0a2a
Local Storage: total: 1.15 TiB used: 20.96 GiB (1.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0B-00EPW0
size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0000 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800 size: 953.87 GiB
serial: <filter> fw-rev: 8B scheme: GPT
ID-1: / raw-size: 657.23 GiB size: 657.23 GiB (100.00%)
used: 20.93 GiB (3.2%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
used: 27.4 MiB (28.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 657.23 GiB size: 657.23 GiB (100.00%)
ID-4: /var/log raw-size: 657.23 GiB size: 657.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 657.23 GiB size: 657.23 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C pch: 53.0 C mobo: 45.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB available: 15.49 GiB used: 3.9 GiB (25.2%)
Processes: 253 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1496 libs: 473 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date: 2024-09-13
Last full system update: 2024-09-13
