no matter what i do the audio just will not play on my install, i tried reinstalling but it still doesn't. i went through and searched the arch wikis and they said stuff about drivers that i didn't understand. i tried following their instructions but it didn't work. i just want to be able to use the built in speakers in my laptop and would really appreciate any help, thanks!
garuda-inxi gives:
Kernel: 5.18.15-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=cfcb03a3-a209-484c-a743-5f5e0d1a2c6b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Convertible System: HP product: HP ENVY x360 2-in-1 Laptop 15-ey0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8A31 v: 26.29 serial: <superuser required> UEFI: Insyde
v: F.05 date: 04/07/2022
ID-1: BAT1 charge: 13.3 Wh (25.4%) condition: 52.3/51.0 Wh (102.6%)
volts: 11.1 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Device-1: hid-0018:04F3:402B.0001-battery model: ELAN2513:00 04F3:402B
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1422 high: 1619 min/max: 1600/4547 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1377 2: 1391
3: 1383 4: 1417 5: 1619 6: 1611 7: 1394 8: 1406 9: 1401 10: 1465 11: 1380
12: 1377 13: 1385 14: 1384 15: 1403 16: 1365 bogomips: 63876
STIBP: always-on, RSB filling
Device-1: AMD Barcelo vendor: Hewlett-Packard driver: amdgpu v: kernel
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0
chip-ID: 1002:15e7 class-ID: 0300
Device-2: Chicony HP True Vision 5MP Camera type: USB driver: uvcvideo
bus-ID: 1-4:4 chip-ID: 04f2:b767 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08a8 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.15-zen1-1-zen)
v: 4.6 Mesa 22.1.4 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.15-zen1-1-zen running: yes
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.0
chip-ID: 14c3:0616 class-ID: 0280
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-3:3 chip-ID: 0489:e0e0 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 476.94 GiB used: 9.21 GiB (1.9%)
model: MZVLQ512HBLU-00BH1 size: 476.94 GiB block-size: physical: 512 B
rev: HPS1NFAV temp: 25.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.21 GiB
(1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.21
GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.21
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 9.21
ID-1: swap-1 type: zram size: 11.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 341 Uptime: 31m wakeups: 1182 Memory: 11.03 GiB used: 2.63 GiB
(23.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.0 Packages: pacman: 1207 lib: 305 Shell: fish v: 3.5.1
Garuda (2.6.5-1):
System install date: 2022-07-31
Last full system update: 2022-07-31
Is partially upgraded: Yes
