Get no audio in games after this update
Kernel: 5.18.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw [email protected]
sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.86 date: 01/27/2022
status: full
Device-2: ps-controller-battery-4c:b9:9b:1b:68:38 model: N/A serial: N/A
charge: N/A status: discharging
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 4041 high: 4084 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4078 2: 4073
3: 4081 4: 3967 5: 4080 6: 3950 7: 4078 8: 4084 9: 4083 10: 3992 11: 4083
12: 3946 bogomips: 86403
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA 2
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2
bus-ID: 0f:00.0 chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositors: 1: kwin_wayland 2: Gamescope driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
d-rect: 5888x2160 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 2048x864 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 3840x2160 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 13.0.1 DRM
3.46 5.18.8-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0f:00.1 chip-ID: 1002:ab28
Sound Server-1: ALSA v: k5.18.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.53 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-8:4 chip-ID: 7392:c611 class-ID: e001 serial: <filter>
Local Storage: total: 2.96 TiB used: 3.08 TiB (104.1%)
model: SSD 970 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXE7 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
used: 807.13 GiB (86.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
used: 16.3 MiB (5.5%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-1: swap-1 type: zram size: 31.27 GiB used: 11.8 MiB (0.0%)
System Temperatures: cpu: 51.4 C mobo: 39.0 C gpu: amdgpu temp: 67.0 C
mem: 58.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1991 fan-3: 0 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 2967
Power: 12v: N/A 5v: N/A 3.3v: 3.18 vbat: 3.28 gpu: amdgpu watts: 144.00
Processes: 445 Uptime: 1h 31m wakeups: 4 Memory: 31.27 GiB
used: 16.72 GiB (53.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 2422
pacman: 2404 lib: 590 flatpak: 18 Shell: fish v: 3.4.1 default: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-05-22
Last full system update: 2022-07-02
how can I switch back? I get this
:: pipewire-media-session and wireplumber are in conflict. Remove wireplumber? [y/N] y
:: removing wireplumber breaks dependency 'wireplumber' required by pipewire-alsa
:: removing wireplumber breaks dependency 'wireplumber' required by pipewire-jack
:: removing wireplumber breaks dependency 'wireplumber' required by pipewire-pulse
