I was here on a Discord call, and suddenly I stopped hearing my friend on a call. I tried reconnecting the headset to the laptop, restarting pipewire, connecting another headset, and finally, booting on Windows. The same issue was happening on Windows. When I connect the headset to the laptop, nothing happens, it doesn’t seem it detects the new connected device.
Another strange thing, I can’t hear any audio from the laptop speakers, and it seems the laptop speakers is also not being recognized by the system, because I don’t see any option to select the speakers anymore.
I’m not sure if my audio card is broken or not. I don’t know how to investigate this issue.
After testing a bunch of things, I realized that although the headset does not produce sound when connected directly to the headphone jack of my laptop, when I connect the headset on my ultrawide screen monitor (which is connected to the laptop via HDMI), the audio works perfectly fine.
Troubleshooting Steps Taken:
- Verified the headset works with other devices.
- Tested with multiple headphones/headsets to rule out device-specific issues.
- Checked sound settings and
pavucontrol
for any muted channels or incorrect configurations. - Used
alsamixer
to ensure no channels were muted. - Reviewed
dmesg
andjournalctl
logs for any obvious errors or warnings upon connecting the headset. But I would appreciate any help to understand better these logs.
Observations:
- The headset works without issues when connected through the HDMI-connected monitor.
- No changes are observed in
pavucontrol
when connecting the headset directly to the laptop.
I’m suspecting this could be a configuration issue or a problem with the laptop’s headphone jack detection. However, I’m not entirely sure how to diagnose this further, especially within the context of Garuda’s audio management setup.
Could anyone provide guidance on how to troubleshoot this issue further or suggest any potential fixes? Any advice on tools or logs that could provide more insights would be greatly appreciated.
Thank you in advance for your help and support!
╰─λ garuda-inxi
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1841fbdb-0a5a-497a-86d3-67c2ef2f6c76 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
v: 5.115.0 wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: Avell High Performance product: A65 MOB v: Standard
Mobo: Avell High Performance model: Avell A65 MOB v: Standard
serial: <superuser required> part-nu: A65 MOB uuid: <superuser required>
UEFI: American Megatrends LLC. v: N.1.07AVE00 date: 07/23/2021
ID-1: BAT0 charge: 69.3 Wh (98.0%) condition: 70.7/93.5 Wh (75.6%)
volts: 12.2 min: 11.4 model: standard type: Li-ion serial: <filter>
status: not charging
ID-2: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x4E
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1657 high: 3584 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 2373 2: 3492 3: 2706
4: 2478 5: 800 6: 802 7: 800 8: 800 9: 800 10: 800 11: 2279 12: 1238
13: 800 14: 1960 15: 800 16: 3584 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Tongfang Hongkong
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Tongfang Hongkong driver: nvidia v: 545.29.06
2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-2,DP-3,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-3: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-13:8 chip-ID: 04f2:b71a
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary,bottom-r
model: LG (GoldStar) 25UM58G serial: <filter> built: 2015 res: 2560x1080
dpi: 96 gamma: 1.2 size: 677x290mm (26.65x11.42") diag: 730mm (28.8")
modes: max: 2560x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: top-left model: BOE Display 0x0974
built: 2021 res: 2560x1440 hz: 165 dpi: 189 gamma: 1.2
modes: 2560x1440
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop
GPU/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.3.276 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (TGL GT1) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:9a60 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
Device-1: Intel Tiger Lake-H HD Audio vendor: Tongfang Hongkong
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Tongfang Hongkong
Device-3: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.2:11
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
Device-2: Realtek RTL8125 2.5GbE vendor: Tongfang Hongkong driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 2e:00.0
IF: enp46s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-2: br-3736135ffeba state: down mac: <filter>
IF-ID-3: br-4454222891f0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
IF-ID-5: veth115be32 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth343fced state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth4bb8cbd state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: veth5f7e0ce state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: veth6d456c4 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: veth6f8f2e1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth9c379e6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: vethab5102f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: vethbc9710f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: vethd7f6a3e state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: NetworkManager, nginx, smbd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:9 chip-ID: 8087:0026
Local Storage: total: 3.73 TiB used: 612.43 GiB (16.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42B9T6TB temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
lanes: 4 tech: SSD serial: <filter> fw-rev: 42B9T6TB temp: 41.9 C
ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 612.43 GiB (32.1%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:8
used: 571 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:7
ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
used: 612.43 GiB (32.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:8
ID-4: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.54 GiB used: 21.2 MiB (0.0%)
System Temperatures: cpu: 68.0 C mobo: N/A gpu: nvidia temp: 63 C
Memory: total: 64 GiB note: est. available: 62.54 GiB
used: 13.11 GiB (21.0%)
Processes: 514 Power: uptime: 1h 8m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 24.98 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2265 libs: 553
tools: pamac,paru Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12
Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2021-09-13
Last full system update: 2024-02-13 ↻
Relevant software: timeshift NetworkManager mkinitcpio nvidia-dkms
Failed units: anbox-container-manager.service systemd-networkd-wait-online.service
