I've had Garuda for about a week now and haven't had any issues with it until now. There is no longer sound coming from my headphones, however, I am still able to use the microphone. I dual-boot Windows 10 for certain games and I had to reinstall the audio drivers on Windows for the sound to work again there but the issue still persists on Garuda. I have looked at other posts here on the forum related to this issue but nothing has worked yet. Thanks in advance. It should also be noted that I'm still a novice with Linux.
Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=6b2ddd8c-14fa-43bf-9d97-37e46a39d368
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: H110M-A/M.2 v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 1802 date: 06/20/2016
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S gen: core 6 built: 2015
process: Intel 14nm family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4000 high: 4001 min/max: 800/4200 scaling: driver: intel_pstate
governor: performance cores: 1: 4000 2: 4001 3: 4000 4: 4001 5: 4000 6: 4000 7: 4000 8: 4000
bogomips: 63999
mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com. driver: nvidia v: 515.48.07
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of 2022-06) arch: Pascal
process: TSMC 16nm built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 compositor: kwin_x11 driver: X:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50") s-diag: 693mm (27.28")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 515.48.07
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 16.1 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:0030 class-ID: 0280
Local Storage: total: 670.7 GiB used: 56.72 GiB (8.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 052 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: PNY model: CS1311 240GB SSD size
: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1122 scheme: GPT
ID-1: / raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 56.72 GiB (12.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 56.72 GiB (12.7%) fs: btrfs
ID-4: /var/log raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 56.72 GiB (12.7%)
ID-5: /var/tmp raw-size: 446.83 GiB size: 446.83 GiB (100.00%) used: 56.72 GiB (12.7%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 2 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 240 Uptime: 6m wakeups: 0 Memory: 15.57 GiB used: 2.75 GiB (17.7%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages:
pacman: 1819 lib: 513 Client: shell wrapper v: 5.1.16-release inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-12
Last full system update: 2022-06-26
