Hi,
I've been having this issue on every Linux Distro, so I'm suspecting it might be an issue of a lack of kernel support. But the audio on my speakers won't work on my HP Envy Laptop (HP 15-ey0013dx) and I'm trying to figure out why. Every distro I've tried uses pipewire, distros that use pulseaudio typically also have outdated network packages for this machine, so I tend to avoid those. HDMI audio and 3.5mm jack audio work fine, as well as bluetooth. It'll show 17h/19h HD Audio as an option in the audio settings, but nothing happens. This is literally the ONLY problem I'm having, been loving everything else about Garuda! Any suggestions?
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=01d4db93-908e-40d9-a270-c2e6319c4b0a rw [email protected]
quiet rd.luks.uuid=5c422143-8703-40b2-b2de-5138726964a1 quiet splash
rd.luks.uuid=238c3846-5aa4-47ae-b9d5-d80493f6745b
resume=/dev/mapper/luks-238c3846-5aa4-47ae-b9d5-d80493f6745b loglevel=3
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
Type: Convertible System: HP product: HP ENVY x360 2-in-1 Laptop 15-ey0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 8A31 v: 26.11 serial: <superuser required> UEFI: Insyde
v: F.11 date: 02/10/2023
ID-1: BAT1 charge: 43.4 Wh (86.8%) condition: 50.0/51.0 Wh (98.1%)
volts: 12.4 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Device-1: hid-0018:04F3:402C.0001-battery model: ELAN2513:00 04F3:402C
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 5 5625U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1663 high: 2300 min/max: 1600/4387 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600
3: 1392 4: 2300 5: 1600 6: 1372 7: 1600 8: 1600 9: 1600 10: 1600 11: 1397
12: 2300 bogomips: 55097
Device-1: AMD Barcelo vendor: Hewlett-Packard driver: amdgpu v: kernel
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 34.0 C
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x09d8 built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.2-zen1-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api
vendor: Foxconn driver: mt7921e v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.0 chip-ID: 14c3:0616
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0489:e0e0
Local Storage: total: 238.47 GiB used: 45.59 GiB (19.1%)
model: MZVLQ256HBJD-00BH1 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS1NFAV temp: 25.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 45.59 GiB (19.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-5c422143-8703-40b2-b2de-5138726964a1
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 254:0
mapped: luks-238c3846-5aa4-47ae-b9d5-d80493f6745b
ID-2: swap-2 type: zram size: 7.08 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 363 Uptime: 51m wakeups: 54596 Memory: available: 7.08 GiB
used: 2.8 GiB (39.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1524 libs: 458 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.27
System install date: 2023-05-15
Last full system update: 2023-05-20 ↻
