I just install garuda and have trouble to get audio driver for my laptop,on windows audio was working and on some old version of ubuntu,now I only have garuda on this machine,please help,dont know what to do,try restart alsa but no effect
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=cd55ff06-aad7-4fbb-a3b3-3ccf09f3bc50
systemd.unified_cgroup_hierarchy=1 resume=UUID=e23cd8fd-c09f-41b3-84ec-845496b901c9 loglevel=3
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0 Distro: Garuda Linux
Machine: Type: Laptop System: ASUSTeK product: X555SJ v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X555SJ v: 1.0 serial: <filter> UEFI: American Megatrends v: X555SJ.214
date: 04/18/2019
Battery: ID-1: BAT0 charge: 22.0 Wh (84.6%) condition: 26.0/37.3 Wh (69.8%) volts: 7.5 min: 7.5
model: ASUSTeK X555-50 type: Li-ion serial: N/A status: Discharging
CPU: Info: Quad Core model: Intel Pentium N3700 socket: BGA1155 bits: 64 type: MCP arch: Airmont
family: 6 model-id: 4C (76) stepping: 3 microcode: 368 cache: L1: 224 KiB L2: 4 MiB
flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12800
Speed: 1062 MHz min/max: 480/2400 MHz base/boost: 1600/2400 volts: 1.2 V ext-clock: 80 MHz
Core speeds (MHz): 1: 1082 2: 1281 3: 1161 4: 480
Type: spec_store_bypass status: Not affected
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:22b1 class-ID: 0300
Device-2: NVIDIA GK208BM [GeForce 920M] driver: nouveau v: kernel bus-ID: 01:00.0
chip-ID: 10de:1299 class-ID: 0302
Device-3: Realtek USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 0bda:57de class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.1 compositor: gnome-shell driver: loaded: nouveau
unloaded: modesetting failed: intel alternate: fbdev,nv,vesa display-ID: :1 screens: 1
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Audio: Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:2284
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lite-On driver: rtl8723be
v: kernel port: c000 bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-3:2
chip-ID: 0bda:b721 class-ID: e001 serial: <filter>
Drives: Local Storage: total: 119.24 GiB used: 10.56 GiB (8.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD6SB1M-128G-1006 size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 706
Partition: ID-1: / raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 10.56 GiB (9.6%) fs: btrfs
block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 10.56 GiB (9.6%) fs: btrfs
ID-4: /var/log raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 10.56 GiB (9.6%) fs: btrfs
ID-5: /var/tmp raw-size: 110.15 GiB size: 110.15 GiB (100.00%) used: 10.56 GiB (9.6%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 6280.4 C mobo: 35.0 C gpu: nouveau temp: 31.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 224 Uptime: 4m wakeups: 12931 Memory: 7.67 GiB used: 1.63 GiB (21.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1153 lib: 340
Shell: fish (sudo) v: 3.3.1 default: Bash v: 5.1.12 running-in: gnome-terminal inxi: 3.3.09
