Greetings. I’ve just installed Garuda Linux, after using Arch with KDE for several weeks, and I experience a problem with audio. My PC doesn’t see my headphones that are connected via jack (not usb or bluetooth). I had the same pipewire on my Arch KDE and it worked good.
I tried to install pulseaudio, but still no success. Garuda Assistant couldn’t help either. Help?
Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
root=UUID=f5922cb5-d047-44b2-8604-49f18f7d7b1c rw rootflags=subvol=@
vt.default_blu=46,168,161,175,250,231,213,222,112,168,161,175,250,231,213,200 quiet
resume=UUID=a4bfa883-9857-4cd3-a752-6d9134e365d0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASUSTeK model: PRIME Z370-P II v: Rev X.0x serial: <superuser required>
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 0411 date: 09/21/2018
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: discharging
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake gen: core 8 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4300 min/max: 800/4600 scaling: driver: intel_pstate governor: performance
cores: 1: 4300 2: 4300 3: 4300 4: 4300 5: 4300 6: 4300 7: 4300 8: 4300 9: 4300 10: 4300 11: 4300
12: 4300 bogomips: 76799
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1 empty: HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: Samsung C27F390 serial: <filter> built: 2018 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2) device-ID: 8086:3e92
memory: 7.55 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 5 device: 0 type: integrated-gpu name: Intel UHD Graphics 630
(CFL GT2) driver: N/A device-ID: 8086:3e92 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api with: aoss type: oss-emulator
Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK RTL8111H
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Local Storage: total: 465.76 GiB used: 18.98 GiB (4.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
fw-rev: 2B6Q scheme: GPT
ID-1: / raw-size: 448.45 GiB size: 448.45 GiB (100.00%) used: 18.98 GiB (4.2%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.45 GiB size: 448.45 GiB (100.00%) used: 18.98 GiB (4.2%) fs: btrfs
ID-4: /var/log raw-size: 448.45 GiB size: 448.45 GiB (100.00%) used: 18.98 GiB (4.2%) fs: btrfs
ID-5: /var/tmp raw-size: 448.45 GiB size: 448.45 GiB (100.00%) used: 18.98 GiB (4.2%) fs: btrfs
ID-1: swap-1 type: zram size: 15.47 GiB used: 65.5 MiB (0.4%) priority: 100 comp: zstd
avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 12 dev: /dev/zram0
ID-2: swap-2 type: partition size: 17.02 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
System Temperatures: cpu: 45.0 C mobo: N/A
Memory: total: 16 GiB available: 15.47 GiB used: 5.57 GiB (36.0%)
Processes: 305 Power: uptime: 46m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 6.18 GiB
Packages: pm: pacman pkgs: 1854 libs: 424 tools: octopi,paru Compilers: clang: 19.1.7
gcc: 14.2.1 Client: Unknown Client: garuda-rani inxi: 3.3.37
System install date: 2025-03-20
Last full system update: 2025-03-20 ↻
