Hi, i have a question, i think this was asked before, but i did what was suggested in a previous thread, which is enabling this in the Grub
amdgpu.ppfeaturemask=0xffffffff
but still after doing so nothing changes. I’ve already tried multiple kernels including:
linux-zen 6.0.2, linux-arch 6.0.2, Multiple TKG kernels.
╭─aqua@aqua in
╰─λ garuda-inxi
Kernel: 6.0.2-x64v2-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge
root=UUID=723b7c64-c203-418d-b27c-4d67f33d0e69 rw rootflags=subvol=@
loglevel=3 mitigations=off amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: X79-UP4 v: x.x serial: <superuser required>
UEFI: American Megatrends v: F6a date: 12/18/2013
Info: model: Intel Core i7-3930K bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 3 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2D (45) stepping: 7 microcode: 0x71A
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2692 high: 5900 min/max: 1200/5900 scaling:
driver: intel_cpufreq governor: ondemand cores: 1: 3072 2: 3802 3: 1200
4: 1200 5: 1200 6: 5900 7: 5900 8: 2128 9: 1200 10: 3038 11: 1400
12: 2271 bogomips: 76799
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M] vendor: Tul
/ PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:73df class-ID: 0300
compositor: kwin_x11 driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Samsung
built: 2010 res: 1920x1080 hz: 60 dpi: 55 gamma: 1.2
size: 886x498mm (34.88x19.61") diag: 551mm (21.7") ratio: 16:9 modes:
Monitor-2: DP-3 mapped: DisplayPort-2 pos: primary,right model: LG
(GoldStar) FULL HD serial: <filter> built: 2020 res: 1920x1080 hz: 60
dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63") diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon RX 6700 XT (navi22 LLVM 14.0.6 DRM 3.48
6.0.2-x64v2-xanmod1-1) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:ab28
Sound API: ALSA v: k6.0.2-x64v2-xanmod1-1 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Gigabyte driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Local Storage: total: 592.05 GiB used: 25.43 GiB (4.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Gigabyte model: GP-GSTFS31120GNTD
type: SSD serial: <filter> rev: 11.3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HM250HI
size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 01C4 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra Fit
size: 14.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 25.43 GiB
(22.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
(0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 25.43
GiB (22.8%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 25.43
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 25.43
ID-1: swap-1 type: zram size: 31.28 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 30.0 C
Processes: 307 Uptime: 5m wakeups: 0 Memory: 31.28 GiB used: 2.93 GiB
(9.4%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1497 libs: 478
tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.8-1):
System install date: 2022-10-16
Last full system update: 2022-10-20
Failed units: systemd-oomd.socket
