Hello everyone :),
Hey I am trying to use the garuda nix subsystem, but the instillation is failing. It says complete, but it never installed and I can not see the option to boot into it. I am following this guide. I tried to update it to fix it and got the following errors.
error:
… while calling the 'head' builtin
at /tmp/tmp.0JfOgU16wY/nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/attrsets.nix:936:11:
935| || pred here (elemAt values 1) (head values) then
936| head values
937| else
… while evaluating the attribute 'value'
at /tmp/tmp.0JfOgU16wY/nix/store/4fgs7yzsy2dqnjw8j42qlp9i1vgarzy0-source/lib/modules.nix:809:9:
808| in warnDeprecation opt //
809| { value = builtins.addErrorContext "while evaluating the option `${showOption loc}':" value;
810| inherit (res.defsFinal') highestPrio;
(stack trace truncated; use '--show-trace' to show the full trace)
error: A definition for option `networking.hostName' is not of type `string matching the pattern ^$|^[[:alnum:]]([[:alnum:]_-]{0,61}[[:alnum:]])?$'. Definition values:
- In `/tmp/tmp.0JfOgU16wY/nix/store/kvczim5v3xnk9li1pbfvwal2sh66793s-source/internal/modules/base/managed': "neon-"
Kernel: 6.6.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=16418167-4e2f-45d3-ad11-0999ce42a0f8 rw rootflags=subvol=@
quiet rd.luks.uuid=412f8dfb-b329-4435-af90-33c36e8f7552
rd.luks.uuid=acde1cd1-513c-4b66-a1c1-ef7d203fb179
resume=/dev/mapper/luks-acde1cd1-513c-4b66-a1c1-ef7d203fb179 loglevel=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Detachable System: ASUSTeK product: ROG Flow Z13 GZ301ZC_GZ301ZC
Mobo: ASUSTeK model: GZ301ZC v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GZ301ZC.317 date: 05/18/2023
ID-1: BAT0 charge: 48.2 Wh (100.0%) condition: 48.2/56.0 Wh (86.0%)
volts: 16.0 min: 16.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 154
Device-1: hid-0018:04F3:2ED7.000A-battery model: ELAN9008:00 04F3:2ED7
serial: N/A charge: N/A status: N/A
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x430
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 498 high: 998 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 670 6: 400 7: 400 8: 898 9: 664 10: 400 11: 604 12: 400 13: 400 14: 998
15: 400 16: 400 17: 530 18: 400 19: 400 20: 400 bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-2 empty: DP-2,DP-3 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 ports: active: none
empty: DP-1,eDP-1 bus-ID: 0000:01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-3: USB C Video Adaptor driver: N/A type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.4.2:34 chip-ID: 25a4:9311
class-ID: 1100 serial: <filter>
Device-4: Microdia USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:5 chip-ID: 0c45:636d
Device-5: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:11
chip-ID: 13d3:5492 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.2
Monitor-1: eDP-2 res: 1536x960 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
inactive: device-2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 14.95 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46a6 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia
v: 545.29.06 device-ID: 10de:25a2 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.6.6-zen1-1-zen status: kernel-api tools: N/A
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.4:39 chip-ID: 0b95:1790
IF: enp0s20f0u1u4c2 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:14 chip-ID: 8087:0033
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 491.38 GiB used: 12.23 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN735 SDBPTHH-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 70626000 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: USB DISK 3.0 size: 14.44 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
used: 12.22 GiB (2.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-412f8dfb-b329-4435-af90-33c36e8f7552
ID-3: /home raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
ID-4: /var/log raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
mapped: luks-acde1cd1-513c-4b66-a1c1-ef7d203fb179
ID-2: swap-2 type: zram size: 15.31 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
Use of uninitialized value in pattern match (m//) at /usr/bin/inxi line 26495.
Use of uninitialized value in pattern match (m//) at /usr/bin/inxi line 26499.
Use of uninitialized value in pattern match (m//) at /usr/bin/inxi line 26506.
Use of uninitialized value in pattern match (m//) at /usr/bin/inxi line 26525.
Src: /sys System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Processes: 442 Uptime: 12h 53m wakeups: 1 Memory: total: 16 GiB note: est.
available: 15.31 GiB used: 5.51 GiB (36.0%) Init: systemd v: 255
pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0 pm: pacman
pkgs: 1463 libs: 394 tools: octopi,paru Shell: fish v: 3.6.4
Garuda (2.6.19-2):
System install date: 2023-12-13
Last full system update: 2023-12-13
