Hi there,
I've been using Garuda on my desktop computer for around 6 months now and i very much like it.
I have a NFS server at home which i automatically mount at startup on this main computer, using fstab with the _netdev option. It has always worked fine on my main computer, as well as on another Manjaro computer i have at home.
However, when trying to do the same on my new laptop which i freshly installed on Garuda too, it ends up not working with a strange behavior.
I tried with fstab/_netdev, and with a systemd Mount with a dependency to network-online.target
and both solutions ended up having the same issue.
In journalctl, i can see that systemd does wait for the network-online target to be reached before attempting the mount, but even after network-online is reached it seems like the network interfaces are not completely up; so the mount fails with a 'network unreachable' error.
Doing sudo mount -a
or systemctl restart my-mount.mount
after login does work so its likely not a misconfiguration;
Being on a wired or wireless network doesn't make any difference.
I found some ideas for a workaround looking around the internet, but it feels strange to me that the same configuration would work flawlessly on several desktop computers but not on the laptop ?!? Maybe wifi is getting in the way for some reason ?
Could use any ideas there, thanks a lot for reading
Garuda-inxi
Kernel: 6.4.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=93c200b2-f7d6-44e0-b4da-8a779d0679f4 rw rootflags=subvol=@
resume=UUID=60c3e298-c385-4adf-8796-820ae4ebfa38 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 21D4002TFR v: ThinkPad Z16 Gen 1
Mobo: LENOVO model: 21D4002TFR serial: <filter> UEFI: LENOVO
v: N3GET57W (1.57 ) date: 05/10/2023
ID-1: BAT0 charge: 57.4 Wh (79.5%) condition: 72.2/72.2 Wh (100.0%)
volts: 16.9 min: 15.5 model: Celxpert 5B10W51888 type: Li-poly
serial: <filter> status: not charging cycles: 1
Info: model: AMD Ryzen 7 PRO 6850H with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1800 high: 3200 min/max: 1600/4784 boost: enabled
base/boost: 3200/4750 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3200 2: 1600 3: 1600 4: 1600
5: 3200 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 1600
13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 102203
Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-10,eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, DP-9
bus-ID: e4:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 37.0 C
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
chip-ID: 30c9:0052 class-ID: fe01 serial: <filter>
Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.3.2.1:12
chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
Screen-1: 0 s-res: 4480x1682 s-dpi: 96 s-size: 1183x444mm (46.57x17.48")
s-diag: 1264mm (49.75")
Monitor-1: DP-10 mapped: DisplayPort-9 pos: primary,top-left
model: AOC Q3279WG5B serial: <filter> built: 2017 res: 2560x1440 hz: 60
dpi: 90 gamma: 1.2 size: 725x428mm (28.54x16.85") diag: 842mm (33.1")
ratio: 15:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: bottom-r model: BOE Display 0x0a30
built: 2021 res: 1920x1200 hz: 60 dpi: 141 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 1920x1200
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (rembrandt
LLVM 15.0.7 DRM 3.52 6.4.3-zen1-1-zen) direct-render: Yes
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: e4:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: e4:00.5 chip-ID: 1022:15e2 class-ID: 0480
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: e4:00.6
Device-4: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
Device-5: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.3.4:6 chip-ID: 0bda:402e
API: ALSA v: k6.4.3-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.74 status: n/a (root, process) with:
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 17cb:1103 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-1.4:5
IF: enp229s0f3u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 10ab:9309 class-ID: e001
Local Storage: total: 476.94 GiB used: 6.2 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCQNRY-512G-1001 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 61540101 temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 37 hrs cycles: 421
read-units: 3,768,499 [1.92 TB] written-units: 1,082,955 [554 GB]
ID-1: / raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
used: 6.19 GiB (1.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 460.25 GiB size: 460.25 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: partition size: 16.39 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 14.9 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): fan-1: 2659 fan-2: 2428
Processes: 356 Uptime: 22m wakeups: 5117 Memory: total: 16 GiB note: est.
available: 14.9 GiB used: 3.19 GiB (21.4%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1210 libs: 326 tools: octopi,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-07-15
Last full system update: 2023-07-15
Failed units:```
