The Kernel 6.6.58-1-lts is the only kernel that boots. The latest kernel 6.11 zen does not get past: “Loading Garuda Linux, loading zram” and just sits there - forever.
Sorry, this is the only inxi I can get to.
Kernel: 6.6.58-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=792384b1-5057-4a55-adc4-b8bcd36ec2a1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Laptop System: System76 product: Adder WS v: addw3
Mobo: System76 model: Adder WS v: addw3 serial: <superuser required>
UEFI: coreboot v: 2024-07-08_926f73d date: 06/28/2024
ID-1: BAT0 charge: 68.2 Wh (96.3%) condition: 70.8/70.8 Wh (99.9%)
volts: 17.3 min: 15.4 model: Notebook BAT type: Li-ion serial: <filter>
status: not charging cycles: 3
Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device
Info: model: 13th Gen Intel Core i9-13900HX bits: 64 type: MST AMCP
microcode: 0x129
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 800 min/max: 800/5200:5400:3900 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800
bogomips: 154880
Device-1: Intel Raptor Lake-S UHD Graphics vendor: CLEVO/KAPOK driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-2 empty: DP-2, DP-3, DP-4, HDMI-A-2, HDMI-A-3, HDMI-A-4
bus-ID: 00:02.0 chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: CLEVO/KAPOK driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: none empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0
chip-ID: 10de:28a0 class-ID: 0300
Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:2 chip-ID: 5986:9102
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
Monitor-1: eDP-2 res: 1920x1080 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a788 memory: 15.23 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 24.2.5-arch1.1
device-ID: 8086:a788 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 4060 Laptop GPU driver: nvidia
v: 560.35.03 device-ID: 10de:28a0 surfaces: xcb,xlib,wayland device: 2
v: 24.2.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel Raptor Lake High Definition Audio vendor: CLEVO/KAPOK
Device-2: NVIDIA AD107 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.6.58-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-2: Intel vendor: CLEVO/KAPOK driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:0dc8 class-ID: 0200
IF: eno0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0033
Local Storage: total: 931.51 GiB used: 12.57 GiB (1.3%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 41.9 C
used: 12.57 GiB (1.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2032
Memory: total: 32 GiB note: est. available: 31.19 GiB used: 4.05 GiB (13.0%)
Processes: 497 Power: uptime: 28m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1559 libs: 497 tools: paru pm: flatpak pkgs: 0
Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-10-28
Last full system update: 2024-10-28
