New shadow , borders and layouts options in G-Hyprland
Hello garudians !!
I wanted to tell that there are 3 more options which are shadows , borders and layouts are added in our optional G-Hyprland feature ,
which are shown in the below featured video :
for getting it first update with upd and then disabling and enabling again your G-Hyprland feature with the shortcut key Mod+Shift+g
PS : don’t forget to take a backup of your older configs :wink:
Thanks :smile:
Summary
Screenshots | Garuda Linux preferred :master: - #1799 by Ankur
0.4.151 · Tags · Garuda Linux 🦅 / Themes and Settings / Settings / Garuda Hyprland Settings · GitLab
It keeps getting better an better. Great job.
The config file under gum_files/brain/config/borders/colors/ seems to have some errors and isn’t working properly. For example:
general {
    col.active_border = rgba(225,0,0,100)
Good Job. Looks nice.
Hmm… thanks for telling, let me check
EDIT : there was a file that was file that I forgot to add in commit , now it is added .
You can re-check and let me know if it works as expected or not :slightly_smiling_face:
It seems the RGBA values in the layout options require fixing.
I tried to as guest user , and everything is working well
I don’t know about what kind of flaw you are talking , if you can provide more details then maybe I can help :slightly_smiling_face:
For example, the settings in white_red.conf are as follows:
general {
    col.active_border = rgba(225,225,255,300) rgba(225,0,0,300) 45deg
When I choose this configuration, Waybar throws an error saying: “no colors?” Then I checked with GPT, and the explanation was that this rgba is incorrect because the fourth parameter in RGBA represents the alpha value (transparency), which should range from 0 to 1, not 300. I’m not sure why this configuration works correctly for you.
Seems like a typo, but max is in this notation 100
I like more the #e1e1ffff notation, it’s shorter :smiley:
col.active_border = rgba(33ccffee) rgba(8f00ffee) 45deg
I’m not sure; I just copied GPT’s response:
Frontend Development: In CSS, opacity and rgba() usually use a decimal format ranging from 0 to 1.
Design Tools: To make it easier for non-developers to understand, design tools typically represent transparency using percentages. In these tools, 100% means fully opaque.
If you write rgba(255, 0, 0, 100); directly in CSS, it is not supported and will cause an error. The correct way is: rgba(255, 0, 0, 1);
Well, my friends and during exam times use GPT to verify our answers , that whether they are correct or not when we are preparing .
And I tell you many times it just write anything , sometimes it will do obvious errors instead of chatGPT correcting us on where we are doing mistake , we are correcting it :sweat_smile:
So, please don’t say that chatGPT said this or that , it is still an LLM and it commits tons of errors :stuck_out_tongue:
BTW, back to topic :
300 was a typo :sweat_smile:
And it is really funny that all the values are working on my system :rofl:
Anyways , will change all the 100s and 300s to 1 :slightly_smiling_face:
fixed :
Just for final confirmation , can you please check and confirm , everything is working well or not :slightly_smiling_face: ??
I understand what you mean, and I have no intention of offending you. It’s just that the previous configuration indeed couldn’t run normally on my computer. You said: ‘I don’t know about what kind of flaw you are talking, if you can provide more details then maybe I can help,’ so I went to ask GPT. Anyway, thank you, great job.
Looking really nice I need to try this distro out at some point.
FYI :slight_smile:
Garuda Linux is the distribution.
Hyprland is the Desktop Enviroment (DE).
