Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ac3e7f0c-0797-45ee-b013-38f863703c95 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASRock model: Z790 LiveMixer serial: <filter>
uuid: 04006b9c-7879-0000-0000-000000000000 UEFI: American Megatrends LLC.
v: 3.09 date: 10/07/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
Info: model: 13th Gen Intel Core i9-13900KF bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 856 high: 1100 min/max: 800/5500:5800:4300
base/boost: 5445/8500 scaling: driver: intel_pstate governor: powersave
volts: 1.4 V ext-clock: 100 MHz cores: 1: 1100 2: 800 3: 1100 4: 800
5: 800 6: 1100 7: 800 8: 1100 9: 1100 10: 800 11: 800 12: 1099 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800
23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 800 30: 800 31: 800
32: 800 bogomips: 191692
Device-1: NVIDIA AD103 [GeForce RTX 4080] vendor: Gigabyte driver: nvidia
v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2704
Display: server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43")
s-diag: 804mm (31.65")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 3840x2160 dpi: 139
size: 700x390mm (27.56x15.35") modes: 3840x2160
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 17.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 45.76 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4080 driver: nvidia v: 550.54.14
device-ID: 10de:2704 surfaces: xcb,xlib
Device-1: Intel Raptor Lake High Definition Audio vendor: ASRock
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bb
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 22.28 TiB used: 9.99 TiB (44.8%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Seagate model: BarraCuda Q5
ZP2000CV30001 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU5SH017
temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 109d 9h cycles: 3,168
read-units: 25,797,292 [13.2 TB] written-units: 93,774,298 [48.0 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: TeamGroup
model: T-FORCE TM8FPZ004T size: 3.64 TiB block-size: physical: 512 B
fw-rev: EIFM51.3 temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 24d 8h cycles: 206
read-units: 13,425,010 [6.87 TB] written-units: 14,778,547 [7.56 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
family: Barracuda 7200.12 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: CC38 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 6y 191d 19h cycles: 9542
read: 14.42 GiB written: 1023.96 GiB Pre-Fail: attribute: Spin_Retry_Count
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST12000NM0127
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: G006
temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5d 18h cycles: 49
read: 1.29 TiB written: 3.13 TiB Pre-Fail: attribute: Spin_Retry_Count
ID-5: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ03UBB200
family: 2.5" HDD MQ03UBB... size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
sata: 3.0 speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 5438 drive-rev: JP050U temp: 25 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 4y 85d 23h cycles: 1805
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD40NMZW-11GX6S1 family: Elements / My Passport (USB, AF)
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 sata: 3.1 speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1018 drive-rev: 01.01A01
temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 82d 5h cycles: 630
ID-1: / raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
used: 384.06 GiB (76.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:5
used: 648 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:6
ID-3: /home raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 500.24 GiB size: 500.24 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 46.86 GiB used: 54 MiB (0.1%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 13.0 C mobo: 42.0 C gpu: nvidia temp: 49 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0 fan-3: 1274 fan-4: 0 fan-5: 559
fan-6: 3169 fan-7: 0 gpu: nvidia fan: 0%
Memory: total: 48 GiB available: 46.86 GiB used: 6.11 GiB (13.0%)
Processes: 560 Power: uptime: 2h 34m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.68 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2430 libs: 612 tools: gnome-software, octopi,
pamac, paru pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: lxterminal
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-04
Last full system update: 2024-03-09
i use quick launchers on my panel, but the icons disappear when i hover my mouse above them, only coming back irregularly, at times not at all. This also happens with icon only task manager icons, and system icons.
It happens in both X11 and Wayland, but i want to use X11 for my scripts do not work any longer with Wayland.
How best to proceed?
[EDIT]
i just found out, by accident, after trying a million things, that reloading the plasma shell in a terminal fixed the problem. (i wanted to see if it would give me any errors loading it like that.)
(i did it twice, for the first time i forgot to assign it a pid, so the panel crashed closing the panel pressing ctrl c. So iām not sure what fixed the issue, crashing the plasma shell, or loading it in a terminal.)
All that matters is that it is working fine, and i do not have to repeat the procedure, even after a reboot.
