Hey everyone, so I just built a hell of a new PC to run Garuda and had a question about my audio devices. The short question is why are my motherboard audio ports (s/pdif and speakers) showing up as USB Audio and not analog?
This is causing me to have to turn up the volume way more than im used to in Garuda, and this is not the case when I ran Windows for a week (only to run cinebench and 3d mark lol). In Garuda i have the volume at 73% and in Windows I was below 30% volume.
My motherboard is using Realtek® ALC4080 Codec
Im kinda at a loss as to what to do or try or if this is even a issue to begin with but it is rather annoying having to turn the volume up so loud for the same experience, it just feels off if you know what I mean.
Thanks for the help and guidance.
╰─λ garuda-inxi
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=abca74bd-967e-4902-9d64-1b3167ed032c rw rootflags=subvol=@
quiet resume=UUID=5d80dee8-4f6f-4c4c-b276-ade82e80f7d0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: Micro-Star model: MPG X670E CARBON WIFI (MS-7D70) v: 1.0
Megatrends LLC. v: 1.F0 date: 03/28/2024
Info: model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 1789 high: 4752 min/max: 400/5759 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 4306 3: 400
4: 400 5: 4186 6: 400 7: 400 8: 3880 9: 4520 10: 4049 11: 3946 12: 400
13: 400 14: 400 15: 400 16: 3175 17: 400 18: 3691 19: 400 20: 3452 21: 400
22: 400 23: 400 24: 400 25: 3326 26: 3177 27: 3189 28: 4752 29: 400
30: 400 31: 400 32: 400 bogomips: 268796
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1,Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2, Writeback-2 bus-ID: 18:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 50.0 C
gpu: amdgpu,amdgpu d-rect: 6592x2232 display-ID: 0
Monitor-1: DP-1 pos: top-center res: 2752x1152 size: N/A modes: N/A
Monitor-2: DP-2 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-3: DP-3 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.9.3-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.1.1-arch1.1 device-ID: 1002:164e
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM 17.0.6)
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 18:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 18:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Razer USA Kraken X USB driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:6
chip-ID: 1532:0526 class-ID: 0300 serial: <filter>
Device-5: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:5
chip-ID: 0db0:d6e7 class-ID: 0300
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api with: aoss
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:8
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:4 chip-ID: 0e8d:0616
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 931.51 GiB used: 171.41 GiB (18.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT401.3 temp: 43.9 C
ID-1: / raw-size: 828.39 GiB size: 828.39 GiB (100.00%)
used: 171.41 GiB (20.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 828.39 GiB size: 828.39 GiB (100.00%)
ID-4: /var/log raw-size: 828.39 GiB size: 828.39 GiB (100.00%)
ID-5: /var/tmp raw-size: 828.39 GiB size: 828.39 GiB (100.00%)
ID-1: swap-1 type: zram size: 93.48 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
ID-2: swap-2 type: partition size: 102.83 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.1 C mobo: 42.0 C
GPU: device: amdgpu temp: 50.0 C device: amdgpu temp: 58.0 C mem: 70.0 C
fan: 386 watts: 77.00
Memory: total: 96 GiB note: est. available: 93.48 GiB used: 8.4 GiB (9.0%)
Processes: 562 Power: uptime: 2h 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 37.38 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1950 libs: 585 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-06-03
Last full system update: 2024-06-07
