New Aqualung problem
 aqualung
aqualung: error while loading shared libraries: libavcodec.so.60: cannot open shared object file: No such file or directory
 ╭─oldrocker99@oldrocker99 in ~ took 12ms
[🔍] × yay -S libavcodec
:: Resolving dependencies...
error: could not find all required packages:
    libavcodec (target)
This just happened, and I’m stuck on how to fix it.
  Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=aae31ea9-4c84-48c7-aa44-18be46d09b9d rw rootflags=subvol=@
  Desktop: MATE v: 1.28.2 wm: marco v: 1.28.1 with: mate-panel
    tools: mate-screensaver, xscreensaver, xscreensaver-systemd avail: xautolock
    vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda base: Arch Linux
  Type: Laptop System: Acer product: Nitro AN515-42 v: V1.13
  Mobo: RR model: Freed_RRS v: V1.13 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.13
    date: 02/11/2019
  ID-1: BAT1 charge: 36.1 Wh (100.0%) condition: 36.1/48.9 Wh (73.7%)
    volts: 16.3 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0x4B
    type: Li-ion serial: <filter> status: full
  Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
    family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1550 high: 1600 min/max: 1600/2000 boost: disabled
    scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1579 2: 1600
    3: 1600 4: 1600 5: 1459 6: 1369 7: 1600 8: 1600 bogomips: 31938
  Device-1: AMD Baffin [Radeon RX 460/560D / Pro
    450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI
    built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380
    temp: 45.0 C
  Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
    lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:15dd class-ID: 0300 temp: 45.0 C
  Device-3: Quanta HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:a060
    compositor: marco v: 1.28.1 driver: X: loaded: amdgpu unloaded: modesetting
  Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05d8 built: 2018
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    device: 1 drv: radeonsi device: 2 drv: swrast surfaceless: drv: radeonsi
    x11: drv: radeonsi inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
    (radeonsi raven LLVM 17.0.6 DRM 3.57 6.9.5-zen1-1-zen)
    device-ID: 1002:15dd memory: 1000 MiB unified: no
  API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 24.1.1-arch1.1
    device-ID: 1002:15dd surfaces: xcb,xlib device: 1 type: discrete-gpu
    name: AMD Radeon RX Graphics (RADV POLARIS11) driver: mesa radv
    v: 24.1.1-arch1.1 device-ID: 1002:67ef surfaces: xcb,xlib device: 2
    type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
    v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
  API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168
  IF: enp2s0f1 state: down mac: <filter>
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 42.0 C
  Local Storage: total: 1.02 TiB used: 813.53 GiB (78.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8120G
    tech: SSD serial: <filter> fw-rev: 61E1 scheme: MBR
  ID-1: / raw-size: 95.81 GiB size: 95.81 GiB (100.00%)
    used: 37.73 GiB (39.4%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
  ID-2: /boot/efi raw-size: 300 MiB size: 98.4 MiB (32.82%)
    used: 867 KiB (0.9%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
  ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 775.8 GiB (84.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  ID-4: /var/log raw-size: 95.81 GiB size: 95.81 GiB (100.00%)
  ID-5: /var/tmp raw-size: 95.81 GiB size: 95.81 GiB (100.00%)
  ID-1: swap-1 type: zram size: 30.26 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 45.8 C mobo: N/A
  GPU: device: amdgpu temp: 46.0 C watts: 9.11 device: amdgpu temp: 45.0 C
  Memory: total: 32 GiB note: est. available: 30.26 GiB used: 5.48 GiB (18.1%)
  Processes: 279 Power: uptime: 6h 50m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 3 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.09 GiB services: mate-power-manager,upowerd
  Packages: 1599 pm: pacman pkgs: 1594 libs: 524 tools: octopi,paru
    pm: flatpak pkgs: 5 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: Bash
    v: 5.2.26 running-in: mate-terminal inxi: 3.3.35
  System install date:     2024-04-19
  Last full system update: 2024-06-21
Have you tried rebuilding it. E.g.
paru aqualung
Package rebuilt, should be working after an update
Reinstalled, and
aqualung
It seems to me that the problem stems from the fact that aqualung depens on ffmpeg and currently ffmpeg 2:7.0.1-1 provides libavcodec.so=61-64 instead of libavcodec.so.60 :frowning:
I saw in the upstream site they added over time support to ffmpeg5, ffmpeg6. See e.g.
Now it’s probably time that someone asks for ffmpeg7?
whereis libavcodec
libavcodec: /usr/include/libavcodec /usr/share/man/man3/libavcodec.3.gz
It doesn’t matter where it is located but by what package it is provided:
https://archlinux.org/packages/?q=libavcodec
(I’m not on the Garuda machine at the moment)
libavcodec is a library, not a package.
So its the same cause for trouble as in this thread. Bummer :confused:
Updated and Aqualung runs! Thanks to the builder!
