Just for the heck of it...
I've always had good luck with iwd
I installed iwd and set up NM to use it as a backend
Then I decided to get rid of wpa_supplicant all together using networkmanager-iwd.
Got a little nervous about half way through but I persevered!
2020-12-28T18:06:01-0500] [PACMAN] Running 'pacman -S iwd'
[2020-12-28T18:06:03-0500] [ALPM] transaction started
[2020-12-28T18:06:03-0500] [ALPM] installed ell (0.35-1)
[2020-12-28T18:06:03-0500] [ALPM] installed iwd (1.10-1)
[2020-12-28T18:06:03-0500] [ALPM] transaction completed
[2020-12-28T18:06:03-0500] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-12-28T18:06:03-0500] [ALPM] running '30-systemd-update.hook'...
[2020-12-28T18:06:03-0500] [ALPM] running 'dbus-reload.hook'...
[2020-12-28T18:06:03-0500] [ALPM] running 'orphans.hook'...
[2020-12-28T18:06:03-0500] [ALPM-SCRIPTLET] => No orphans found.
[2020-12-28T18:06:03-0500] [ALPM] running 'pacnew-check.hook'...
[2020-12-28T18:22:47-0500] [PACMAN] Running 'pacman -Rns wpa_supplicant'
[2020-12-28T18:31:57-0500] [PACMAN] Running '/usr/bin/pacman -S --asdeps intltool gobject-introspection gtk-doc vala perl-yaml vala glib2-docs meson'
[2020-12-28T18:32:13-0500] [ALPM] transaction started
[2020-12-28T18:32:13-0500] [ALPM] installed intltool (0.51.0-6)
[2020-12-28T18:32:13-0500] [ALPM] installed python-markupsafe (1.1.1-6)
[2020-12-28T18:32:13-0500] [ALPM] installed python-beaker (1.11.0-6)
[2020-12-28T18:32:13-0500] [ALPM] installed python-mako (1.1.3-3)
[2020-12-28T18:32:13-0500] [ALPM] installed python-markdown (3.3.3-2)
[2020-12-28T18:32:13-0500] [ALPM] installed gobject-introspection (1.66.1-3)
[2020-12-28T18:32:13-0500] [ALPM] installed docbook-xml (4.5-9)
[2020-12-28T18:32:14-0500] [ALPM] installed docbook-xsl (1.79.2-7)
[2020-12-28T18:32:14-0500] [ALPM] installed glib2-docs (2.66.4-1)
[2020-12-28T18:32:14-0500] [ALPM] installed python-lxml (4.6.2-1)
[2020-12-28T18:32:14-0500] [ALPM] installed python-pygments (2.7.3-1)
[2020-12-28T18:32:14-0500] [ALPM] installed python-anytree (2.8.0-3)
[2020-12-28T18:32:14-0500] [ALPM] installed gtk-doc (1.33.1-1)
[2020-12-28T18:32:14-0500] [ALPM] installed netpbm (10.73.33-1)
[2020-12-28T18:32:14-0500] [ALPM] installed gts (0.7.6.121130-2)
[2020-12-28T18:32:15-0500] [ALPM] installed graphviz (2.44.1-6)
[2020-12-28T18:32:15-0500] [ALPM] installed vala (0.50.2-1)
[2020-12-28T18:32:15-0500] [ALPM] installed perl-yaml (1.30-2)
[2020-12-28T18:32:16-0500] [ALPM] installed ninja (1.10.2-1)
[2020-12-28T18:32:16-0500] [ALPM] installed meson (0.56.0-3)
[2020-12-28T18:32:17-0500] [ALPM] transaction completed
[2020-12-28T18:32:17-0500] [ALPM] running '30-systemd-update.hook'...
[2020-12-28T18:32:17-0500] [ALPM] running 'detect-old-perl-modules.hook'...
[2020-12-28T18:32:17-0500] [ALPM] running 'orphans.hook'...
[2020-12-28T18:32:17-0500] [ALPM-SCRIPTLET] gobject-introspection 1.66.1-3
[2020-12-28T18:32:17-0500] [ALPM-SCRIPTLET] intltool 0.51.0-6
[2020-12-28T18:32:17-0500] [ALPM-SCRIPTLET] meson 0.56.0-3
[2020-12-28T18:32:17-0500] [ALPM-SCRIPTLET] perl-yaml 1.30-2
[2020-12-28T18:32:17-0500] [ALPM-SCRIPTLET] vala 0.50.2-1
[2020-12-28T18:32:17-0500] [ALPM] running 'pacnew-check.hook'...
[2020-12-28T18:50:17-0500] [PACMAN] Running '/usr/bin/pacman -U /home/jbarks/networkmanager-iwd/networkmanager-iwd-1.26.2-3-x86_64.pkg.tar.xz /home/jbarks/networkmanager-iwd/libnm-iwd-1.26.2-3-x86_64.pkg.tar.xz /home/jbarks/networkmanager-iwd/nm-iwd-cloud-setup-1.26.2-3-x86_64.pkg.tar.xz'
[2020-12-28T18:50:41-0500] [ALPM] transaction started
[2020-12-28T18:50:41-0500] [ALPM] removed nm-cloud-setup (1.26.4-1)
[2020-12-28T18:50:49-0500] [ALPM] removed networkmanager (1.26.4-1)
[2020-12-28T18:50:49-0500] [ALPM] removed libnm (1.26.4-1)
[2020-12-28T18:50:49-0500] [ALPM] installed libnm-iwd (1.26.2-3)
[2020-12-28T18:50:49-0500] [ALPM] installed networkmanager-iwd (1.26.2-3)
[2020-12-28T18:50:49-0500] [ALPM-SCRIPTLET]
[2020-12-28T18:50:49-0500] [ALPM-SCRIPTLET] >>> It's recommended to enable iwd service if you haven't done yet:
[2020-12-28T18:50:49-0500] [ALPM-SCRIPTLET] systemctl enable iwd.service
[2020-12-28T18:50:49-0500] [ALPM] installed nm-iwd-cloud-setup (1.26.2-3)
[2020-12-28T18:50:50-0500] [ALPM] transaction completed
[2020-12-28T18:50:50-0500] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-12-28T18:50:50-0500] [ALPM] running '30-systemd-udev-reload.hook'...
[2020-12-28T18:50:50-0500] [ALPM] running '30-systemd-update.hook'...
[2020-12-28T18:50:50-0500] [ALPM] running 'dbus-reload.hook'...
[2020-12-28T18:50:50-0500] [ALPM] running 'orphans.hook'...
[2020-12-28T18:50:50-0500] [ALPM-SCRIPTLET] gobject-introspection 1.66.1-3
[2020-12-28T18:50:50-0500] [ALPM-SCRIPTLET] intltool 0.51.0-6
[2020-12-28T18:50:50-0500] [ALPM-SCRIPTLET] meson 0.56.0-3
[2020-12-28T18:50:50-0500] [ALPM-SCRIPTLET] perl-yaml 1.30-2
[2020-12-28T18:50:50-0500] [ALPM-SCRIPTLET] vala 0.50.2-1
[2020-12-28T18:50:50-0500] [ALPM] running 'pacnew-check.hook'...
[2020-12-28T18:51:09-0500] [PACMAN] Running 'pacman -Rns wpa_supplicant'
[2020-12-28T18:57:39-0500] [PACMAN] Running 'pacman -Rns wpa_supplicant networkmanager-support'
[2020-12-28T19:03:14-0500] [PACMAN] Running 'pacman -S networkmanager'
[2020-12-28T19:04:08-0500] [PACMAN] Running 'pacman -Rns networkmanager-iwd nm-iwd-cloud-setup'
[2020-12-28T19:05:12-0500] [PACMAN] Running 'pacman -Rns networkmanager-support wpa-supplicant'
[2020-12-28T19:05:22-0500] [PACMAN] Running 'pacman -Rns networkmanager-support wpa_supplicant'
[2020-12-28T19:05:24-0500] [ALPM] transaction started
[2020-12-28T19:05:24-0500] [ALPM] removed networkmanager-support (1-1)
[2020-12-28T19:05:24-0500] [ALPM] removed xl2tpd (1.3.16-1)
[2020-12-28T19:05:24-0500] [ALPM] removed wireguard-tools (1.0.20200827-1)
[2020-12-28T19:05:24-0500] [ALPM] removed usb_modeswitch (2.6.1-1)
[2020-12-28T19:05:24-0500] [ALPM] removed rp-pppoe (3.14-1)
[2020-12-28T19:05:24-0500] [ALPM] removed openresolv (3.11.0-1)
[2020-12-28T19:05:24-0500] [ALPM] removed openldap (2.4.56-1)
[2020-12-28T19:05:24-0500] [ALPM] removed unixodbc (2.3.9-1)
[2020-12-28T19:05:24-0500] [ALPM] removed ntp (4.2.8.p15-1)
[2020-12-28T19:05:25-0500] [ALPM] removed networkmanager-vpnc (1.2.7dev+20+gdca3aea-2)
[2020-12-28T19:05:25-0500] [ALPM] removed networkmanager-strongswan (1.5.2-1)
[2020-12-28T19:05:25-0500] [ALPM] removed strongswan (5.9.1-1)
[2020-12-28T19:05:25-0500] [ALPM] removed networkmanager-pptp (1.2.9dev+10+gb41b0d0-2)
[2020-12-28T19:05:25-0500] [ALPM] removed pptpclient (1.10.0-2)
[2020-12-28T19:05:25-0500] [ALPM] removed networkmanager-openvpn (1.8.12-1)
[2020-12-28T19:05:25-0500] [ALPM] removed openvpn (2.5.0-3)
[2020-12-28T19:05:25-0500] [ALPM] removed pkcs11-helper (1.27.0-1)
[2020-12-28T19:05:25-0500] [ALPM] removed networkmanager-openconnect (1.2.7dev+49+gc512d5a-1)
[2020-12-28T19:05:25-0500] [ALPM] removed openconnect (1:8.10-1)
[2020-12-28T19:05:25-0500] [ALPM] removed stoken (0.92-4)
[2020-12-28T19:05:25-0500] [ALPM] removed pcsclite (1.9.0-1)
[2020-12-28T19:05:25-0500] [ALPM] removed vpnc (1:0.5.3.r468.r81-2)
[2020-12-28T19:05:25-0500] [ALPM] removed networkmanager-fortisslvpn (1.4rc1-2)
[2020-12-28T19:05:25-0500] [ALPM] removed openfortivpn (1.15.0-1)
[2020-12-28T19:05:25-0500] [ALPM] removed nm-connection-editor (1.18.0-1)
[2020-12-28T19:05:25-0500] [ALPM] removed network-manager-sstp (1.2.6-2)
[2020-12-28T19:05:25-0500] [ALPM] removed sstp-client (1.0.13-1)
[2020-12-28T19:05:25-0500] [ALPM] removed libnma (1.8.30-1)
[2020-12-28T19:05:25-0500] [ALPM] removed gcr (3.38-1)
[2020-12-28T19:05:26-0500] [ALPM] removed neard (0.16-2)
[2020-12-28T19:05:26-0500] [ALPM] removed gpsd (3.21-3)
[2020-12-28T19:05:26-0500] [ALPM] removed dhclient (4.4.2-2)
[2020-12-28T19:05:26-0500] [ALPM] removed wpa_supplicant (2:2.9-7)
[2020-12-28T19:05:26-0500] [ALPM] transaction completed
[2020-12-28T19:05:26-0500] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-12-28T19:05:26-0500] [ALPM] running '30-systemd-udev-reload.hook'...
[2020-12-28T19:05:26-0500] [ALPM] running '30-systemd-update.hook'...
[2020-12-28T19:05:26-0500] [ALPM] running 'dbus-reload.hook'...
[2020-12-28T19:05:26-0500] [ALPM] running 'glib-compile-schemas.hook'...
[2020-12-28T19:05:26-0500] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-12-28T19:05:26-0500] [ALPM] running 'orphans.hook'...
[2020-12-28T19:05:27-0500] [ALPM-SCRIPTLET] gobject-introspection 1.66.1-3
[2020-12-28T19:05:27-0500] [ALPM-SCRIPTLET] intltool 0.51.0-6
[2020-12-28T19:05:27-0500] [ALPM-SCRIPTLET] meson 0.56.0-3
[2020-12-28T19:05:27-0500] [ALPM-SCRIPTLET] perl-yaml 1.30-2
[2020-12-28T19:05:27-0500] [ALPM-SCRIPTLET] vala 0.50.2-1
[2020-12-28T19:05:27-0500] [ALPM] running 'pacnew-check.hook'...
[2020-12-28T19:05:27-0500] [ALPM] running 'update-desktop-database.hook'...
[2020-12-28T19:05:27-0500] [ALPM] running 'update-mime-database.hook'...
[2020-12-28T19:06:19-0500] [PACMAN] Running 'pacman -S networkmanager-openvpn networkmanager-connection-editor'
[2020-12-28T19:06:36-0500] [PACMAN] Running 'pacman -S networkmanager-openvpn nm-connection-editor'
[2020-12-28T19:06:46-0500] [ALPM] transaction started
[2020-12-28T19:06:46-0500] [ALPM] installed pkcs11-helper (1.27.0-1)
[2020-12-28T19:06:46-0500] [ALPM] installed openvpn (2.5.0-3)
[2020-12-28T19:06:46-0500] [ALPM] installed networkmanager-openvpn (1.8.12-1)
[2020-12-28T19:06:46-0500] [ALPM] installed gcr (3.38-1)
[2020-12-28T19:06:46-0500] [ALPM] installed libnma (1.8.30-1)
[2020-12-28T19:06:46-0500] [ALPM] installed nm-connection-editor (1.18.0-1)
[2020-12-28T19:06:46-0500] [ALPM] transaction completed
I re-installed networkmanager-openvpn
nm-connection-editor and ntp.
No breakage so far, I'm pretty happy with it.
