Hello Garuda.
As the title says. The connection works with Win10 and Android.
Every forum search returns null resolutions.
Thanks.
Cool distro BTW. Hope to stick with it.
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=04f4a94a-60b5-424d-a5bc-8228bc0a1f76 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F23g date: 03/09/2018
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4018 high: 4151 min/max: 800/4200 scaling:
driver: intel_pstate governor: performance cores: 1: 4000 2: 4000 3: 4151
4: 4000 5: 4000 6: 4000 7: 4000 8: 4000 bogomips: 63999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 530 vendor: Gigabyte driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: none
empty: DP-1, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:1912 class-ID: 0380
Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: CardExpert
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org v: 21.1.5 with: Xwayland v: 22.1.6
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 33 s-size: 1478x831mm (58.19x32.72")
s-diag: 1696mm (66.76")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 34
size: 1440x810mm (56.69x31.89") diag: 1652mm (65.05") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
1070/PCIe/SSE2 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: NVIDIA GP104 High Definition Audio vendor: CardExpert
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
driver: btusb v: 0.8 bus-ID: 1-7:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.1 TiB used: 172.44 GiB (4.1%)
model: MZVLB1T0HALR-000L7 size: 953.87 GiB block-size: physical: 512 B
rev: 4L2QEXA7 temp: 17.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: 0000 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 056 scheme: MBR
used: 172.44 GiB (18.5%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 31.23 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 50 C
Processes: 257 Uptime: 10h 24m wakeups: 0 Memory: 31.23 GiB
used: 4.15 GiB (13.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1871
libs: 522 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-13
Last full system update: 2022-12-15
