Network Manager couldn't see and connect to the WiFi network
  • Problem happened with me every time after i update garuda packages. When i use Garuda’s version from bootable USB - it works perfectly fine. Last time this problem happened yesterday, immediately on the clean install of the Garuda after i installed updates.
Garuda-inxi output:
  Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=108d9ed7-e7c7-45a9-904e-1893c4362bd3 rw rootflags=subvol=@
  Desktop: Hyprland v: 0.42.0 with: waybar tools: avail: swayidle,swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: MAIBENBEN product: MaiBook X series v: Standard
  Mobo: MAIBENBEN model: X558 v: Standard serial: <superuser required>
    part-nu: X558 uuid: <superuser required> UEFI: American Megatrends LLC.
    v: N.1.50MBB01 date: 08/20/2022
  ID-1: BAT0 charge: 35.3 Wh (100.0%) condition: 35.3/46.7 Wh (75.6%)
    volts: 12.4 min: 11.4 model: standard type: Li-ion serial: <filter>
    status: full
    microcode: 0xA50000C
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 922 high: 3538 min/max: 400/4463 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 1930
    4: 3072 5: 1424 6: 400 7: 400 8: 400 9: 400 10: 400 11: 3538 12: 400
    13: 400 14: 400 15: 400 16: 400 bogomips: 102215
What i tried to solve a problem
  • Downgrade NetworkManager - (each version from 1.48.8 to 1.44.0) and reboot - it didn’t help
  • Using dhclient and dhcpcd as backend - i installed packages, changed NetworkManaged configuration file - no results
  • Full clean reinstall - No any changes.
  • Checked other web pages: Networkmanager 1.46.0-1 Update Breaks internet connectivity; No IPv4 after updating to 1.46.0
    What partially solved a problem
  • Using iwd and enabling iwd service helped (with systemctl enable) but i need to reconnect manually after restart. (NetworkManager service was disabled, but network manage package wasn’t uninstalled).
  • Using a cable: - laptop could recognize it and connects to the internet via cable.
  • Also i am most probably sure, that this problem also cause laptop suspending problems. There are the errors i get each time i try to suspend or reboot.
journalctl -u NetworkManager output:
-- Boot 8d27f93e78dc41aabd14c21997c73887 --
авг 27 11:32:10 borodinov-garuda systemd[1]: Starting Network Manager...
авг 27 11:32:10 borodinov-garuda NetworkManager[768]: <info>  [1724747530.9505] NetworkManager (version 1.48.8-1) is starting... (boot:8d27f93e-78dc-41aa-bd14-c21997c73887)
авг 27 11:32:10 borodinov-garuda NetworkManager[768]: <info>  [1724747530.9505] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf, unmanaged-lo.conf) (etc: dhcp-client.conf)
авг 27 11:32:10 borodinov-garuda NetworkManager[768]: <info>  [1724747530.9529] manager[0x5c137c5ec570]: monitoring kernel firmware directory '/lib/firmware'.
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0092] hostname: hostname: using hostnamed
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0093] hostname: static hostname changed from (none) to "borodinov-garuda"
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0094] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0101] manager[0x5c137c5ec570]: rfkill: Wi-Fi hardware radio set enabled
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0101] manager[0x5c137c5ec570]: rfkill: WWAN hardware radio set enabled
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0113] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.48.8-1/libnm-device-plugin-adsl.so)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0128] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.48.8-1/libnm-device-plugin-bluetooth.so)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0136] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.48.8-1/libnm-device-plugin-ovs.so)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0289] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.48.8-1/libnm-device-plugin-team.so)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0298] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.48.8-1/libnm-device-plugin-wifi.so)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0301] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.48.8-1/libnm-device-plugin-wwan.so)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0302] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0303] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0303] manager: Networking is enabled by state file
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0305] settings: Loaded settings plugin: keyfile (internal)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0309] dhcp: init: Using DHCP client 'dhclient'
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0310] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0315] manager: (enp2s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0322] settings: (enp2s0): created default wired connection 'Wired connection 1'
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.0322] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
авг 27 11:32:11 borodinov-garuda systemd[1]: Started Network Manager.
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.2491] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.2495] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:02.2/0000:04:00.0/ieee80211/phy0/rfkill1) (driver mt7921e)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.2499] ovsdb: disconnected from ovsdb
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.2501] device (wlan0): driver supports Access Point (AP) mode
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.2504] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.2506] modem-manager: ModemManager available
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.2527] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.7848] device (wlan0): set-hw-addr: set MAC address to 3E:F1:FD:C3:15:6B (scanning)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.8640] device (wlan0): supplicant interface state: internal-starting -> disconnected
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.8641] Wi-Fi P2P device controlled by interface wlan0 created
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.8642] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.8643] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.8645] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
авг 27 11:32:11 borodinov-garuda NetworkManager[768]: <info>  [1724747531.8647] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2408] device (enp2s0): carrier: link connected
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2410] device (enp2s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2415] policy: auto-activating connection 'Wired connection 1' (2b5fc40d-5966-3066-a2fd-8e0a18869890)
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2418] device (enp2s0): Activation: starting connection 'Wired connection 1' (2b5fc40d-5966-3066-a2fd-8e0a18869890)
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2418] device (enp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2419] manager: NetworkManager state is now CONNECTING
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2419] device (enp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2423] device (enp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2427] dhcp4 (enp2s0): activation: beginning transaction (timeout in 45 seconds)
авг 27 11:32:14 borodinov-garuda NetworkManager[768]: <info>  [1724747534.2461] dhcp4 (enp2s0): dhclient started with pid 869
авг 27 11:32:14 borodinov-garuda dhclient[869]: DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 4
авг 27 11:32:16 borodinov-garuda NetworkManager[768]: <info>  [1724747536.3722] dhcp6 (enp2s0): activation: beginning transaction (timeout in 45 seconds)
авг 27 11:32:16 borodinov-garuda NetworkManager[768]: <info>  [1724747536.3740] dhcp6 (enp2s0): dhclient started with pid 1388
авг 27 11:32:17 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 930ms.
авг 27 11:32:18 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 1800ms.
авг 27 11:32:18 borodinov-garuda dhclient[869]: DHCPDISCOVER on enp2s0 to 255.255.255.255 port 67 interval 4
авг 27 11:32:18 borodinov-garuda dhclient[869]: DHCPOFFER of 192.168.1.47 from 192.168.1.1
авг 27 11:32:18 borodinov-garuda dhclient[869]: DHCPREQUEST for 192.168.1.47 on enp2s0 to 255.255.255.255 port 67
авг 27 11:32:19 borodinov-garuda dhclient[869]: DHCPACK of 192.168.1.47 from 192.168.1.1
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.1604] dhcp4 (enp2s0):   address 192.168.1.47
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.1604] dhcp4 (enp2s0):   plen 24 (255.255.255.0)
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.1604] dhcp4 (enp2s0):   gateway 192.168.1.1
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.1605] dhcp4 (enp2s0):   lease time 25200
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.1605] dhcp4 (enp2s0):   nameserver '192.168.1.1'
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.1605] dhcp4 (enp2s0): state changed new lease, address=192.168.1.47, acd pending
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.2941] dhcp4 (enp2s0): state changed new lease, address=192.168.1.47
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.2945] policy: set 'Wired connection 1' (enp2s0) as default for IPv4 routing and DNS
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.3014] device (enp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
авг 27 11:32:19 borodinov-garuda dhclient[869]: bound to 192.168.1.47 -- renewal in 9532 seconds.
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.3328] device (enp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.3329] device (enp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.3331] manager: NetworkManager state is now CONNECTED_SITE
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.3332] device (enp2s0): Activation: successful, device activated.
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.3337] manager: startup complete
авг 27 11:32:19 borodinov-garuda NetworkManager[768]: <info>  [1724747539.3558] manager: NetworkManager state is now CONNECTED_GLOBAL
авг 27 11:32:19 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 3510ms.
авг 27 11:32:21 borodinov-garuda NetworkManager[768]: <info>  [1724747541.4175] agent-manager: agent[86d03bed12471b95,:1.32/org.freedesktop.nm-applet/1000]: agent registered
авг 27 11:32:23 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 7250ms.
авг 27 11:32:30 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 14940ms.
авг 27 11:32:45 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 30240ms.
авг 27 11:33:15 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 63100ms.
авг 27 11:34:19 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 125080ms.
авг 27 11:36:24 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 124300ms.
авг 27 11:38:28 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 129590ms.
авг 27 11:39:03 borodinov-garuda NetworkManager[768]: <info>  [1724747943.0132] device (wlan0): set-hw-addr: set MAC address to E2:7C:6C:21:E0:C0 (scanning)
авг 27 11:39:03 borodinov-garuda NetworkManager[768]: <info>  [1724747943.0246] device (wlan0): supplicant interface state: disconnected -> interface_disabled
авг 27 11:39:03 borodinov-garuda NetworkManager[768]: <info>  [1724747943.0246] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> interface_disabled
авг 27 11:39:03 borodinov-garuda NetworkManager[768]: <info>  [1724747943.0436] device (wlan0): supplicant interface state: interface_disabled -> inactive
авг 27 11:39:03 borodinov-garuda NetworkManager[768]: <info>  [1724747943.0436] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
авг 27 11:40:38 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 116030ms.
авг 27 11:42:34 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 123290ms.
авг 27 11:44:37 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 122030ms.
авг 27 11:45:58 borodinov-garuda NetworkManager[768]: <info>  [1724748358.0190] device (wlan0): set-hw-addr: set MAC address to 66:53:05:95:AE:62 (scanning)
авг 27 11:45:58 borodinov-garuda NetworkManager[768]: <info>  [1724748358.0348] device (wlan0): supplicant interface state: inactive -> interface_disabled
авг 27 11:45:58 borodinov-garuda NetworkManager[768]: <info>  [1724748358.0348] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
авг 27 11:45:58 borodinov-garuda NetworkManager[768]: <info>  [1724748358.0516] device (wlan0): supplicant interface state: interface_disabled -> inactive
авг 27 11:45:58 borodinov-garuda NetworkManager[768]: <info>  [1724748358.0516] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
авг 27 11:46:39 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 130110ms.
авг 27 11:48:50 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 120350ms.
авг 27 11:50:50 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 130450ms.
авг 27 11:52:53 borodinov-garuda NetworkManager[768]: <info>  [1724748773.0172] device (wlan0): set-hw-addr: set MAC address to 7A:86:3D:FE:A5:8B (scanning)
авг 27 11:52:53 borodinov-garuda NetworkManager[768]: <info>  [1724748773.0482] device (wlan0): supplicant interface state: inactive -> interface_disabled
авг 27 11:52:53 borodinov-garuda NetworkManager[768]: <info>  [1724748773.0482] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
авг 27 11:52:53 borodinov-garuda NetworkManager[768]: <info>  [1724748773.0484] device (wlan0): supplicant interface state: interface_disabled -> inactive
авг 27 11:52:53 borodinov-garuda NetworkManager[768]: <info>  [1724748773.0484] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
авг 27 11:53:00 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 110630ms.
авг 27 11:54:51 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 118850ms.
авг 27 11:56:50 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 116320ms.
авг 27 11:58:47 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 129790ms.
авг 27 11:59:48 borodinov-garuda NetworkManager[768]: <info>  [1724749188.0179] device (wlan0): set-hw-addr: set MAC address to FA:AE:0F:4D:98:75 (scanning)
авг 27 11:59:48 borodinov-garuda NetworkManager[768]: <info>  [1724749188.0437] device (wlan0): supplicant interface state: inactive -> interface_disabled
авг 27 11:59:48 borodinov-garuda NetworkManager[768]: <info>  [1724749188.0437] device (p2p-dev-wlan0): supplicant management interface state: inactive -> interface_disabled
авг 27 11:59:48 borodinov-garuda NetworkManager[768]: <info>  [1724749188.0644] device (wlan0): supplicant interface state: interface_disabled -> inactive
авг 27 11:59:48 borodinov-garuda NetworkManager[768]: <info>  [1724749188.0644] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> inactive
авг 27 12:00:56 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 124280ms.
авг 27 12:03:01 borodinov-garuda dhclient[1388]: XMT: Info-Request on enp2s0, interval 124600ms.
Please try with the LTS kernel.
You can install it with:
sudo pacman -Syu linux-lts linux-lts-headers
Then select it in the GRUB menu.
Please note that your gaurda-inxi seems to be cut. E.g. the Networking part is not visible.
Booting with Ubuntu LTS kernel
Booting with LTS kernel didn’t help. Also when i unplug cable i can’t get back internet connection even if i use systemctl restart NetworkManager. Only one workaround - rebooting with plugged internet cable.
Workaround
I have found a workaround. I could connect to the WiFI using a second screen (it is attached to my main laptop with HDMI-HDMI cable). I can see all WiFi networks from a second screen. After connection i could see only my chosen WiFi on the laptop screen
Full garuda-inxi:
    status: full
  Speed (MHz): avg: 2082 high: 4444 min/max: 400/4463 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3142 2: 400 3: 4444
    4: 4442 5: 3545 6: 400 7: 400 8: 400 9: 3554 10: 400 11: 3611 12: 3682
    13: 400 14: 400 15: 3702 16: 400 bogomips: 102213
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Tongfang Hongkong driver: nvidia v: 560.35.03
    alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
    2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-1
    empty: DP-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
    vendor: Tongfang Hongkong driver: amdgpu v: kernel arch: GCN-5 code: Vega
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-2 empty: none
    bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 49.0 C
  Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04f2:b711
    compositor: Hyprland v: 0.42.0 driver: X: loaded: amdgpu,nvidia
    gpu: amdgpu,nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 1
  Monitor-1: HDMI-A-1 pos: right model: BenQ EW2775ZH serial: <filter>
    built: 2018 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2 scale: 1
    max: 1920x1080 min: 640x480
  Monitor-2: eDP-2 pos: primary,left model: BOE Display 0x090f built: 2020
    res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 scale: 1.5
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.6-arch1.1
    device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
    type: discrete-gpu name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia
    v: 560.35.03 device-ID: 10de:2520 surfaces: xcb,xlib,wayland device: 2
    v: 24.1.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: NVIDIA GA106 High Definition Audio vendor: Tongfang Hongkong
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
    snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
  API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Tongfang Hongkong driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
  IF: wlan0 state: down mac: <filter>
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 0e8d:0608
  Local Storage: total: 1.38 TiB used: 92.45 GiB (6.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Kingston model: SKC3000S 1024G
    lanes: 4 tech: SSD serial: <filter> fw-rev: W0927B0L temp: 28.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 28.9 C scheme: GPT
  ID-1: / raw-size: 300 GiB size: 300 GiB (100.00%) used: 8.88 GiB (3.0%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:5
    used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:4
  ID-3: /home raw-size: 300 GiB size: 300 GiB (100.00%)
    used: 83.56 GiB (27.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:7
  ID-4: /var/log raw-size: 300 GiB size: 300 GiB (100.00%)
    used: 8.88 GiB (3.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:5
  ID-5: /var/tmp raw-size: 300 GiB size: 300 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p1 maj-min: 259:3
  System Temperatures: cpu: 69.8 C mobo: 40.0 C gpu: amdgpu temp: 49.0 C
  Memory: total: 16 GiB note: est. available: 15.03 GiB used: 4.18 GiB (27.8%)
  Processes: 369 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
    image: 5.96 GiB services: upowerd Init: systemd v: 256 default: graphical
  Packages: pm: pacman pkgs: 1310 libs: 381 tools: pacseek,pamac,paru
    Compilers: gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
    running-in: foot inxi: 3.3.35
  System install date:     2024-08-27
  Last full system update: 2024-08-27 ↻
Update 1:
After finding the workaround i could guess that my networks works fine and i have met with a GUI issue. I couldn’t tell why it happens.
My first screen before connecting to the WiFi:
I could not add screenshot of my second screen but it have a WiFi icon in the topbar. I right-clicked it and was able to see all available WiFi networks.
Update 2
Now i have 2 WiFi icons in my topbar. The right one is one, which allows you to connect to the new WiFi networks and the left one is the one, which doesn’t.
Please do not post here in the forum, like in chat forums.
As long as no one has responded to your post, you can edit your post.
