Kernel: 6.2.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=aeed0525-beaa-4f84-9165-c04fb9af3432 rw [email protected]
resume=UUID=58877725-3f84-4e5b-8ce2-0cf00a037c13 loglevel=3
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2607
date: 08/14/2020
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3467 high: 4254 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 4254 6: 3700 7: 2748 8: 3700 9: 2539 10: 2456 11: 3700
12: 3700 13: 3700 14: 3700 15: 3700 16: 2789 bogomips: 118178
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2484
Screen-1: 0 s-res: 5560x1920 s-dpi: 107 s-size: 1320x456mm (51.97x17.95")
s-diag: 1397mm (54.98")
Monitor-1: DP-0 pos: left res: 1080x1920 hz: 60 dpi: 92
size: 297x527mm (11.69x20.75") diag: 605mm (23.82") modes: N/A
Monitor-2: DP-4 pos: primary,center res: 2560x1440 hz: 165 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-3: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 3-2:3 v: kernel pcie: chip-ID: 33ae:0001
gen: 3 class-ID: 0300 serial: <filter> speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228b class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
Device-3: BEACN Mic type: USB driver: snd-usb-audio
Device-4: Licensed by Sony Entertainment America Rocksmith Guitar Adapter
type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:4
chip-ID: 12ba:00ff class-ID: 0300
API: ALSA v: k6.2.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp8s0f3u1 state: up speed: 425 Mbps duplex: half mac: <filter>
Local Storage: total: 1.55 TiB used: 58.17 GiB (3.7%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 894.25 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 7A0 scheme: GPT
model: WD5000AZLX-75K2TA0 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Patriot model: Blast size: 223.57 GiB
serial: <filter> rev: 12.2 scheme: GPT
ID-1: / raw-size: 859.58 GiB size: 859.58 GiB (100.00%)
used: 58.17 GiB (6.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 859.58 GiB size: 859.58 GiB (100.00%)
ID-4: /var/log raw-size: 859.58 GiB size: 859.58 GiB (100.00%)
ID-5: /var/tmp raw-size: 859.58 GiB size: 859.58 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 1024 KiB (0.0%)
ID-2: swap-2 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 37.9 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 350 Uptime: 10m wakeups: 0 Memory: 31.25 GiB
used: 3.91 GiB (12.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1816
libs: 520 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-04-02
Last full system update: 2023-04-03 ↻
Failed units: Storage.mount NetworkManager-wait-online.service
Network connection does not work with router, but will function while USB Tethering. It will howerver, work in a snapshot but eventually will fail again.
Soltuions I have attempted:
Note: I am on a wired connection.
disabling ipv4 and 6 separately also setting to link local, tried static ipv4 configuration
restarting Network manager, and Network-manager-wait-online.service, network will work for about 30 seconds and cut off again.
rebooting router and computer
checked /etc/resolv.conf I did not see issues
looked through /var/log/garuda/garuda-update no issues.
unplugged ethernet, rebooted pc, waited for full boot then plugged in.
attempted system update
