Hi @Gourav, you have not followed the topic template. Here it is (pasted below), please take another look and add as much information as you can to the thread so we can see what is happening.
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)- Format terminal output (including your
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the textThe template above should be deleted before posting your help request.
I got an old snapshot how to upadate it, first remove the firmware and update ones more is correct or not
Yes, that is the only way you will be able to get past the errors when you update. Perhaps you will need to downgrade one of the specific firmware packages after the update completes.
Paste the output of garuda-inxi into the thread before you begin.
I had the same issue. After doing:
sudo pacman -Rdd linux-firmware and then garuda-update and restarting the system I booted in a very slow enviroment without network. After using snap to access a previous image I did again sudo pacman -Rdd linux-firmware and then garuda-update linux-firmware this worked fine for me.
My apologies @Gourav, as a new member perhaps you were unaware that it is the policy of the Garuda Linux forum that a garuda-inxi terminal output must be provided to receive technical assistance.
Please post the necessary garuda-inxi terminal output on your next post, or your thread will be in violation of our forum’s posting guidelines. Threads that violate our forum’s rules generally end up being sent to the dust bin, so please “help us to help you” and provide us with all the information we need to render assistance.
Your cooperation would be greatly appreciated. ![]()
Ok sir
Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@_backup_20250103223621977/boot/vmlinuz-linux-zen
root=UUID=d46b5928-bfd1-4e3e-b8c7-12375326566d quiet loglevel=3 ibt=off
rootflags=defaults,noatime,compress=zstd,subvol=@_backup_20250103223621977
Desktop: KDE Plasma v: 6.4.0 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Laptop System: HP product: HP Laptop 15s-du1xxx
Mobo: HP model: 85F1 v: 37.29 serial: <superuser required>
part-nu: 1V4G6PA#ACJ uuid: <superuser required> UEFI: Insyde v: F.53
date: 10/15/2021
ID-1: BAT1 charge: 33.4 Wh (98.8%) condition: 33.8/41.0 Wh (82.3%)
volts: 13.0 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Pentium 6405U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check level: v2 built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
microcode: 0xFC
desc: 2x256 KiB L3: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 400 min/max: 400/2400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 19200
Device-1: Intel Comet Lake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
chip-ID: 8086:9b21 class-ID: 0300
Device-2: IMC Networks HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 13d3:56c9
Display: x11 server: X.Org v: 24.1.6 with: Xwayland v: 24.1.8
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x076f built: 2017 res: mode: 1366x768
hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT1)
device-ID: 8086:9b21 memory: 3.54 GiB unified: yes
API: Vulkan v: 1.4.313 layers: 5 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT1) driver: mesa intel v: 25.1.4-arch1.1
device-ID: 8086:9b21 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.6 128 bits) driver: mesa llvmpipe v: 25.1.4-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api tools: N/A
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 0bda:b009
Local Storage: total: 931.51 GiB used: 170.23 GiB (18.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 7C scheme: GPT
ID-1: / raw-size: 209.73 GiB size: 596.99 GiB (284.65%)
used: 73.8 GiB (12.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 946 MiB size: 63.8 MiB (6.75%)
used: 34.7 MiB (54.3%) fs: vfat dev: /dev/sda12 maj-min: 8:12
ID-3: /home raw-size: 209.73 GiB size: 596.99 GiB (284.65%)
ID-4: /var/log raw-size: 209.73 GiB size: 596.99 GiB (284.65%)
ID-5: /var/tmp raw-size: 209.73 GiB size: 596.99 GiB (284.65%)
ID-1: swap-1 type: zram size: 3.63 GiB used: 870.3 MiB (23.4%)
max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 45.0 C pch: 42.0 C mobo: N/A
Memory: total: 4 GiB available: 3.63 GiB used: 1.53 GiB (42.2%)
Processes: 229 Power: uptime: 8h 4m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 fails: 2 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 1.44 GiB services: org_kde_powerdevil,
Packages: 1355 pm: pacman pkgs: 1347 libs: 388 tools: octopi,paru,yay
pm: snap pkgs: 8 Compilers: gcc: 15.1.1 Shell: garuda-inxi default: fish
System install date: 2025-02-10
Last full system update: 2025-06-23 ↻
Failed units: snapper-timeline.service
Thank you @Gourav. Your issue is solved now, is that right?
