Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ec0f3acc-7f46-4d24-ad06-15cfff579e11 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 4403 date: 04/27/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4233 high: 4799 min/max: 2200/4965 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3864 2: 3892
3: 3852 4: 4799 5: 4781 6: 4707 7: 4037 8: 4512 9: 3800 10: 3902 11: 3587
12: 4774 13: 4789 14: 3923 15: 4200 16: 4320 bogomips: 121604
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1, Writeback-1
bus-ID: 0b:00.0 chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.5
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.4-arch1.2
navi22 LLVM 17.0.6 DRM 3.57 6.8.2-zen2-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.4-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.4-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Thesycon System & Consulting GmbH SMSL USB AUDIO
lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 152a:85dd class-ID: 0300
Device-4: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:4
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3
rfk-block: hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10
Local Storage: total: 2.73 TiB used: 277.38 GiB (9.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q
lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.3 temp: 28.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
used: 192.18 GiB (20.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.25 GiB used: 264 KiB (0.0%) priority: 100
System Temperatures: cpu: 63.4 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 44.0 C
Memory: total: 32 GiB available: 31.25 GiB used: 5.93 GiB (19.0%)
Processes: 390 Power: uptime: 1h 57m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1377 libs: 390 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.33
Garuda (2.6.24-1):
System install date: 2024-04-06
Last full system update: 2024-04-07 ↻
Yes I use a paid vpn. The system will forget that it has a hardwired internet connection. I disabled wifi bluetooth etc just to force the connection through the hardline. This issue occurs even when vpn is disabled and uninstalled, the vpn actually makes waking the connection back up easier because I can just && the console disconnect and reconnect commands and have it essentially bounce my connection. I can’t even type a sentence in this forum and post without bouncing my connection.
