Network does not work until VPN is disabled and reenabled
Every time I power on or wake the computer I need to disable the vpn (wireguard) and reenable it for the network to work
I have searched through both the Garuda forums and wiki, Arch forums and wiki and duckduckgo but no searches returned relevant results, does anyone know what could be causing this or how to fix it?
network manager log: (osirix is both the hostname and the name of the vpn config)
ago 03 18:05:38 osirix systemd[1]: Starting Network Manager...
ago 03 18:05:38 osirix NetworkManager[750]: <info>  [1722701138.9341] NetworkManager (version 1.48.6-1) is starting... (boot:554f7382-23b2-4148-bedd-7932ed021a01)
ago 03 18:05:38 osirix NetworkManager[750]: <info>  [1722701138.9364] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf, unmanaged-lo.conf) (etc: 10-garuda-assistant-dns.conf)
ago 03 18:05:38 osirix NetworkManager[750]: <info>  [1722701138.9862] manager[0x584eda096330]: monitoring kernel firmware directory '/lib/firmware'.
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.7134] hostname: hostname: using hostnamed
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.7134] hostname: static hostname changed from (none) to "osirix"
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.7179] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.7310] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/platform/acer-wmi/rfkill/rfkill0) (platform driver acer-wmi)
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.7845] manager[0x584eda096330]: rfkill: Wi-Fi hardware radio set enabled
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.7846] manager[0x584eda096330]: rfkill: WWAN hardware radio set enabled
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.7984] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-adsl.so)
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.8275] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-bluetooth.so)
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.8340] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-ovs.so)
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.9855] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-team.so)
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.9945] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-wifi.so)
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.9960] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.48.6-1/libnm-device-plugin-wwan.so)
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.9989] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.9991] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
ago 03 18:05:39 osirix NetworkManager[750]: <info>  [1722701139.9996] manager: Networking is enabled by state file
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.0029] settings: Loaded settings plugin: keyfile (internal)
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.0256] dhcp: init: Using DHCP client 'internal'
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.0286] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.0444] manager: (enp2s0f1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.0626] settings: (enp2s0f1): created default wired connection 'Wired connection 1'
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.0628] device (enp2s0f1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.2145] manager: (osirix): new WireGuard device (/org/freedesktop/NetworkManager/Devices/3)
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7063] device (osirix): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7150] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
ago 03 18:05:40 osirix systemd[1]: Started Network Manager.
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7217] ovsdb: disconnected from ovsdb
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7251] device (osirix): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7303] policy: auto-activating connection 'osirix' (c9e90145-08ef-4934-8c9e-99c4892c90de)
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7362] device (osirix): Activation: starting connection 'osirix' (c9e90145-08ef-4934-8c9e-99c4892c90de)
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7410] device (osirix): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7458] manager: NetworkManager state is now CONNECTING
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7462] device (osirix): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7659] device (osirix): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7821] modem-manager: ModemManager available
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.7987] device (osirix): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.8024] device (osirix): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.8454] manager: (48:87:59:BF:4E:0B): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/4)
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.8462] device (48:87:59:BF:4E:0B): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.8702] device (48:87:59:BF:4E:0B): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.8775] device (osirix): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:40 osirix NetworkManager[750]: <info>  [1722701140.9718] device (osirix): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.1154] device (osirix): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.1159] device (osirix): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.1205] manager: NetworkManager state is now CONNECTED_LOCAL
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.1212] device (osirix): Activation: successful, device activated.
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.5174] device (wlan0): driver supports Access Point (AP) mode
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.5291] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/5)
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.5901] rfkill3: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0/ieee80211/phy0/rfkill3) (driver ath10k_pci)
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.5965] device (wlan0): interface index 4 renamed iface from 'wlan0' to 'wlp3s0'
ago 03 18:05:41 osirix NetworkManager[750]: <info>  [1722701141.6461] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 03 18:05:42 osirix NetworkManager[750]: <info>  [1722701142.0101] device (wlp3s0): set-hw-addr: set MAC address to B6:A7:B1:74:5B:39 (scanning)
ago 03 18:05:47 osirix NetworkManager[750]: <error> [1722701147.5391] device (wlp3s0): Couldn't initialize supplicant interface: Timeout was reached
ago 03 18:05:47 osirix NetworkManager[750]: <info>  [1722701147.5392] manager: startup complete
ago 03 18:05:58 osirix NetworkManager[750]: <warn>  [1722701158.0003] device (wlp3s0): re-acquiring supplicant interface (#1).
ago 03 18:05:58 osirix NetworkManager[750]: <info>  [1722701158.0098] device (wlp3s0): supplicant interface state: internal-starting -> disconnected
ago 03 18:05:58 osirix NetworkManager[750]: <info>  [1722701158.0100] Wi-Fi P2P device controlled by interface wlp3s0 created
ago 03 18:05:58 osirix NetworkManager[750]: <info>  [1722701158.0105] manager: (p2p-dev-wlp3s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/6)
ago 03 18:05:58 osirix NetworkManager[750]: <info>  [1722701158.0109] device (p2p-dev-wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 03 18:05:58 osirix NetworkManager[750]: <info>  [1722701158.0130] device (wlp3s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
ago 03 18:05:58 osirix NetworkManager[750]: <info>  [1722701158.0146] device (p2p-dev-wlp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5665] policy: auto-activating connection 'MOVISTAR_PLUS_A477' (50fa5a0c-c1be-4033-9e16-48993284ba64)
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5674] device (wlp3s0): Activation: starting connection 'MOVISTAR_PLUS_A477' (50fa5a0c-c1be-4033-9e16-48993284ba64)
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5676] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5679] manager: NetworkManager state is now CONNECTING
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5757] device (wlp3s0): set-hw-addr: reset MAC address to F8:A2:D6:44:63:BB (preserve)
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5850] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5854] device (wlp3s0): Activation: (wifi) access point 'MOVISTAR_PLUS_A477' has security, but secrets are required.
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5855] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5859] device (wlp3s0): supplicant interface state: disconnected -> interface_disabled
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5859] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> interface_disabled
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5870] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5874] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5878] device (wlp3s0): Activation: (wifi) connection 'MOVISTAR_PLUS_A477' has security, and secrets exist.  No new secrets needed.
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5879] Config: added 'ssid' value 'MOVISTAR_PLUS_A477'
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5879] Config: added 'scan_ssid' value '1'
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5879] Config: added 'bgscan' value 'simple:30:-70:86400'
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5879] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5880] Config: added 'auth_alg' value 'OPEN'
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5880] Config: added 'psk' value '<hidden>'
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5895] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.5896] device (p2p-dev-wlp3s0): supplicant management interface state: interface_disabled -> inactive
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.6330] device (wlp3s0): supplicant interface state: inactive -> authenticating
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.6331] device (p2p-dev-wlp3s0): supplicant management interface state: inactive -> authenticating
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.7368] device (wlp3s0): supplicant interface state: authenticating -> associating
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.7368] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.7482] device (wlp3s0): supplicant interface state: associating -> associated
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.7483] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.7558] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.7559] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> 4way_handshake
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.8112] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.8112] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "MOVISTAR_PLUS_A477"
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.8113] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.8115] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:02 osirix NetworkManager[750]: <info>  [1722701162.8126] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.0059] dhcp4 (wlp3s0): state changed new lease, address=192.168.1.65, acd pending
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.1766] dhcp4 (wlp3s0): state changed new lease, address=192.168.1.65
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.1772] policy: set 'MOVISTAR_PLUS_A477' (wlp3s0) as default for IPv4 routing and DNS
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.1860] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.2508] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.2511] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.2521] manager: NetworkManager state is now CONNECTED_SITE
ago 03 18:06:03 osirix NetworkManager[750]: <info>  [1722701163.2527] device (wlp3s0): Activation: successful, device activated.
ago 03 18:06:04 osirix NetworkManager[750]: <info>  [1722701164.6066] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
ago 03 18:06:28 osirix NetworkManager[750]: <info>  [1722701188.2177] agent-manager: agent[6204e60880dab740,:1.43/org.freedesktop.nm-applet/1000]: agent registered
ago 03 18:07:42 osirix NetworkManager[750]: <info>  [1722701262.1521] device (osirix): state change: activated -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
ago 03 18:07:42 osirix NetworkManager[750]: <info>  [1722701262.1550] audit: op="connection-deactivate" uuid="c9e90145-08ef-4934-8c9e-99c4892c90de" name="osirix" pid=1329 uid=1000 result="success"
ago 03 18:07:42 osirix NetworkManager[750]: <info>  [1722701262.2112] device (osirix): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
ago 03 18:07:42 osirix NetworkManager[750]: <info>  [1722701262.2559] device (osirix): state change: disconnected -> unmanaged (reason 'user-requested', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4260] device (osirix): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4291] device (osirix): state change: unavailable -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4329] device (osirix): Activation: starting connection 'osirix' (c9e90145-08ef-4934-8c9e-99c4892c90de)
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4331] audit: op="connection-activate" uuid="c9e90145-08ef-4934-8c9e-99c4892c90de" name="osirix" pid=1329 uid=1000 result="success"
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4356] device (osirix): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4361] manager: NetworkManager state is now CONNECTING
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4362] device (osirix): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4368] device (osirix): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4419] device (osirix): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.4439] device (osirix): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.7574] device (osirix): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.7638] device (osirix): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.7915] device (osirix): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.7918] device (osirix): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.7938] manager: NetworkManager state is now CONNECTED_SITE
ago 03 18:07:45 osirix NetworkManager[750]: <info>  [1722701265.7942] device (osirix): Activation: successful, device activated.
ago 03 18:07:46 osirix NetworkManager[750]: <info>  [1722701266.1350] manager: NetworkManager state is now CONNECTED_GLOBAL
garuda-inxi:
  Kernel: 6.10.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=bfb37244-f624-4c2e-b542-8916ff4236de rw rootflags=subvol=@
    quiet rd.luks.uuid=ed559483-e040-4b29-b1d7-dc284e685d1d loglevel=3
  Desktop: Sway v: 0.4 with: waybar tools: swayidle avail: swaylock vt: 1
    lm: greetd Distro: Garuda base: Arch Linux
  Type: Laptop System: Acer product: Aspire A315-21 v: V1.12
  Mobo: SR model: Squirtle_SR v: V1.12 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.12
    date: 06/19/2018
  ID-1: BAT1 charge: 27.6 Wh (100.0%) condition: 27.6/37.0 Wh (74.6%)
    volts: 8.3 min: 7.7 model: PANASONIC AP16M5J type: Li-ion serial: <filter>
    status: full
  Info: model: AMD A6-9220e RADEON R4 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
    arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
    family: 0x15 (21) model-id: 0x70 (112) stepping: 0 microcode: 0x6006705
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
    desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 2131 high: 2396 min/max: 1200/1600 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 1867 2: 2396
    bogomips: 6388
  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics]
    vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-3
    code: Volcanic Islands process: TSMC 28nm built: 2014-19 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:98e4
  Device-2: Chicony VGA WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:4 chip-ID: 04f2:b5e0
  Display: wayland server: Xwayland v: 24.1.1 compositor: Sway v: 0.4
    driver: gpu: amdgpu display-ID: 1
  Monitor-1: eDP-1 model: BOE Display 0x0675 built: 2015 res: 1366x768
    hz: 60 dpi: 101 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
  API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: AMD
    Radeon R3 Graphics (RADV STONEY) driver: mesa radv v: 24.1.5-arch1.1
    device-ID: 1002:98e4 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: AMD vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
  Device-2: AMD Family 15h Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
  API: ALSA v: k6.10.2-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
    vendor: Acer Incorporated ALI driver: r8168 v: 8.053.00-NAPI modules: r8169
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1
  IF: enp2s0f1 state: down mac: <filter>
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  IF-ID-1: osirix state: unknown speed: N/A duplex: N/A mac: N/A
  Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
  Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:3
    chip-ID: 04ca:3015 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
  Local Storage: total: 119.24 GiB used: 24.79 GiB (20.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS128G39TND-N210A
    size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1P10 scheme: GPT
  ID-1: / raw-size: 118.74 GiB size: 118.74 GiB (100.00%)
    used: 24.79 GiB (20.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ed559483-e040-4b29-b1d7-dc284e685d1d
    used: 728 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 118.74 GiB size: 118.74 GiB (100.00%)
  ID-4: /var/log raw-size: 118.74 GiB size: 118.74 GiB (100.00%)
  ID-5: /var/tmp raw-size: 118.74 GiB size: 118.74 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.22 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 2 dev: /dev/zram0
  System Temperatures: cpu: 37.6 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Memory: total: 8 GiB note: est. available: 7.22 GiB used: 1.3 GiB (18.0%)
  Processes: 241 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.88 GiB services: power-profiles-daemon
  Packages: pm: pacman pkgs: 1422 libs: 470 tools: pacseek,paru pm: flatpak
    pkgs: 0 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
    running-in: foot inxi: 3.3.35
  System install date:     2024-07-27
  Last full system update: 2024-08-03
Follow this as a last resort as it is what I would do if I was in your situation, while waiting for an informed answer.
You have narrowed down the problem to your VPN
  1. Is it enabled by default? Did you try disabling it not to boot with your system e.g systemctl disable ....?
  2. What happens if you uninstall the vpn? Can you access your internet?
  3. If not, what happens if you
sudo systemctl restart systemd-resolved
sudo resolvectl flush-caches
sudo systemctl restart dnsmasq
systemctl rebboot
Just disabling the VPN also works but I do need to use it to access my home network.
What specifically does not work before you do this? Are you able to ping an IP on your LAN? How about on the WAN?
ping 1.1.1.1
[🔴] × ping 1.1.1.1 # WAN
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
From 10.20.1.3 icmp_seq=1 Destination Host Unreachable
ping: sendmsg: Destination address required
From 10.20.1.3 icmp_seq=2 Destination Host Unreachable
From 10.20.1.3 icmp_seq=3 Destination Host Unreachable
From 10.20.1.3 icmp_seq=4 Destination Host Unreachable
From 10.20.1.3 icmp_seq=5 Destination Host Unreachable
^C
--- 1.1.1.1 ping statistics ---
5 packets transmitted, 0 received, +5 errors, 100% packet loss, time 4135ms
 ╭─theredcyclops@osirix in ~ took 4s
[🔴] × ping 192.168.100.1 # Remote (VPN) Router
PING 192.168.100.1 (192.168.100.1) 56(84) bytes of data.
^C
--- 192.168.100.1 ping statistics ---
2 packets transmitted, 0 received, +2 errors, 100% packet loss, time 1049ms
 ╭─theredcyclops@osirix in ~ took 1s
[🔴] × ping 192.168.1.1 # Local Router
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=65.4 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=95.9 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=117 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=3.35 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=5.40 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=5.67 ms
^C
--- 192.168.1.1 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5008ms
rtt min/avg/max/mdev = 3.354/48.800/117.070/46.484 ms
 ╭─theredcyclops@osirix in ~ took 5s
 ╰─λ
