I have woken up my MBP several times after it goes to sleep, and each time I am finding the Network Manager service works fine, Bluetooth is on and connected to my BT keyboard and mouse, but the wifi is dead due to no active connections. I would like to fix that, but I am struggling with the Arch way of doing it. I read one should create a restart service. Not sure that is exactly the solution. My computer stats read as follows from garuda-inxi below. Any hot tips here on what to do so that my Wifi can connect to an Active Connection once I re-awaken the machine?
By Sleep I also mean something overnight happens. If I just use Logout and choose Sleep and then re-awaken the machine, the network connection is fine. It only when I leave the machine for many hours, that this coma happens.
I can save the system status when this happens I suppose and then diff that with this garuda-inxi output to find the culprit?
Kernel: 6.6.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3ca8b255-f29c-4744-8324-8ca995444357 rw rootflags=subvol=@
quiet resume=UUID=88aa211a-5bdb-49f3-a5f5-d8ac5cf926a3 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-E43C1C25D4880AD6
Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1
serial: <superuser required> UEFI: Apple v: 486.0.0.0.0 date: 08/03/2023
ID-1: BAT0 charge: 58.8 Wh (96.7%) condition: 60.8/74.8 Wh (81.4%)
volts: 12.7 min: 11.4 model: DP bq20z451 type: Li-ion serial: N/A
status: full cycles: 209
Device-1: hidpp_battery_8 model: Logitech MX Master 3 for Mac
Info: model: Intel Core i5-5287U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3050 high: 3300 min/max: 500/3300 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3300 2: 2802 3: 3300
4: 2800 bogomips: 23201
Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: HDMI-A-2,eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:162b
alternate: fbdev,intel,vesa dri: iris gpu: i915 d-rect: 3657x1234
display-ID: 0
Monitor-1: HDMI-A-2 pos: right res: 2194x1234 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1463x914 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Graphics 6100 (BDW
GT3) device-ID: 8086:162b memory: 15.16 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 9 device: 0 type: integrated-gpu name: Intel
Iris Graphics 6100 (BDW GT3) driver: mesa intel v: 23.3.1-arch1.1
device-ID: 8086:162b surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
API: ALSA v: k6.6.8-zen1-1-zen status: kernel-api with: aoss
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
chip-ID: 05ac:8290 class-ID: fe01
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0000
Local Storage: total: 465.92 GiB used: 21.68 GiB (4.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512G
size: 465.92 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: JA0Q scheme: GPT
ID-1: / raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
used: 21.68 GiB (4.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
ID-4: /var/log raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.54 GiB size: 448.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 4 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 83.0 C pch: 80.0 C mobo: N/A
Processes: 227 Uptime: 1d 22h 1m wakeups: 7 Memory: total: 16 GiB
available: 15.52 GiB used: 6.11 GiB (39.4%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1940 libs: 562 tools: octopi,paru Shell: fish
v: 3.6.4 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-12-24
Last full system update: 2023-12-25 ↻
