I have a new (2021) HP Essential Laptop Computer 17.3" HD+ AMD Athlon 8 GB memory; 128 GB SSD. I have replaced the Windows OS with garuda-xfce-linux-lts-240428.iso. My computer will not stay connected to the internet. My WiFi connects when the computer boots, but after a few minutes the connection is lost and the Network Manager does not list any available networks. Advanced Network Configuration shows my WiFi Router.
I am running Garuda Linux on my desktop machine with no problems with the network connection dropping.
Please post your garuda-inxi as requested by the template.
Welcome to the community ![]()
inxi -b
Host: tjh-hplaptop Kernel: 6.6.29-1-lts arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Garuda Linux
Type: Laptop System: HP product: HP Laptop 17z-cp200 v: Type1ProductConfigId
serial:
Mobo: HP model: 8A81 v: 41.22 serial: UEFI: Insyde
v: F.13 date: 08/04/2023
ID-1: BAT0 charge: 40.6 Wh (100.0%) condition: 40.6/40.6 Wh (100.0%)
Info: dual core AMD Athlon Gold 7220U with Radeon Graphics [MT MCP]
speed (MHz): avg: 665 min/max: 400/3758
Device-1: AMD Mendocino driver: amdgpu v: kernel
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB
Display: x11 server: X.Org v: 21.1.13 driver: X: loaded: amdgpu
unloaded: modesetting dri: radeonsi gpu: amdgpu resolution: 1600x900~60Hz
API: Vulkan v: 1.3.279 drivers: radv,llvmpipe surfaces: xcb,xlib
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce
Local Storage: total: 119.24 GiB used: 4.04 GiB (3.4%)
Memory: total: 8 GiB note: est. available: 7 GiB used: 1.51 GiB (21.6%)
Processes: 253 Uptime: 4m Shell: Bash inxi: 3.3.34
not
and please
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Is this what you need? I am floundering a bit here.
Kernel: 6.6.29-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=632cf880-6bce-4e34-b59b-cfaa799c66e1 rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Mobo: HP model: 8A81 v: 41.22 serial: <superuser required>
part-nu: 67K39AV uuid: <superuser required> UEFI: Insyde v: F.13
date: 08/04/2023
volts: 13.0 min: 11.3 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full cycles: 1
Info: model: AMD Athlon Gold 7220U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0xA0 (160) stepping: 0
microcode: 0x8A00008
L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 400 min/max: 400/3758 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 bogomips: 19169
Device-1: AMD Mendocino vendor: Hewlett-Packard driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1506
class-ID: 0300 temp: 38.0 C
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
chip-ID: 30c9:0064 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0955 built: 2020
res: 1600x900 hz: 60 dpi: 106 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1600x900 min: 640x480
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: AMD
v: 24.0.5-arch1.1 device-ID: 1002:1506 surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Hewlett-Packard
bus-ID: 03:00.1 chip-ID: 1002:1640 class-ID: 0403
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
API: ALSA v: k6.6.29-1-lts status: kernel-api tools: N/A
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:b00e
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison model: PSELN128GA87MC0
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: HPE4BP00 temp: 26.9 C
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 4.04 GiB (3.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Memory: total: 8 GiB note: est. available: 7 GiB used: 1.44 GiB (20.5%)
Processes: 253 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 2.79 GiB services: upowerd,xfce4-power-manager Init: systemd v: 255
Packages: pm: pacman pkgs: 1250 libs: 398 tools: paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
System install date: 2024-06-12
Last full system update: 2024-06-12
I am having to run the terminal on the laptop, copy the output, email it to myself (before my WiFi connection is lost), open the email on my desktop machine, and send the information to you.
This solution is from a couple years ago, but it’s the same NIC so maybe worth a shot:
The only “gotcha” I see there is that package seems to be no longer in the Chaotic repo (it is just an AUR package now), so you’ll have to install it with something like Paru instead of Pacman.
paru -S rtw88-dkms-git
Press Q to exit the PKGBUILD review and proceed with the installation.
Next time add this exact garuda-inxi field to the first post.
I am far from linux whiz. I am struggling.
I opened Terminal and ran: sudo touch/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
I received a “command not found” response.
I then ran: paru -S rtw88-dkms-git
I was presented with a Repo and an AUR version and a “proceed to review [Y,n]” choice. I entered “Y”
It downloaded PKGBUILDs: /home/joe/.cache/paru/clone/rtw88-dkms-git/PKGBUILD
Terminal installed: rtw88-dkms-git r400.530dfla-1 32.29MiB
Your instructions were: Add the following contents to the newly created conf file (where is this file?) with your preferred text editor: [connection] wifi.powerssave = 0 you can run the following command to generate the required conf file automatically: echo -e [connection] (what is the “connection” reference?).
Have I generated a “conf file”? What do I do from here?
Here a space is missing:
sudo touch /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
It is the file you’ll have created with the command above.
That was only an alternative way to create and update the file with a one-line command. So, one of the two option is enough ([connection] is the same line you see in the text to be copied with the other option).
Probably not, since sudo touch ... hasn’t worked. Follow the instructions again and:
Then restart Network Manager, or reboot.
Then proceed. The package is installed as you said, so proceed with the
Create
/etc/modprobe.d/rtl8821ce.conf
part, again with the same two options, manual and one liner.
I ran the following commands in Terminal:
â•─joe@tjh in ~ as ![]()
] Ă— sudo echo -e touch /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Restarted laptop
â•─joe@tjh in ~ took 12ms
╰─λ Create /etc/modprobe.d/rt18821ce.conf
find-the-command: “Create” is not found locally, searching in repositories…
find-the-command: /var/cache/pkgfile/*.files are out of date, update? [Y/n] Y
[sudo] password for joe:
:: Updating 6 repos…
download complete: community [ 45.0 B 58.0B/s 5 remaining]
download complete: garuda [ 309.6 KiB 315K/s 4 remaining]
download complete: multilib [ 209.4 KiB 156K/s 3 remaining]
download complete: core [ 1103.1 KiB 334K/s 2 remaining]
download complete: chaotic-aur [ 47.7 MiB 9.39M/s 1 remaining]
download complete: extra [ 39.6 MiB 2.18M/s 0 remaining]
:: download complete in 18.19s < 88.9 MiB 4.89M/s 6 files >
:: waiting for 1 process to finish repacking repos…14 pt
find-the-command: command not found: “Create”
Create did not work.
Following your instructions to rerun “the manual and one liner” I reran:
I then opened Thunar as Root. I then went to /etc/NetworkManager/conf.d and found the file default-wifi-powersave-on. I used a text editor to enter wifi.powersave = 0 into it.
I restarted the laptop. Now I am unable to get Network Manager to even open. Clicking on the icon at the bottom of the screen, I am given a message: “NetworkManager is not running “
What now?
These commands are different from those in the suggested post.
Delete /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf and /etc/modprobe.d/rt18821ce.conf (probably not created, the command was wrong) and copy and paste the following
echo -e "[connection]\nwifi.powersave = 0" | sudo tee /etc/modprobe.d/rtl8821ce.conf
echo -e "options rtw_pci disable_aspm=1\nblacklist rtw88_8821ce" | sudo tee /etc/modprobe.d/rtl8821ce.conf
And reboot
The commands are those in the text blocks, while something like
Create /etc/modprobe.d/rtl8821ce.conf:
is just a description.
I have deleted the two files as you suggested.
Let me double check exactly what I should enter as “connection”. Is it:
sudo touch /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf ?
So my first Terminal entry would be:
sudo touch /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf/nwifi.powersave = 0 |
You are trying to make a file here:
The name of the file is default-wifi-powersave-on.conf, and it will be saved inside the /etc/NetworkManager/conf.d directory. The touch and tee commands are just quick ways of automatically creating this file for you. You can also open the file in and editor if you would like–any method is fine.
Inside the file should be these lines:
[connection]
wifi.powersave = 0
The echo | sudo tee commands are intended to automatically add this content to the file, but if you would like you can just open the file in an editor and paste in the content as well.
After this file is set up, restart NetworkManager.
sudo systemctl restart NetworkManager
Thank you all so much. I think I was successful.
BluishHumility you gave the key. I was not able to get any of the Terminal commands to work, so I used Thunar as root and created a file " default-wifi-powersave-on.conf" within " /etc/NetworkManager/conf.d" and entered “wifi.powersave = 0” into the file. I then restarted NetworkManager.
It looks like my WiFi connection is now working.
I appreciate the hand-holding.
Joe Hall
Glad you solved the problem.
I only modified the solution with the post giving the information about the source of the solution, as we always do.
Wait guys.
I was too hasty. I started trying to setup my computer, but my laptop is still dropping the WiFi connection. I have to restart the computer to get a connection and that connection closes after a short length of time.
I am not even able to restart NetworkManager using;
I get this error message:
Failed to restart NetworkManager.service: Unit NetworkManager.service not found.
The only way I can get WiFi back is to restart my computer.
Could this be a hardware issue? The computer is supposedly new from the HP store on ebay.
Just checking: you included the bracketed “[connection]” line, right? The whole file should look like this:
[connection]
wifi.powersave = 0
Double-check for a typo in the command. The capitalization is significant. Copy and paste the full input/output into the thread so we can take a look. Highlight the text in the terminal, and “click” the scroll wheel on the mouse where you want to paste.
Paste also this terminal output:
inxi -Naz
