I am tyring to get netboot to install garuda kde. The menu version 2.0.79 lists garuda images. I have sucessfully boot my laptop into other live cds via netboot. I am very interested in making this work.
I have local assets:
garuda-dr460nized 240428-f610be58
garuda-dr460nized-gaming 240428-a96201bb
I am getting the error:
dracut Warning: dracut: FATAL: No or emtpy root= argument
Then it drops to a dracut shell.
Kernel: 6.9.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
loglevel=3 quiet ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
part-nu: 16U5.1 uuid: <superuser required> UEFI: American Megatrends
v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 23.5 Wh (59.9%) condition: 39.2/51.6 Wh (75.9%)
volts: 11.1 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1614 high: 4391 min/max: 800/4500 scaling:
5: 1644 6: 2800 7: 800 8: 800 9: 4136 10: 800 11: 800 12: 4391
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.0-arch1.1
GT2) device-ID: 8086:3e9b memory: 7.52 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 24.1.0-arch1.1
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.78
device-ID: 10de:1f11 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-arch1.1 (LLVM
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.9.2-zen1-1-zen status: kernel-api with: aoss
vendor: Micro-Star MSI driver: r8168 v: 8.053.00-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
Local Storage: total: 1.38 TiB used: 1.01 TiB (73.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20140000 temp: 39.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
used: 68.81 GiB (47.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 4.3 MiB (1.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C pch: 45.0 C mobo: N/A
Memory: total: 16 GiB available: 15.41 GiB used: 5.24 GiB (34.0%)
Processes: 370 Power: uptime: 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.1 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1866 libs: 537 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2022-07-14
Last full system update: 2024-06-03
