Garuda-inxi
I recently installed Arch LInux Tweak Tools to try my hand at different WMs. I launched it and ran through all the settings. When I reached the neofetch ones, I modified a bit, saved and ran it in the konsole. Now instead of sending the Garuda Linux one, it sends:
Edit: what I did with the tool was just turn on the "Neofetch enabled button" and apply neofetch config. I did not install any WMs yet.
You can post the garuda-inxi in your topic. Here it is.
Kernel: 6.3.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=80fa3bbb-5305-46fa-96da-cb6a36c7ef7f rw rootflags=subvol=@
loglevel=3 ibt=off
Distro: ArcoLinux base: Arch Linux
Type: Laptop System: Acer product: Swift SFX14-51G v: V1.03
Mobo: ADL model: Otter_ADP v: V1.03 serial: <superuser required>
UEFI: Insyde v: 1.03 date: 04/22/2022
ID-1: BAT0 charge: 57.3 Wh (97.4%) condition: 58.8/58.8 Wh (100.1%)
volts: 17.5 min: 15.4 model: SMP KT00407009 AP18E7M type: Li-ion
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x429
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2429 high: 2754 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: performance cores: 1: 2500 2: 2500 3: 2500
4: 2500 5: 2754 6: 2500 7: 2079 8: 2500 9: 2500 10: 2500 11: 2500 12: 1534
13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79872
Device-1: Intel Alder Lake-P Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a6
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
chip-ID: 10de:25a0 class-ID: 0302
Device-3: Chicony ACER FHD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:6 chip-ID: 04f2:b777
Screen-1: 0 s-res: 2240x1400 s-dpi: 96 s-size: 592x370mm (23.31x14.57")
s-diag: 698mm (27.48")
Monitor-1: eDP-1 model: AU Optronics 0xcb9f built: 2021 res: 2240x1400
hz: 60 dpi: 190 gamma: 1.2 size: 300x188mm (11.81x7.4") diag: 354mm (13.9")
ratio: 16:10 modes: 2240x1400
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.3.1-zen1-1-zen status: kernel-api with: aoss
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0033 class-ID: e001
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 70.25 GiB (7.4%)
model: MZVL21T0HCLR-00B07 size: 953.87 GiB block-size: physical: 512 B
fw-rev: GXA7402Q temp: 42.9 C scheme: GPT
used: 70.25 GiB (7.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.33 GiB used: 132 MiB (0.8%) priority: 100
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 396 Uptime: 16m wakeups: 2158 Memory: available: 15.33 GiB
used: 5.27 GiB (34.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2098 libs: 581 tools: octopi,pamac,paru,yay Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-05-04
Last full system update: 2023-05-11 ↻
First off, changing WMs are not supported. If you are going out of your way to do that, you are on your own. Not to mention....
"Distro: ArcoLinux"
Not sure what you did with this tool (since you didn't mention what you did). Weird that it would change the distro label though considering Garuda is "supported" by the tool.
If you are going to mess with your system this much, you should expect a lot of things to break.
The Garuda team didn't make the tool you messed around with, nor supports changing WMs.
If you can't even tell us what you changed with the tool, how do you even expect help anyways? Maybe go ask other users of said tool. GitHub - arcolinux/archlinux-tweak-tool
I think reinstalling garuda-hooks
might fix this.
Haha, I was going through the files to find a hint on what set this and noticed you created an issue RIGHT IN THE SAME MOMENT
opened 07:28PM - 11 May 23 UTC
I recently installed ATT on Garuda Linux. I started it up and noticed the neofet… ch settings. So far, all I have done is turn on the "neofetch enabled button" and apply neofetch config. When running neofetch or fastfetch I get this:
[Neofetch]
[Fastfetch]
Can anyone help me reset it to Garuda?
@PWDSerialgamer07
(posted here for added visibility)
As dr460nf1r3 mentioned on GitHub, Make sure you keep that issue open over at GitHub so the makers of the tool can fix the issue on their side. Garuda is in the supported list after all, and I rather not see more weird assimilation issues going on . I've already watched that happen enough watching Star Trek as is
system
Closed
13 May 2023 20:14
8
