I was a few days ago in another dist with cinnamon and nemo, in that one it displayed below folder names like (78 files), but no matter what setting i change in nemo preferences, it refuses to show the count.
Any idea how to get it visible?
Kernel: 6.12.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=3df21139-cd5f-45f6-8063-226d3de4acff rw rootflags=subvol=@
Desktop: Cinnamon v: 6.4.2 tk: GTK v: 3.24.43 wm: Muffin v: 6.4.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: TUF GAMING B650-PLUS v: Rev 1.xx
serial: part-nu: SKU uuid:
UEFI: American Megatrends v: 3057 date: 10/29/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: charge: 55% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4750 min/max: 545/5050 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4750 2: 4750 3: 4750
4: 4750 5: 4750 6: 4750 7: 4750 8: 4750 9: 4750 10: 4750 11: 4750 12: 4750
13: 4750 14: 4750 15: 4750 16: 4750 bogomips: 134141
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3
code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1, DP-2, HDMI-A-1, HDMI-A-2
empty: Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:747e class-ID: 0300
Display: x11 server: [X.Org](http://X.Org) v: 21.1.15 with: Xwayland v: 24.1.4 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 8192x4464 s-dpi: 108 s-size: 1927x1050mm (75.87x41.34")
s-diag: 2194mm (86.4")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: bottom-l model: Dell U2724D
serial: built: 2024 res: 4096x2304 dpi: 174 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: primary,bottom-r
model: Dell U2724D serial: built: 2024 res: 4096x2304 dpi: 174
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: top-right model: AOC 27G2G4
serial: built: 2020 res: 3840x2160 dpi: 163 gamma: 1.2
Monitor-4: HDMI-A-2 mapped: HDMI-A-1 pos: top-center model: AOC 27G2G4
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 18.1.8 DRM 3.59 6.12.4-zen1-1-zen) device-ID: 1002:747e
memory: 15.62 GiB unified: no
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256
lanes: 16 bus-ID: 70:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.4-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 6b:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac:
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:3 chip-ID: 0b05:190e
class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.1
Hardware-1: Advanced Micro Devices [AMD] Device driver: ahci v: 3.0
port: N/A bus-ID: 6e:00.0 chip-ID: 1022:43bd rev: N/A class-ID: 0104
Local Storage: total: 5.55 TiB used: 319.52 GiB (5.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: fw-rev: EIFK31.6 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Kingston model: SKC3000D2048G
lanes: 4 tech: SSD serial: fw-rev: EIFK31.6 temp: 39.9 C
ID-3: /dev/nvme2n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 620361WD temp: 51.9 C
ID-1: / raw-size: 1.86 TiB size: 5.55 TiB (297.69%) used: 319.52 GiB (5.6%)
ID-3: /home raw-size: 1.86 TiB size: 5.55 TiB (297.69%)
used: 319.52 GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.86 TiB size: 5.55 TiB (297.69%)
ID-5: /var/tmp raw-size: 1.86 TiB size: 5.55 TiB (297.69%)
ID-1: swap-1 type: zram size: 62.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 54.1 C mobo: 39.2 C gpu: amdgpu temp: 60.0 C
mem: 56.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 577
Info:SSSasss
Memory: total: 64 GiB available: 62.44 GiB used: 8.64 GiB (13.8%)
Processes: 462 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.96 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 1714 libs: 485 tools: octopi,pacseek,paru
Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
running-in: guake inxi: 3.3.36
System install date: 2024-12-18
Last full system update: 2024-12-20
