Needing help with stutter lags and freeze
Hello, I have been using Garuda Linux for 3 months now. I’ve had a lot of problems since installing Garuda Dragonized edition on my laptop. I was able to solve them sometimes by finding solutions on the forum.
Recently I had a lot of lag and freeze. I visited the page dedicated to the subject (Troubleshooting System Stutter, Lags, Freezes, and Hangs).
I tested different kernel zen, lts, zenver2, catchy-os catchyos-BORE, Liquorix Xanmod, Xanmod. The one that seems to work best overall is xanmod1-1-edge-x64v3, but I can’t launch a game via Itch.iopar for example. I used to be able to do this with zenver2 and now it doesn’t work with any kernel.
I tried to install different versions of Wine (wine-staging, wine -wow64 to see if the problem could come from there but without success. I also tried to download different versions of Vulkan drivers via Nvidia-all.
I’ve also tried swapping between Wayland and X11 X11 is the most stable so far, whereas Wayland causes glitches and is very unstable for me.
Also, my Nvidia driver works on Linux zenver2 and Xanmod but under Catchyos, the Nivida server program doesn’t show me all the parameters.
Do you think Corectrl is responsible for any problems? The parameters proposed by Corectrl are very limited.
I can’t figure out what’s causing my recurring problems and why, from one day to the next, I can’t launch games either via Steam or Itch.io or what’s making my laptop feeze.
The worst : I’ve also had Libreoffice crash when I try to copy and paste, for example.
I’m at a loss and don’t know what to do.
Here’s my acutal garuda-inxi :
Kernel: 6.12.1-x64v3-xanmod1-1-edge-x64v3 arch: x86_64 bits: 64
compiler: gcc v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge-x64v3
root=UUID=4541648c-12b5-471b-9d28-480ff74553f5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
Mobo: HP model: 86D5 v: 96.45 serial: <superuser required>
part-nu: 8BT93EA#ABF uuid: <superuser required> UEFI: AMI v: F.20
date: 05/06/2024
ID-1: BAT0 charge: 40.3 Wh (100.0%) condition: 40.3/40.3 Wh (100.0%)
volts: 12.3 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full cycles: 362
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3134 min/max: 1400/2300 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3134 2: 3134 3: 3134
4: 3134 5: 3134 6: 3134 7: 3134 8: 3134 bogomips: 36728
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 565.57.01
alternate: nvidiafb,nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Hewlett-Packard driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-2
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 80.0 C
Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:5365
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x61ed built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 10 Graphics
(radeonsi raven LLVM 18.1.8 DRM 3.59 6.12.1-x64v3-xanmod1-1-edge-x64v3)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.295 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Vega 10 Graphics (RADV RAVEN) driver: mesa radv v: 24.2.7-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 565.57.01
device-ID: 10de:1f91 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.1-x64v3-xanmod1-1-edge-x64v3 status: kernel-api
with: aoss type: oss-emulator tools: N/A
Server-2: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Info: services: NetworkManager, nginx, systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:b00c
Local Storage: total: 1.03 TiB used: 512.94 GiB (48.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-128G-1006 size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20120006 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 68.52 GiB (57.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
maj-min: 259:2
zswap: no
ID-1: swap-1 type: zram size: 5.66 GiB used: 4.48 GiB (79.1%)
priority: 100 comp: zstd avail: lzo-rle,lzo,lz4,lz4hc max-streams: 8
System Temperatures: cpu: 87.9 C mobo: N/A gpu: amdgpu temp: 87.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 6 GiB note: est. available: 5.66 GiB used: 4.55 GiB (80.3%)
Processes: 456 Power: uptime: 2h 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.21 GiB services: org_kde_powerdevil,
Packages: 2158 pm: pacman pkgs: 2141 libs: 604 tools: gnome-software,
octopi, pamac, paru pm: snap pkgs: 17 Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-10-05
Last full system update: 2024-11-25
IDK, but …
maybe you have a heat and RAM problem.
Thanks. In fact I hadn’t noticed, I’m going to look to see if I can replace the thermal paste for heat. For the RAM memory I am not inoculating the budget to replace with 16 GB. I was still able to operate my laptop correctly. The question I ask myself is why even small indie games that don’t require a lot of resources have stopped working and I have started lagging overnight
