I cannot find in Garuda (with gnome as the DE) where to disable or terminal command to disable hibernation. That is, if I leave my System76 laptop while in Garuda, it eventually turns off without leaving the area in which I am working. So, I have to push the power button to turn it on.
Thanks for your help.
I have googled extensively and have looked at various help areas regarding Garuda linux. Have even watched YouTubes on Garuda Linux and have actually installed it before. This problem is new to me; my laptop shutting off after a specific duration reminds me of what Microsoft does with Windows using hibernation. As a network admin, I used to disable hibernation because they tended to be problematic.
Where / what do I have to install -- are the gnome settings in Garuda linux? The only setting I managed to find was to turn off the blanking of the screen when closing my laptop. What is weird is this is the 2nd time I have installed Garuda-gnome (first install after a while would not get past the login screen) and I did not have this issue the first time.
