Need help with systemctl enable --now fstrim.timer
 ╰─λ garuda-inxi
  Kernel: 6.1.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=0590fe61-9088-453a-9aca-ad0cc0dced40 rw [email protected]
    quiet
    cryptdevice=UUID=b7641313-1009-4b60-bb53-29da5479d641:luks-b7641313-1009-4b60-bb53-29da5479d641
    root=/dev/mapper/luks-b7641313-1009-4b60-bb53-29da5479d641 quiet splash
  Desktop: LXQt v: 1.2.1 tk: Qt v: 5.15.8 info: cairo-dock, lxqt-panel
  Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2601 date: 05/17/2022
  Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4398 high: 4903 min/max: 800/5100 scaling:
    driver: intel_pstate governor: performance cores: 1: 4901 2: 3800 3: 4684
    4: 4902 5: 4899 6: 4903 7: 3800 8: 4743 9: 4892 10: 3800 11: 1747 12: 4807
    13: 4892 14: 4902 15: 4900 16: 3800 bogomips: 121596
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 53.0 C
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
    built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
    diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
    missing.
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Sound API: ALSA v: k6.1.8-zen1-1-zen running: yes
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.18 TiB used: 15.33 GiB (0.5%)
    model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
    rev: 211070WD temp: 34.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
    rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
    rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
    used: 15.33 GiB (6.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-b7641313-1009-4b60-bb53-29da5479d641
    used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1207
  Processes: 362 Uptime: 1h 12m wakeups: 0 Memory: 31.25 GiB
  used: 3.99 GiB (12.8%) Init: systemd v: 252 default: graphical
  pkgs: 1364 libs: 341 tools: gnome-software,octopi,pamac,paru Shell: fish
  v: 3.6.0 running-in: qterminal inxi: 3.3.24
Garuda (2.6.14-1):
  System install date:     2023-01-30
  Last full system update: 2023-02-01
I'm confused about this and need help.
I looked online and even visited YouTube.
Please do not post pictures of terminal outputs. This is our forum's policy, (unless there is absolutely no other method to post this info). Press the pencil icon below your Original Post (OP), and remove the picture and replace it with the proper textual output.
Have you considered the use of luks as the root of your issue:
Enable periodic TRIM - including on a LUKS partition - Tech Knowledge Base - jaytaala.com Confluence
https://wiki.archlinux.org/title/Dm-crypt/Specialties#Discard/TRIM_support_for_solid_state_drives_(SSD)
Please... just copy paste.
Pictures of terminal make no sense unless there's some UI glitch to show, or it's impossible to post otherwise.
the discard operation is not supported
I guess... the discard operation is not supported.
From fstrim.service:
/usr/bin/fstrim --listed-in /etc/fstab:/proc/self/mountinfo --verbose --quiet-unsupported
From man fstrim:
       --quiet-unsupported
           Suppress error messages if trim operation (ioctl) is unsupported. This option is meant to be used in systemd service file or in cron(8) scripts to hide warnings that are result
           of known problems, such as NTFS driver reporting Bad file descriptor when device is mounted read-only, or lack of file system support for ioctl FITRIM call. This option also
           cleans exit status when unsupported filesystem specified on fstrim command line.
The timer is correctly enabled, but see here: Discard/TRIM_support_for_solid_state_drives_(SSD)
edit: LOL, I didn't see the above post.
I do understand what transpired, yes.
I wanted to experiment with encryption mode this time.
sorry
No problem. After all, we run Linux also because we like to experiment.
And I like to look into these issues because I learn something in the process.
Although I greatly appreciate your nice sentiments, I really need your assistance in installing AMD drivers. Here is a picture, although I'm not sure.\
I took it out. I just read your message, and I'm really sorry because this is a brand-new animal.
I hope I'm not mistaken, it looks like it's already installed.
Thank you
I wanted to hear that :slight_smile:
