Kernel: 6.1.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d14feffa-13aa-4e7c-a3e8-4c066739d757 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.28.80 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2601 date: 05/17/2022
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4474 high: 4802 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 4802 2: 4801 3: 4800
4: 4760 5: 3800 6: 3800 7: 4802 8: 4762 9: 4747 10: 4767 11: 4802 12: 3800
13: 4751 14: 3800 15: 4798 16: 3800 bogomips: 121596
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 52.0 C
Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.8-zen1-1-zen) direct render: Yes
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.1.8-zen1-1-zen running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.21 TiB used: 23.11 GiB (0.7%)
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211070WD temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
used: 23.11 GiB (9.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1160
Processes: 339 Uptime: 12m wakeups: 0 Memory: 31.25 GiB
used: 2.85 GiB (9.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1454
libs: 439 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
Garuda (2.6.14.r0.g8183f88-1):
System install date: 2023-01-28
Last full system update: 2023-01-28
This is where I need help. no matter what I do
this is not working
powerpill
I've searched wherever I can for the arch wiki.
I've been entering long, winding commands.
and Still cant fix it
