Need help with NUT running on Garuda as client
Still having issues with NUT run as client on Garuda.
I installed nut.
I tried installing nut, nut-client, nut-monitor
I get nut-2.8.2-2 is up to date
with sudo pamac install nut
I also get more files in the nut folder than in other distros, in which I have it working on all,
Win10,11, Mint, openmediavault, qnap NAS., and others.
Nut server is APC upc and served from QNAP and works on everything but Garuda.
In /etc/nut/ folder I have: host.conf, nut.conf, ups.conf, upsd.conf, upsd.users, upsmon.conf, upssched.conf, upsset.conf, upsstats.html, upsstats-single.html
Where in other Linux distro’s I have: nut.conf, upsconf, upsmon.conf.
Just can’t seem to figure it out.
  Kernel: 6.14.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=1a5793f8-3377-4500-9b95-bcfc4a65af9e rw rootflags=subvol=@
  Desktop: Cinnamon v: 6.4.10 tk: GTK v: 3.24.49 wm: Muffin v: 6.4.1 tools:
    avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Dell product: Inspiron 3670 v: N/A
  Mobo: Dell model: 0H4VK7 v: A01 serial: <superuser required> part-nu: 0868
    uuid: <superuser required> UEFI: Dell v: 2.21.0 date: 12/03/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
  Info: model: Intel Core i5-9600K bits: 64 type: MCP arch: Coffee Lake
    model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 4401 min/max: 800/4600 scaling: driver: intel_pstate
    governor: performance cores: 1: 4401 2: 4401 3: 4401 4: 4401 5: 4401 6: 4401
    bogomips: 44398
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
    ports: active: none empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3e98 class-ID: 0380
  Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Gigabyte driver: nvidia
    v: 570.144 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 4
    ports: active: none off: HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1d01 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6 driver: X:
    loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x331mm (23.70x13.03")
    s-diag: 687mm (27.05")
  Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Acer KB272HL H
    serial: <filter> built: 2022 res: mode: 1920x1080 hz: 75 scale: 100% (1)
    dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia x11:
    drv: nvidia inactive: wayland
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
    memory: 1.95 GiB
  API: Vulkan v: 1.4.309 layers: 7 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GT 1030 driver: nvidia v: 570.144 device-ID: 10de:1d01
    surfaces: xcb,xlib device: 1 type: discrete-gpu
    device-ID: 10de:1d01 surfaces: xcb,xlib device: 2 type: integrated-gpu
    name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
    v: 25.0.5-arch1.1 device-ID: 8086:3e98 surfaces: xcb,xlib device: 3
    type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
    v: 25.0.5-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo
    gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
  Device-2: NVIDIA GP108 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
  API: ALSA v: k6.14.5-zen1-1-zen status: kernel-api tools: N/A
  Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0 chip-ID: 8086:15f3
  IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
  Local Storage: total: 2.73 TiB used: 984.87 GiB (35.2%)
    model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 620361WD temp: 31.9 C scheme: GPT
    model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
    scheme: MBR
  ID-1: / raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
    used: 117.19 GiB (21.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 27 MiB (28.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
  ID-4: /var/log raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
  ID-5: /var/tmp raw-size: 558.98 GiB size: 558.98 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 6
  System Temperatures: cpu: 31.0 C pch: 38.0 C mobo: 31.0 C gpu: nvidia
    temp: 36 C
  Fan Speeds (rpm): cpu: 1000 gpu: nvidia fan: 51%
  Memory: total: 32 GiB available: 31.16 GiB used: 3.02 GiB (9.7%)
  Processes: 306 Power: uptime: 3h 48m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.39 GiB services: csd-power,upowerd
  Packages: 1660 pm: pacman pkgs: 1644 libs: 462 tools: pamac,paru
    pm: flatpak pkgs: 16 Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: garuda-inxi
    default: fish v: 4.0.2 running-in: gnome-terminal inxi: 3.3.38
  System install date:     2024-09-26
  Last full system update: 2025-05-07
I don’t know if this helps, anyway…:
I ended up deleting all the NUT stuff and installed WinNUT via Wine.
Works like a charm! Even give you the applet that gives mouse over
WinNUT ver.
Connected - online
Battery - OK
