I installed Garuda Dragonized edition on my Hp laptop selected Hibernate with Swap but when I hibernate it doesn't wake up. Also now my usb keyboard stopped working it was working earlier to this. I used another usb port on the system. Please help I'm a newbie to Linux. I need help to wake up when hibernated. Have tried CTRL+ ALT+ Fx all bindings none of them works , have also tried switching on the power button but same.
inxi - Faz Output
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=5611ffb8-9652-4b12-98bb-26426f572ee2 rw rootflags=subvol=@
resume=UUID=5742a49a-ab74-465b-b7b3-0fa451737516 loglevel=3
Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
v: 0884110000385910000610100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 183E v: 56.32 serial: <superuser required>
UEFI: Insyde v: F.22 date: 11/22/2012
ID-1: BAT0 charge: 15.6 Wh (100.0%) condition: 15.6/15.6 Wh (100.0%)
volts: 12.3 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-3110M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1213 high: 1266 min/max: 1200/2400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1266 2: 1197 3: 1192
4: 1197 bogomips: 19154
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: AMD Thames [Radeon HD 7500M/7600M Series]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 1002:6840 class-ID: 0300
Device-3: Suyin HP TrueVision HD Integrated Webcam type: USB
driver: uvcvideo bus-ID: 2-1.5:3 chip-ID: 064e:e263 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver:
gpu: i915 note: X driver n/a display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: LG Display 0x034d built: 2012
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 22.0.0 compat-v: 3.1 direct render: Yes
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard
driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 1814:3290 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8136
Device-1: Ralink RT3290 Bluetooth vendor: Hewlett-Packard driver: N/A pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.1 chip-ID: 1814:3298
class-ID: 0d11
Report: bt-service: enabled,stopped note: tool can't run
Local Storage: total: 931.51 GiB used: 10.98 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
ID-1: / raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
used: 10.98 GiB (1.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-4: /var/log raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 123.2 MiB (1.6%)
System Temperatures: cpu: 49.0 C mobo: N/A gpu: radeon temp: 43.5 C
Processes: 201 Uptime: 16h 43m wakeups: 13 Memory: 7.66 GiB
used: 1.79 GiB (23.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1349 lib: 349 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
filo
30 March 2022 07:14
2
Hi there, first of all, welcome!
I’ve found a reference into the arch wiki related to a similar model (HP Pavilion g6-2379sr) with some known problems:
Suspend to RAM: Working properly
Suspend to Disk: Not work (do not turn off pc, just freeze on black screen)
It doesn’t necessarily mean you cannot find a solution (sightly different model and also slightly different problem), but I think you should keep this in mind at a certain point in time.
I’m not an expert of this stuff, but a couple of things you could do:
Update your system, with garuda-update from terminal, because 5.16.16-zen1-1-zen is surpassed, then reboot.
Check if there is a more recent BIOS/UEFI version, since UEFI: Insyde v: F.22 date: 11/22/2012 seems old.
PS:
I edited your post to give a raw look to the inxi with ~~~. Please check for the future
And also in the future usegaruda-inxi, providing more information.
Thanks for the reply. I have checked the BIOS update for this device that was the last update, they had release a BIOS update after that but removed it from Official website as it was causing issues to a lot of users and they recommend staying on this BIOS. Also just to let you know in my BIOS I have Legacy Support Enabled Secure Boot OFF is that whats causing the issue.
Also why my usb keyboard stopped working on one of the ports and its working on the other PORT all happened after this HIbernate thing. My mouse does work on the port also when I attach the keyboard it lights up but unable to type anything.
serial: N/A status: full
Speed (MHz): avg: 1274 high: 1439 min/max: 1200/2400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1264 2: 1439 3: 1197
4: 1197 bogomips: 19157
Type: l1tf
loaded: intel,radeon unloaded: modesetting alternate: fbdev,vesa gpu: i915
class-ID: 0d11
Local Storage: total: 931.51 GiB used: 12.53 GiB (1.3%)
used: 12.53 GiB (1.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 67.0 C mobo: N/A gpu: radeon temp: 57.0 C
Processes: 216 Uptime: 10m wakeups: 1 Memory: 7.66 GiB
used: 1.9 GiB (24.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1350 lib: 350 Shell: fish v: 3.3.1
Garuda (2.5.6-2):
System install date: 2022-03-30
Last full system update: 2022-03-30
Also have updated the system as asked with garuda-update
Also how to do that inxi with ~~~ to make it look raw ?
filo
30 March 2022 07:34
4
Just like this:
text
So there's no new update for the BIOS
Legacy Enabled Secure Boot Turned OFF
have provided Garuda inxi
where can we get from here ?
filo
30 March 2022 07:47
6
Why Legacy enabled?
UEFI mode normally performs much better.
I’d try in that way, if there was no specific reason to use the Legacy mode.
The only other suggestion I can provide is this article in th Arch wiki.
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Suspend/hibernate_does_not_work,_or_does_not_work_consistently
E.g. you could try to install the linux-lts kernel and a few other things described.
Apart from that, most likely someone more knowledgable on the topic will jump in
Why Legacy enabled?
-well i have kept that since Windows and haven't changed it
Also Do I really need Hibernate ? Can I use it without Hibernate ? I mean I have already created a swap partition.
Thanks for your help anyways i'll wait for the help.
Bro
30 March 2022 10:07
8
Not if you don’t hibernate.
Use what? Garuda? Of course.
I don't need hibernate but need swap so selecting No Swap at the installation will it still create a default swap. Coz I reinstalled everything now selected No Swap but when I check
swapon -show
Also swappiness
And when I tried to test opening multiple tabs in browser and same time multiple apps it used Swap memory as below
So does this mean swap is present by default and I don't have to manually create swap?
Coz I'm okay if don't have hibernate but I need swap
SGS
30 March 2022 11:58
10
Seems so.
And please, please, please, no pictures from terminals. It’s not readable on cells. Copy and paste as text.
filo
30 March 2022 12:09
11
KundanWadkar:
swapon -show
This is the zram, which is compressed swap in RAM. Not the “traditional” swap.
https://wiki.archlinux.org/title/Improving_performance#zram_or_zswap
It is provided by default, and I think you should keep it.
KundanWadkar:
Also swappiness
That one has a high value exactly to try and use the zram.
So, you’re good to go in this way, in my opinion.
Ok sorry I'll keep that in mind... So everything's good right? I don't have to add swap manually or anything I'm good to go with this.
tbg
30 March 2022 14:06
14
Is there a possibility your USB port is physically damaged? Does that port work on other live disks?
Search your logs for "USB" related errors. Sometimes the iommu=soft kernel parameter helps with USB problems. Kernel parameters may also help with your hibernatation issue.
Heve you checked/changed/tested different C-States in your BIOS, as they directly affect your ability to suspend/hibernate?
Welcome to Garuda.
