Hello everyone
I have for some issues trough reason updates in a scale which makes my machine almost unusable (on fresh install). Certian QT apps have issues (GIMP) ,apps like blender have graphic glitsche (work bench shader black) and can’t recognize the GPU on top i also have issues with OBS when i hover over the close icon the program crahses and i get a Job 1, 'obs' terminated by signal SIGSEGV (Address boundary error)
i had none of these issues a few months back (basicly everything worked like it was supposed to and even better ). At this point i am despreat and i am seriously considering to change to something debian based. I AM DESPERATE
(using Wayland)
Kernel: 6.7.0-rc2-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=3716c11f-4a32-420a-85ed-64cb9c7ed222 rw rootflags=subvol=@
Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7B93 v: 1.0
Mobo: Micro-Star model: MPG X570 GAMING PRO CARBON WIFI (MS-7B93) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.E0
date: 12/17/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2429 high: 3400 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 3400 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 3400 14: 2200 15: 2200 16: 2200 17: 3315 18: 3400 19: 2200
20: 2200 21: 2200 22: 2879 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200
28: 2935 29: 2200 30: 2200 31: 3400 32: 2200 bogomips: 217692
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3
bus-ID: 26:00.0 chip-ID: 1002:744c class-ID: 0300
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Gigabyte G27F serial: <filter> built: 2020
res: 1920x1080 dpi: 81 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 model: Acer S221HQL serial: <filter> built: 2010
res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (gfx1100 LLVM
16.0.6 DRM 3.56 6.7.0-rc2-1-mainline) device-ID: 1002:744c
memory: 19.53 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV GFX1100) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 26:00.1 chip-ID: 1002:ab30
bus-ID: 2e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA Seiren Mini driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:2
chip-ID: 1532:0531 class-ID: 0300 serial: <filter>
API: ALSA v: k6.7.0-rc2-1-mainline status: kernel-api tools: N/A
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:4 chip-ID: 8087:0029
Local Storage: total: 1.36 TiB used: 433.66 GiB (31.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Kingston model: SA2000M8500G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 38.9 C
used: 35.27 GiB (3.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 38.2 C mobo: N/A gpu: amdgpu temp: 46.0 C
mem: 64.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 39
Processes: 568 Uptime: 13m wakeups: 0 Memory: total: 32 GiB
available: 31.26 GiB used: 4.34 GiB (13.9%) Init: systemd v: 254
Packages: 1619 pm: pacman pkgs: 1605 libs: 462 tools: pamac,paru pm: flatpak
pkgs: 14 Shell: fish v: 3.6.1 default: Bash v: 5.2.15
running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-21
Last full system update: 2023-11-22
i am happy for any help !
