Need help to configure my Hardware / Thunderbolt 4 / NVIDIA / Multi-Monitor
Hello all,
I’m new with Garuda (XFCE) and have some problems configuring my hardware:
I have a Notebook with Intel I9-13900HX Prozessor, NVIDIA RTX 4060 and a Dell Thunderbolt 4 Dock.
After installing Garuda only the Notebook internal display was recognized.
1 additional Monitor connected via HDMI wasn’t detected and
2 additional Monitors connected via Dell Thunderbolt 4 Dock wasn’t detected, too
and as seen in the INXI output, some other hardware wasn’t detected, too.
Hope you can gimme assistant in configuring my harware.
Best regards
  Kernel: 6.6.0-rc6-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
    root=UUID=743b7f9e-a8cb-4673-b02a-4685a2621552 rw rootflags=subvol=@
    v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: PCSpecialist product: Recoil VII 17 v: Standard
  Mobo: TongFang model: GM7PX0_7N v: Standard serial: <filter> UEFI: American
    Megatrends LLC. v: N.1.06A00 date: 02/03/2023
  ID-1: BAT0 charge: 97.2 Wh (98.0%) condition: 99.2/99.2 Wh (100.0%)
    volts: 16.6 min: 15.5 model: standard type: Li-ion serial: <filter>
    status: not charging
  Info: model: 13th Gen Intel Core i9-13900HX socket: U3E1 bits: 64
    type: MST AMCP arch: Raptor Lake gen: core 13 level: v3 note: check
    built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183)
    stepping: 1 microcode: 0x119
  Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
    cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
    L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
  Speed (MHz): avg: 800 min/max: 800/5200:5400:3900 base/boost: 4356/8500
    scaling: driver: intel_pstate governor: performance volts: 1.3 V
    ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800 24: 800 25: 800
    26: 800 27: 800 28: 800 29: 800 30: 800 31: 800 32: 800 bogomips: 154880
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: Tongfang Hongkong
    driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3,
    HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:a788 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
    vendor: Tongfang Hongkong driver: N/A alternate: nouveau non-free: 545.xx+
    status: current (as of 2023-10) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
  Device-3: Chicony FHD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:6 chip-ID: 04f2:b7c2
  Display: x11 server: X.Org v: 21.1.9 compositor: xfwm v: 4.18.0 driver: X:
    loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965
    gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0a99 built: 2021
    res: 2560x1600 hz: 240 dpi: 181 gamma: 1.2 size: 360x220mm (14.17x8.66")
    diag: 422mm (16.6") ratio: 16:10 modes: 2560x1600
  API: Vulkan v: 1.3.269 layers: 5 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-S) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:a788 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
  Device-1: Intel vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
  Device-2: NVIDIA vendor: Tongfang Hongkong driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
  Device-3: Corsair HS70 Pro Wireless Gaming Headset
    lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 1b1c:0a4f class-ID: 0300
  API: ALSA v: k6.6.0-rc6-1-mainline status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.84 status: n/a (root, process) with:
  Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
    chip-ID: 8086:7a70 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Tongfang Hongkong driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 3a:00.0
  IF: enp58s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
  Device-3: Realtek RTL88x2bu [AC1200 Techkey] driver: rtw_8822bu type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:4
    chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u1u4 state: down mac: <filter>
  Device-4: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.4.4:5
  IF: enp32s0u1u4u4 state: down mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-14:11 chip-ID: 8087:0033 class-ID: e001
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 5.7 TiB used: 19.67 GiB (0.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 40.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 2TB
  ID-3: /dev/sda maj-min: 8:0 vendor: Generic model: STORAGE DEVICE
    size: 29.48 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0819 scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM024 HN-M101MBB
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> fw-rev: 0204 scheme: MBR
  ID-5: /dev/sdc maj-min: 8:32 model: SSD 480GB size: 447.13 GiB block-size:
    physical: 4096 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1
    mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1101 scheme: GPT
  ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD7500BPVT-08HXZT3 size: 698.64 GiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> scheme: MBR
  ID-1: / raw-size: 911.18 GiB size: 911.18 GiB (100.00%)
    used: 19.63 GiB (2.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p5
    maj-min: 259:9
    used: 32.3 MiB (33.6%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
    maj-min: 259:5
  ID-3: /home raw-size: 911.18 GiB size: 911.18 GiB (100.00%)
    maj-min: 259:9
  ID-4: /var/log raw-size: 911.18 GiB size: 911.18 GiB (100.00%)
    maj-min: 259:9
  ID-5: /var/tmp raw-size: 911.18 GiB size: 911.18 GiB (100.00%)
    maj-min: 259:9
  ID-1: swap-1 type: partition size: 977 MiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p6 maj-min: 259:10
  ID-2: swap-2 type: zram size: 62.54 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
  System Temperatures: cpu: 46.0 C mobo: N/A
  Processes: 509 Uptime: 15m wakeups: 0 Memory: total: 64 GiB
  available: 62.54 GiB used: 3.54 GiB (5.7%) igpu: 60 MiB Init: systemd v: 254
  Packages: pm: pacman pkgs: 1725 libs: 463
  tools: gnome-software,octopi,pamac,paru Shell: Bash (sudo) v: 5.2.15
  running-in: xfce4-terminal inxi: 3.3.31
Garuda (2.6.18-1):
  System install date:     2023-11-09
  Last full system update: 2023-11-09
  Windows dual boot:       Yes
Here is the Journal:
Nov 09 23:28:47 Linkat01 systemd-vconsole-setup[336]: /usr/bin/setfont failed with exit status 71.
Nov 09 23:28:47 Linkat01 systemd-modules-load[332]: Failed to find module 'vboxpci'
Nov 09 23:28:48 Linkat01 systemd-vconsole-setup[532]: /usr/bin/setfont failed with exit status 71.
Nov 09 23:28:49 Linkat01 systemd-modules-load[630]: Failed to find module 'vboxpci'
Nov 09 23:28:50 Linkat01 systemd-vconsole-setup[824]: /usr/bin/setfont failed with exit status 71.
Nov 09 23:28:50 Linkat01 kernel: proc_thermal_pci 0000:00:04.0: error: proc_thermal_add, will continue
Nov 09 23:28:50 Linkat01 kernel: nouveau 0000:01:00.0: unknown chipset (197000a1)
Nov 09 23:28:50 Linkat01 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Nov 09 23:28:51 Linkat01 kernel: usbhid 1-6:1.0: couldn't find an input interrupt endpoint
Nov 09 23:28:51 Linkat01 kernel: usbhid 1-10:1.0: couldn't find an input interrupt endpoint
Nov 09 23:28:51 Linkat01 (udev-worker)[729]: host0: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/host0/scsi_host/host0/link_power_management_policy}, ignoring: Datei oder Verzeichnis nicht gefunden
Nov 09 23:28:52 Linkat01 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Nov 09 23:28:53 Linkat01 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Nov 09 23:28:53 Linkat01 (udev-worker)[772]: host1: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.1/1-9.1.3/1-9.1.3.2/1-9.1.3.2.1/1-9.1.3.2.1.3/1-9.1.3.2.1.3:1.0/host1/scsi_host/host1/link_power_management_policy}, ignoring: No such file or directory
Nov 09 23:28:59 Linkat01 nmbd[2044]: [2023/11/09 23:28:59.935964, 0] ../../source3/nmbd/nmbd.c:901(main)
Nov 09 23:28:59 Linkat01 nmbd[2044]: main: nmbd version 4.19.2 started.
Nov 09 23:28:59 Linkat01 nmbd[2044]: Copyright Andrew Tridgell and the Samba Team 1992-2023
Nov 09 23:28:59 Linkat01 smbd[2046]: [2023/11/09 23:28:59.972709, 0] ../../source3/smbd/server.c:1746(main)
Nov 09 23:28:59 Linkat01 smbd[2046]: smbd version 4.19.2 started.
Nov 09 23:28:59 Linkat01 smbd[2046]: Copyright Andrew Tridgell and the Samba Team 1992-2023
Nov 09 23:29:00 Linkat01 kernel: xhci_hcd 0000:1f:00.0: xHCI host controller not responding, assume dead
Nov 09 23:29:00 Linkat01 kernel: xhci_hcd 0000:1f:00.0: HC died; cleaning up
Nov 09 23:29:00 Linkat01 kernel: pcieport 0000:03:03.0: Unable to change power state from D3hot to D0, device inaccessible
Nov 09 23:29:00 Linkat01 kernel: pcieport 0000:03:01.0: Unable to change power state from D3hot to D0, device inaccessible
Nov 09 23:29:06 Linkat01 (udev-worker)[772]: host1: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9.1/1-9.1.3/1-9.1.3.2/1-9.1.3.2.1/1-9.1.3.2.1.3/1-9.1.3.2.1.3:1.0/host1/scsi_host/host1/link_power_management_policy}, ignoring: No such file or directory
Nov 09 23:29:12 Linkat01 lightdm[1800]: gkr-pam: unable to locate daemon control file
Nov 09 23:29:14 Linkat01 kernel: thunderbolt 0000:04:00.0: failed to send driver ready to ICM
Nov 09 23:29:14 Linkat01 libvirtd[1371]: Gerät 0000:04:00.0 nicht gefunden: Zugriff auf /sys/bus/pci/devices/0000:04:00.0/config nicht möglich: Datei oder Verzeichnis nicht gefunden
Nov 09 23:29:16 Linkat01 (udev-worker)[772]: host2: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1b.0/0000:02:00.0/0000:03:02.0/0000:20:00.0/usb4/4-1/4-1.4/4-1.4.3/4-1.4.3.2/4-1.4.3.2.2/4-1.4.3.2.2:1.0/host2/scsi_host/host2/link_power_management_policy}, ignoring: Datei oder Verzeichnis nicht gefunden
Nov 09 23:29:16 Linkat01 (udev-worker)[729]: host3: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1b.0/0000:02:00.0/0000:03:02.0/0000:20:00.0/usb4/4-1/4-1.4/4-1.4.3/4-1.4.3.2/4-1.4.3.2.3/4-1.4.3.2.3:1.0/host3/scsi_host/host3/link_power_management_policy}, ignoring: Datei oder Verzeichnis nich
t gefunden
Nov 09 23:29:16 Linkat01 (udev-worker)[772]: host4: /usr/lib/udev/rules.d/50-sata.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1b.0/0000:02:00.0/0000:03:02.0/0000:20:00.0/usb4/4-1/4-1.4/4-1.4.3/4-1.4.3.2/4-1.4.3.2.1/4-1.4.3.2.1.2/4-1.4.3.2.1.2:1.0/host4/scsi_host/host4/link_power_management_policy}, ignoring: Datei oder Verzeichnis nicht gefunden
