─λ garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "de_DE.UTF-8",
LC_NAME = "de_DE.UTF-8",
LC_MONETARY = "de_DE.UTF-8",
LC_PAPER = "de_DE.UTF-8",
LC_IDENTIFICATION = "de_DE.UTF-8",
LC_TELEPHONE = "de_DE.UTF-8",
LC_MEASUREMENT = "de_DE.UTF-8",
LC_TIME = "de_DE.UTF-8",
LC_NUMERIC = "de_DE.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e3dc9934-1ce5-4cbb-bcd3-a4f1ecc1fee3 rw [email protected]
loglevel=3 ibt=off
Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2601 date: 05/17/2022
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3800 min/max: 800/5100 scaling: driver: intel_pstate
governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800
7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800 13: 3800 14: 3800
15: 3800 16: 3800 bogomips: 121596
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 51.0 C
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
built: 2019 res: 2560x1440 hz: 60 dpi: 93 gamma: 1.2
size: 697x393mm (27.44x15.47") diag: 800mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.9-zen1-1-zen) direct render: Yes
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.18 TiB used: 13.87 GiB (0.4%)
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211070WD temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
used: 13.87 GiB (6.0%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1188
Processes: 360 Uptime: 13m wakeups: 0 Memory: 31.25 GiB
used: 3.15 GiB (10.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1943
libs: 527 tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.0
error: could not register 'chaotic-aur' database (database already registered)
Garuda (2.6.14-1):
System install date: 2023-02-03
Last full system update: 2023-02-03 ↻
need help i messed up my terminal
find-the-command: "Run" is not found locally, searching in repositories...
find-the-command: command not found: "Run"
~/.config/fish/config.fish (line 158):
Run paleofetch if session is interactive
from sourcing file ~/.config/fish/config.fish
called during startup
find-the-command: "paleofetch" is not found locally, searching in repositories...
find-the-command: command not found: "paleofetch"
~/.config/fish/config.fish (line 160):
paleofetch
source: Error encountered while sourcing file '/home/gnome/.bash_aliases':
source: No such file or directory
